Old 04-02-2017, 04:25 PM   #127
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
First cut on the upper half of the curb side. Swirl marks will go away on the next grit with the random orbital. Also with perfect weather the bathroom counter got three coats of epoxy paint.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 04-02-2017, 04:26 PM   #128
goransons's Avatar
1963 22' Safari
ID:	282579Click image for larger version
ID:	282580Click image for larger version
ID:	282581Click image for larger version
Scott & Megan
Old 04-02-2017, 06:44 PM   #129
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You won't have to polish as much as I did as a lot of your aluminum is new. You're going to spend all those hours making your trailer reflective as a mirror only to see all those water spots at the next rain event. At least that is what happened to me. And did I mention bird and bug splats, or wet leaves?
That counter top looks great. What was the substrait you painted over? Fiberglass, wood, or countertop "pressed wood"?
David
Old 04-02-2017, 09:49 PM   #130
goransons's Avatar
1963 22' Safari
I know the insanity of keeping up a mirror shine. I won't be going that crazy on it. That counter is the factory counter. Fiberglass one piece with plywood backing for attaching to the cabinet. Had some minor failures of the gel coat. Repaired, sanded and 3 coats of a Urethane epoxy paint used on automotive plastic bumpers. It's very very sticky, lays out nice, very flexible and holds up better than the roll on tile stuff.
Scott & Megan
Old 04-03-2017, 01:07 AM   #131
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
Looking good Scott!
groovzilla is offline   Reply With Quote
Old 04-03-2017, 06:03 PM   #132
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the description of the nifty vanity top. I figured the original was gone with the wind. It sure looks nice after your restoration. You have added more value to your old Trade Wind. The polish job will also add value. Polished Airstreams are an "attractive nuisance".
David
Old 04-04-2017, 09:01 PM   #133
goransons's Avatar
1963 22' Safari
We have water!!!
Drain lines are finished and bathroom counter is in. Final trim out in the bathroom and wiring up the water heater then on to finish trimming out then gas lines next.
ID:	282707Click image for larger version
Scott & Megan
Old 04-05-2017, 08:48 AM   #134
groovzilla's Avatar
looks good scott! i really appreciate your desired to restore to original.
if and when you get time, could you please send me a quick diagram of how you piped your water supply lines from the fresh water tank to 12v pump, to hot water heater/etc? showing flo restrictors and how hot/cold are piped to and from hot water tank
i'll be doing copper pipe in my trailer soon and need info on layout.
Old 04-05-2017, 05:03 PM   #135
goransons's Avatar
1963 22' Safari
Thanks! I'll work on that this week. Why copper? Pex is so much easier and won't have the same issues if it freezes a little.
Long day today. Working on punch list stuff. Finished around the toilet, wired the electronic ignition on the water heater, installed towel holders, toilet paper holder, toothbrush holder etc. tons of little trim outs etc. finishing paint tomorrow and then will clean and wax the floor. Still have propane lines to run but going to focus the next few work days on closing up the belly pan. Click image for larger version
ID:	282782Click image for larger version
ID:	282783Click image for larger version
Scott & Megan
Old 04-05-2017, 05:04 PM   #136
goransons's Avatar
1963 22' Safari
ID:	282785Click image for larger version
Scott & Megan
Old 04-05-2017, 06:20 PM   #137
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Looking brand new! The wood cabinetry in your single axle Trade Wind (Safari? I can't tell the difference.) is magnificent. Our 86 Limited has the hickory cabinetry which looks quite nice, and has held up well. But it is 20 years newer.
Have you ever wondered how many times you have ducked your head and stepped in and out of your Airstream? My hip was sore the other day and I decided it was due to stepping in and out of the Globetrotter. It's up on jack stands making the step higher.
Renovating old Airstreams is good exercise.
David
Old 04-05-2017, 07:38 PM   #138
goransons's Avatar
1963 22' Safari
There's a fine line between running into the garage for a tool and hoarding them in the trailer. I haven't found the perfect solution. 1000's of times on that door I bet. Thanks! I can't wait to get the gas lines in and be on to just cosmetic details. Did get a new socket in the sconce by the kitchen today. Old one needed a switch so it got updated. Originally was a gas lamp but I'm just not a fan of hot glass and molten mantle over brand new cushions so it's a reading light now
Scott & Megan
Old 04-05-2017, 07:41 PM   #139
goransons's Avatar
1963 22' Safari
I can't wait to get this on the market and on to Wally's trailer but I'll get there soon enough. Also just listed my 51 clipper on the classifieds.
Scott & Megan
Old 05-17-2017, 08:17 PM   #140
goransons's Avatar
1963 22' Safari
update
Sorry it's been so long since I've updated.
Life gets crazy during little league season!
Since my last post we've installed a new dexter axle, which was interesting for sure. In 1962 I've heard that Airstream considered the torsion axle to be a "forever" axle so it was welded in. No axle plate at all, just pressed against the frame and welded until the factory ran out of welding rod or the dinner bell rang.
After about 5 hours of cutting and cutting the axle was out, then fabricated installed new axle plates, axle, then figured out the old wheels had the wrong size hub hole in the middle (too small) so new rims are on the way.
I've wired up the brakes, and installed a breakaway switch (originals were hydraulic). Back half of the flat belly pan is back in place, just need a calm day to install the front half, then I can do gas lines this weekend. I'm hoping to have all the gas systems up and running before next week, then will be doing final polishing and details. By June 1st the trailer will be going up for sale so we can start on the Wally Byam trailer and have the resources to do it justice.
If you know someone who might be interested send them our way. 100% new floor (full sheets, not pieced), new axle, lots of new metal, all new wiring, new insulation, completely resealed, all new waste lines, valves etc, all new pex plumbing, new 10 gallon electric/gas water heater, new 2-way dometic refrigerator, new water pump, new battery, new intellipower inverter, new black tank, new faucets, new new new new new new. Hoping to find it a good home.
Pictures to follow soon of the progress, just a dead phone.
Scott & Megan
1962, full monte, panel replacement, shell off, tradewind
Top wind or Side wind? kirkrik Hitches, Couplers & Balls 14 08-11-2015 08:40 PM
Tin Can Dreams and Wee Wind Wishes avenuegirl Member Introductions 9 09-30-2008 08:53 AM
Just signed on and just started my 61 trade wind Craig Murphy Member Introductions 11 10-25-2007 09:28 PM
Rims and tires for my Wee Wind vonkamp Tires 9 11-30-2006 09:55 PM
Wind screen sealing and veneer replacement abridges01 Argosy Motorhomes 8 09-04-2006 10:05 AM
