Old 11-04-2016, 08:13 PM   #29
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Name:	ImageUploadedByAirstream Forums1478311813.310508.jpg
Interesting as I did another application of stripper I realized that someone stripped the lettering, it didn't go away so they painted the front. You can tell what had clearcoat left and what came off back in the day.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 11-04-2016, 08:48 PM   #30
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
This takes ghost letters to a new meaning, great find. I would leave them, my vote.
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
Old 11-05-2016, 05:19 PM   #31
goransons's Avatar
1963 22' Safari
Weather was too cold today to strip the back. Finished installing the last half bow on the street side that was missing and riveted in the cross members. Was on track to finish the street side today when my really nice vintage Chicago Pheumatic rivet gun diaphragm failed. Will call around Monday to see about a rebuilt but bought a gun from Aircraft Spruce to hopefully be riveting again by Wednesday. To replace my gun with the same model was almost $800 which isn't going to happen (mine came from the Boeing folks).
After that work I replaced the bad bow back by the tub on the curb side and got that cleco'd in place along with a new corner panel (still in plastic ). Replacing the rear panel in the morning and a small patch to cover some damage to the bottom of the long side panel.
Our friend Wally (Dr. Bucking Bar) took the tool failure in stride and did some test polishing up front and got a good start on the front end cap. Tomorrow he's going to help me around the 2 jelousie windows and the front window so I can reinstall them their eyebrows and get things dry up front.
Name:	ImageUploadedByAirstream Forums1478387691.723001.jpg
ID:	274860Click image for larger version
Name:	ImageUploadedByAirstream Forums1478387704.378280.jpg
ID:	274861Click image for larger version
Name:	ImageUploadedByAirstream Forums1478387831.238549.jpg
Scott & Megan
Old 11-05-2016, 06:48 PM   #32
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Looking like a 63 Safari again. I wonder about how much of the exterior skin you actually replaced. I bet over 50%. Just a whole lot of sheet metal work.
David
dbj216 is online now   Reply With Quote
Old 11-05-2016, 06:59 PM   #33
goransons's Avatar
1963 22' Safari
My signature line is misleading, I do have a 63 safari, this actually a 62 Tradewind (single axle) with a custom layout much like the flying cloud that year, just with one more cabinet on each side. Haven't found the layout documented yet, part of the reason I wanted to save it (my original plan was to cut this down and make a "fake" bambi length trailer just for fun.
I'm about at 50% of the flat metal yes, by the time I'm done that's about right. On the bright side that's 50% less to strip clear coat off of, and 50% less to grind the crud off in the polishing stages. If you count that it's getting a 100% new belly pan I guess it's more than 50% of the sheet metal.
Scott & Megan
Old 11-05-2016, 07:22 PM   #34
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I stand corrected. I knew it was a Trade Wind. Just wasn't thinking. Nice that you have two vintage Airstreams, both from the Byam years when only the best would do.
David
Old 11-06-2016, 05:47 PM   #35
goransons's Avatar
1963 22' Safari
LONG day today. No riveting while I wait for the new rivet gun to arrive. Punch list stuff today.
All c channel on the curb side bolted down. Angle brackets reinstalled on the door frame and bolted in.
Outrigger belly pan on curb side from bumper to step installed.
Rear end cap and remaining lower panels stripped for polishing.
Rear anchor plate bolted in and rear wall panel replaced.
Wally did some great polishing on the front end cap getting it ready for the front window to go in for real (after it gets cleaned up and I remove the front end cap). Will be nice to get the rock guard, emblem, etc all back on and finally have a dry front end.
Here's his polishing work with the dirty window frame back in for the night (man it looks bad)
Name:	ImageUploadedByAirstream Forums1478479396.238663.jpg
End cap is starting to blend nicely with the new metal
Name:	ImageUploadedByAirstream Forums1478479491.162548.jpg
Last of the new panels in. Some small patches to put on but I'm out of cleco's.
Name:	ImageUploadedByAirstream Forums1478479547.688579.jpg
Name:	ImageUploadedByAirstream Forums1478479596.216818.jpg
Anyone got one of these in better shape? At least the lens. Don't mind the mess it's in place temporarily to keep the water out since is above the window.
Scott & Megan
Old 11-06-2016, 06:01 PM   #36
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good old Wally the well polished bucking bar holder is making some good progress. And so are you.
Our friends at Vintage Trailer Supply have Airstream "scare" lights if you need one.
http://www.vintagetrailersupply.com/category-s/444.htm
David
Old 11-06-2016, 06:10 PM   #37
goransons's Avatar
1963 22' Safari
I have one from VTS, it's smaller and the lens isn't interchangeable either (theirs uses 3 screws, mine uses a different pattern and 4 screws). I had the same thought as you and ordered it with my last order. It's an exact replacement for my 63 so it'll eventually end up there. If I wanted to use it on the tradewind I'd need to put a patch up there and recut a hole, I'm hoping to find an exact replacement. I'm tired of sheet metal work I bought a complete set of the new LED side marker lights, new lenses for the tail lights, and new license light and bracket. As soon as we get polished around those openings I can get all those on and sealed up.
Scott & Megan
Old 11-07-2016, 06:04 PM   #38
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I didn't look closely, I just ASSUMED they are all the same. An exact replacement may be harder to find.
I understand your desire to move on from the exterior sheet metal work. You've certainly done a lot of riveting.
David
Old 11-11-2016, 05:41 PM   #39
goransons's Avatar
1963 22' Safari
Thanks Aerowood for designing a great roller! Well worth the money. I still have a bit more work to do but about an hour with my home made roller and another 45 minutes with the better one he designed and a heat gun and we are well on our way.
Before...
Name:	ImageUploadedByAirstream Forums1478911239.096108.jpg
After..
Name:	ImageUploadedByAirstream Forums1478911262.698346.jpg
Scott & Megan
Old 11-12-2016, 05:36 PM   #40
goransons's Avatar
1963 22' Safari
The last of the patches...
Deleted antenna using original holes just in case someone wants to put it back.
Name:	ImageUploadedByAirstream Forums1478997127.322977.jpg
Deleted mess from the tv antenna mount.
Name:	ImageUploadedByAirstream Forums1478997152.599008.jpg
Panel repair from the retaining wall. With more than 50% of sheet metal replaced I decided not to reskin the entire side just for this corner. Purists I'm sorry you're disappointed.
Name:	ImageUploadedByAirstream Forums1478997232.513996.jpg
Jelousie windows seem to always result in a crack above the window near the bow. New repair plate with a backing plate inside ready.
Name:	ImageUploadedByAirstream Forums1478997298.218632.jpg
Tomorrow curb side belt line and rear panel get rivets. Hope to clean up the two jelousie windows, polish around them and reinstall for good. All depends on the weather cooperating.
Scott & Megan
Old 11-13-2016, 08:13 AM   #41
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I'm happy the roller worked for you
Old 11-13-2016, 07:19 PM   #42
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Nice job on rolling the dents. It is a process that seems to work. It requires inside access, which many of us consider too much work to gain access.
I also patch my old TV antenna hole. Maybe I should have kept it and converted it to a flag holder. Actually my trailer has a lot of patches. One for the new water heater, one for the new furnace, one for the dent by the door, and one for the new shore power and city water connections. Oh well. Not a show winner, but a lot of fun none the less.
David
1962, full monte, panel replacement, shell off, tradewind
Top wind or Side wind? kirkrik Hitches, Couplers & Balls 14 08-11-2015 08:40 PM
Tin Can Dreams and Wee Wind Wishes avenuegirl Member Introductions 9 09-30-2008 08:53 AM
Just signed on and just started my 61 trade wind Craig Murphy Member Introductions 11 10-25-2007 09:28 PM
Rims and tires for my Wee Wind vonkamp Tires 9 11-30-2006 09:55 PM
Wind screen sealing and veneer replacement abridges01 Argosy Motorhomes 8 09-04-2006 10:05 AM
