Old 05-20-2019, 07:03 AM   #1
1965 24' Tradewind
Middle , Georgia
Swamperdog's '65 Tradewind Preservation
Hi Everyone,
I'm not new to the forum but I am new to owning an Airstream! I've been lurking for years but just bought a '65 Tradewind double a few weeks ago. I've been working my way through the camper making lists of things to do but haven't started any updates yet.
I'm starting this thread so I can plan out and prioritize work as well as document the work for others to see.
I made two short videos walking around and through the camper. Is it ok to post links to YT videos up here so others can see what I'm working on? If not, I'll take some still pics and put them up here shortly. (there are pics up on my profile page as well)
-Swamperdog
swamperdog is offline   Reply With Quote
Old 05-20-2019, 08:39 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
You can post links to videos, web pages, etc. Not a problem usually.
You might find this post by a member of the airforums site team useful. Far as I know it is still correct.
http://www.airforums.com/forums/f138...ics-44928.html
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-20-2019, 05:16 PM   #3
1965 24' Tradewind
Middle , Georgia
Initial Checklist
I've been working on a checklist for items to work on for the camper. My highest priority items are as follows:
1. Full exterior inspection searching for any missing caulking or seals that might leak. Focus on making sure the camper is properly sealed and not necessarily by replacing all seals and gaskets.
2. Full electrical inspection and testing. Verify what parts of the electrical system are working and what will need updating.
Those are my top options. Now here is my list broken out by exterior vs. interior vs. drivetrain but not necessarily in priority order.
I would appreciate any comments or feedback on the list including anything you think I am missing
Exterior
Main door seal replacement
Main door hold open?
Screen door seal replacement
Screen door second latch and adjustments
Sand and paint tongue
Clean Airstream logo with mineral spirits
Propane system - Exterior inspection
Inspect plexiglass windows
Replace window gaskets and seals all the way around
Exterior access panel doors - open and replace locks with matching keyed locks
Replace rear tail light housings
Replace rear tail lights with LEDs
Replace and seal marker lights with LEDs
Remove, inspect and seal rear one stop service panel
Rear storage lid missing part of hinge and latches
Replace license plate light with LED
Sort out exterior exposed plumbing/drains
Sort out hot water heater exposed externally
Sort out squirrel heater - exposed externally
Replace or renovate exhaust fan vent on exterior
test front and side levels
test and clean manual crank jack
Interior
Sort out original light fixtures testing voltage
Replace fixture bulbs with LEDs
Replace missing light fixture towards rear
Come up with plan for all water damage at cabinet bases
Come up with folding table plan for missing folding table
Sort out additional seating in front (folding chair)
Clean and test range (sort out propane first)
Clean and test range hood fan
Replace backsplash with stick on aluminum?
Replace screening in screens and make screen frames for windows without screeens
Check new skylight for leaks
Sort out and re-rivet new ceiling vents
Test new AC system
Burned interior of upper cabinets. Replace water damaged floors in upper cabinets
Sort out sink and plumbing. New gray tank?
Clean all gaucho cushions. Repair rips
Sort out leak in bathroom and inspect floor under flooring
Systems
Sort out electrical, AC/DC converter, battery, charging and 120v/12v electrical system.
Sort out propane system and figure out connection at old fridge location
Drivetrain
Have axles, hubs and brakes inspected
Repack bearings
Replace shocks
ID:	341257   Click image for larger version
ID:	341259   Click image for larger version
Old 05-20-2019, 06:04 PM   #4
1965 24' Tradewind
Middle , Georgia
Interior Pics
Here are the interior pics. I waited too long to edit the last post so I'm adding them here.
-Swamperdog
ID:	341262   Click image for larger version
ID:	341264   Click image for larger version
Old 05-21-2019, 07:23 AM   #5
1965 24' Tradewind
Middle , Georgia
walkthru/walkaround videos
Here are the videos of the camper inside and out. I'm going to start on some of the small projects while I'm planning out the bigger ones.
Please ignore my comment about being built in Decatur, AL. I meant to say "purchased!"
Exterior: Walkaround
Interior: Walkthru
Old 05-22-2019, 06:14 PM   #6
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Your 65 twind looks very nice inside and out. We had one a couple years ago and sold it as we have two others.
With regard to your rear tail lights those are 1965 year only. Not the best idea they ever had and were not repeated in any other year. You may want to hang on to them and fix them with fiberglass from the outside as best you can for now. When I find them I will post some pictures here on other people's examples of what they have done with theirs. You can only get to the inside I'd them by taking the interior skins off. Not easy to work on so maybe hang on to what you have until you can find something else.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-22-2019, 07:17 PM   #7
1966 22' Safari
Fredericksburg , Texas
Great “to do” list. With older propane lines and systems, do get a LP Gas detector. Good luck and looking forward to your renovation progress reports.
Bubba L is online now   Reply With Quote
Old 05-23-2019, 08:18 AM   #8
1965 24' Tradewind
Middle , Georgia
Thanks Hittenstiehl. I saw that VTS lists some better replacements for the '65 tail lights but they are sold out. I haven't called yet to see if that is permanent status.
I really like the layout of the Tradewind double. Mine is reversed with the mid gaucho on the galley side. I guess there were lots of custom options like that.
Old 05-23-2019, 08:20 AM   #9
1965 24' Tradewind
Middle , Georgia
Thanks Bubba. That's a really good idea. I should probably do that before I start inspecting the lines. I saw in another post where someone had a combo carbon monoxide/LPG detector. I think I'm going to look for one of those.
- Swamperdog
Old 05-23-2019, 09:00 AM   #10
1966 22' Safari
We have the combo plug in with a battery backup in both our trailers. Also a small smoke detector.
Old 05-23-2019, 09:04 AM   #11
1962 28' Ambassador
Mesa , Arizona
Yes, you are correct, VTS has just had those reproduced / manufactured and they look fantastic. You are right make sure you snag a pair of those before you take your old ones out.
Our trailer was also a double and we loved it, it's a very popular one.
Hittenstiehl
Old 05-23-2019, 09:30 AM   #12
1965 24' Tradewind
Middle , Georgia
I just searched on eBay and Amazon and saw that most of the detectors with LPG are plug in. I did find a wand that runs on AA batteries. I may start with the wand so I can check the whole system easily and then use the plug in for general monitoring. (along with the soapy water test)
Old 05-23-2019, 07:07 PM   #13
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi swamperdog, welcome from Colorado: I happened on your 65 Trade Wind thread and would like to follow along.
I had a 66 Trade Wind that I did extensive work to. It was a twin bed layout, but otherwise very similar, except for the Corning glass windows used from 66 to 68. The 67's had significant changes to the bath. The mid sixties trailers are very desirable vintage trailers.
I installed new axles, new waste water tanks, new bath, new electrical system, new fresh water plumbing, new floor covering, new appliances and on and on. I enjoy working on these vintage Airstreams.
Here are some photos of my 66 just before I sold it. I now have a 75 Overlander that I'm working on.
David
Name:	1708 Sale Front Shade (Small).JPG
ID:	341476   Click image for larger version
Name:	1708 Sale Twins 1 (Small).JPG
Name:	1708 Sale Gaucho 1 (Small).JPG
ID:	341478   Click image for larger version
Name:	1708 Sale Rear Shade-800x600.JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 06-01-2019, 06:08 AM   #14
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Hey Swamperdog, welcome to the insanity. You did a very comprehensive inspection and work plan. My compliments.
I just replaced my marker lights with led ones from VTS. They are great. I should not have waited so long to replace these.
You probably should plan on axle and brake replacement sometime.
I have a renovation thread- Dan’s 66 Tradewind Improvements.
Dan
Preservation, refurbishment, modernization walleye001 General Repair Forum 3 03-12-2016 08:24 PM
Preservation mwilliamsmd Winterizing, Storage, Carports & Covers 1 04-11-2014 03:15 AM
will a '67 Tradewind door fit a '62 Tradewind? scoxx30 Doors & Locks 4 11-21-2005 11:58 AM
Interesting Article on Wood Preservation and Rot Prevention Pick Repairing/Replacing Floor &/or Frame 0 07-29-2005 11:34 AM
