01-12-2017, 10:06 AM
#81
1963 19' Globetrotter
Seattle
my 65 24' tradewind had mahogany cabinets and walls - 64-65 must have been a shift from mahogany to oak because my 1966 globetrotter has the oak cabinets which aren't nearly as nice.
i'm thinking of redoing all the cabinets in my trailer BUT after seeing the darker color stain you have used it makes the oak look so much better. maybe i'll strip and re-stain mine?
*let me know if you will be in seattle this week - i still have the furnace you inquired about
all the best!
1968 22' Safari - All Original
01-12-2017, 10:38 AM
#82
Central
, Mississippi
I'm amazed at you guys who are able to use some/all of the interior wood. Everything I have messed with is completely falling apart and only partially useable as a pattern.
Great looking work!
01-12-2017, 10:40 AM
#83
1963 22' Safari
2020 27' Globetrotter
State of
Thanks. Yes the oak they used in 62 must have Been on the clearance rack. I've seen it in browns and it didn't take stain well. This is actually a mahogany stain. Lots of conditioner. They were so cheap though that things like the styles between doors were pine not oak since they only show a little.
As the weather gets better definitely want to get over there for it. Have a retired friend that has a doctors appointment over there I may see if he can swing through for me. I'll give you a call. Thanks again!
Oh I did consider a white or gray wash stain but ended up going this direction. Hopefully I don't regret it when I get to doors
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
01-12-2017, 10:42 AM
#84
1963 22' Safari
State of
Thanks! Reusing is tough. In reality I could have rebuilt. Most doors and drawers I reskin and trim route new faces. Some sides i reglue and repair the veneer, some I replace. Has a little character but no more than a refinished antique in the house.
Scott & Megan
01-12-2017, 06:11 PM
#85
1963 22' Safari
State of
Plenty of panels like this that are trash
The good news is I'm only a sheet in so far but know I'll be in several more fixing doors and drawers
Scott & Megan
01-12-2017, 09:03 PM
#86
1963 22' Safari
State of
I'd sure appreciate it if folks could keep an eye out for these pop in vents. I'm short a lot. I need to do a final count but need a dozen or so. Haven't found a source yet locally. They are smaller than ones I've purchased for soffits etc. Anyone have any ideas?
Sorry for the bad tape measure. It's an old stand by and the shop was down to 4 degrees so I moved fast!
Scott & Megan
01-13-2017, 07:36 AM
#87
1968 22' Safari
NorCal
Round louvered vents
You can find some similar online. I'm not sure if you're trying to match the same vintage or not but here's a google search that turned up several options.
http://tinyurl.com/jc7rjqp
Gratitude for all there is and all there isn't!
Photos of our gal.
WBCCI #19233
01-13-2017, 10:06 AM
#88
1963 22' Safari
State of
Thank you! Yeah I'm hoping to match if I can. Lots of plastic ones out there. I like the lines of the original Better than the simplified newer ones but they are certainly better than a empty hole in the cabinet. Each double wardrobe has 6 of them, 4 of them on the singles. Maybe someone has a drawer of used ones they saved?
Scott & Megan
01-13-2017, 11:55 AM
#89
Central
, Mississippi
I know I have some, lemme look tonight.
01-13-2017, 04:52 PM
#90
Central
, Mississippi
Will this get you started?
01-13-2017, 05:57 PM
#91
1963 22' Safari
State of
Thank you! I just got home from a quick hardware run. Was tipped off locally that one of the mom and pop stores and they had some in a bin the back. I just got on to post and saw your stack. Thank you for looking but they have me covered and they look really close.
New on the left
Scott & Megan
01-18-2017, 06:14 PM
#92
1963 22' Safari
State of
Today we woke up to almost a half inch of freezing rain so no work today. It briefly was above freezing for a change so I heated up the garage and got to work.
Water tank cleaned up, polished the filler pipe and put 3 coats of clear on it. Started to polish the cap too but have more work to clean out the years of pliar marks.
It's ready to go back in after one more rinse.
5 more drawers and 4 doors were refinished today although nearly all the prep work had been done already. The bathroom vanity now is complete and ready to reassemble once the hardware is stripped. Kitchen cabinet is nearly complete, one more upper door and one lower left
Also heated up the trailer and cut in for the final color so I can put up the kitchen roof locker for good and install the lights and power everything up on the 110v side.
This week is supposed to be wet, but some days above freezing so I hope to finish painting the sheet metal and install the cabinets that are already done.
I still have 17 more doors and 5 bed drawers and one false front left.
I'm stunned how much storage this thing has. It's no wonder it's the "caravanner" layout. Tons of room for long trips for someone
Grover water pump is in great shape although we'll be going to a modern on demand pump.
Scott & Megan
01-18-2017, 06:32 PM
#93
1963 22' Safari
State of
Scott & Megan
01-20-2017, 06:40 PM
#94
1963 22' Safari
State of
Tomorrow the power finally goes on. All the lights are painted and will get reassembled tomorrow. So happy the PO didn't toss them. They cleaned up nicely
Scott & Megan
01-21-2017, 04:09 PM
#95
1963 22' Safari
State of
Kitchen cabinet is in for good, roof cabinet is back up, doors starting to go back on and managed to get the lights all up minus the kitchen one. I'll need to pick up parchment for the sconces. 110 is on, but not 12 volt yet
Scott & Megan
01-26-2017, 12:28 PM
#96
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Thank you for the photos of your restoration project. It is looking great. Not very many can start from the exterior skin and work their way in. I know I could not. You are building a great thread for those who may happen to find a Tread Wind shell in the street after a storm.
Very nice period look.
David
01-28-2017, 08:00 PM
#97
1963 22' Safari
State of
Scott & Megan
01-29-2017, 05:34 PM
#98
1963 22' Safari
State of
Doors doors doors. Only 2 to make and 5 drawers to sand left
Scott & Megan
02-03-2017, 05:55 PM
#99
1986 34' Limited
1975 27' Overlander
Conifer
You are going right after it. Soon you can close the door on these doors. Renovating a vintage Airstream takes a lot of hours. Your's looks great.
Here is a photo of my staining a couple of years ago. It is nothing like your project, but I did remake a several cabinet doors and bulkhead walls. I am no cabinet maker, but it did get done and it is functional, although not beautiful.
David
02-04-2017, 05:24 PM
#100
1963 22' Safari
State of
Scott & Megan
