Old 01-29-2017, 01:36 PM   #1
Airstreamin' Angel
AngelStreamn's Avatar
1963 24' Tradewind
Need help locating fuse box
I am trying to locate the fuse box for my 1963 Tradewind 24 ft. I seem to have blown a fuse. I lost electrical power to the midsection of my trailer that runs my refrigerator my AC overhead lights over the kitchen sink and bedroom area. Lights are still working in the front end of the trailer and in the bathroom in the back area of the trailer. Any ideas where the fuse box might be?
AngelStreamn is offline   Reply With Quote
Old 01-29-2017, 01:42 PM   #2
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
In my 73 Argosy that would be one of the two 110 breakers that are located in the bathroom closet.
1973Argosy is offline   Reply With Quote
Old 01-29-2017, 01:45 PM   #3
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
After reading your post again you may have also blown a DC fuse which should be located in a compartment on the front of your univolt. Should be a panel that folds down on the front of the univolt box.
Old 01-29-2017, 01:45 PM   #4
Airstreamin' Angel
1963 24' Tradewind
Oh goodness...I don't have a bathroom closet
Old 01-29-2017, 01:47 PM   #5
Airstreamin' Angel
1963 24' Tradewind
This may be a dumb question but what is a univolt?
Old 01-29-2017, 01:48 PM   #6
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
If you find where your shore power is on the exterior on the trailer it should give you a good idea of where to look on the interior of the trailer. Generally the 110 breakers and univolt aren't far from where the shore power come in from. Hope this helps.
Old 01-29-2017, 01:53 PM   #7
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Univolt or charge controller/convertor. It is what takes the 110 power and turns it to DC power to charge your batteries and run the DC portion of your trailer. Your lights, furnace, water pump, and fans all run on DC power like a car, your fridge, ac, tvs, microwave all run on ac power like your home.
Old 01-29-2017, 02:13 PM   #8
Airstreamin' Angel
1963 24' Tradewind
I just discovered the real problem as to why I lost shore power to The midsection of my trailer Click image for larger version
Name:	ImageUploadedByAirstream Forums1485724338.741609.jpg
ID:	278907Click image for larger version
Name:	ImageUploadedByAirstream Forums1485724359.659725.jpg
ID:	278908Click image for larger version
Name:	ImageUploadedByAirstream Forums1485724381.277356.jpg
Old 01-29-2017, 02:38 PM   #9
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Ouch!
Old 01-30-2017, 10:42 AM   #10
Airstreamin' Angel
1963 24' Tradewind
Airstream service department here in Austin basically said the park here must have lost power which is what fried my electrical plug and cord. 😔
I need to replace both. The service department is backlogged two weeks. Ouch!
Old 01-30-2017, 01:00 PM   #11
Vintage Only
1966 26' Overlander
1981 31' Excella Limited
1964 22' Safari
Ramona , California
Good luck with the repair. However I don't see how having the park loose power would result in this type of damage. Likely it was a short in the plug or socket.
kenfconnor is offline   Reply With Quote
Old 01-30-2017, 01:35 PM   #12
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Concur; or possible loose 'spades' causing overheat.
Look after your equipment, it will look after you.
MelGoddard is offline   Reply With Quote
Old 01-30-2017, 03:08 PM   #13
Airstreamin' Angel
1963 24' Tradewind
I was able to get an independent RV tech out that Airstream recommended. The wiring coming from the breaker box was 12 gauge which according to the tech should not be used for more than 20 AMPS . My trailer is 30 AMPS. He said it was only a matter of time before the 12 gauge would overload and heat up. And that's what happened. So he is re-wiring to carry 30 AMPS. It apparently has been running this way for years. The previous owners were apparently lucky according to the RV tech.
Old 01-30-2017, 05:49 PM   #14
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Glad to hear you are getting everything back together and really glad the damage was as light as it was. That one could have turned out much worse. You might consider asking the rv tech to look over the rest of your systems while he is there. Stay with him while he is looking things over and ask questions on anything you may not be sure of.
Old 01-30-2017, 05:54 PM   #15
Airstreamin' Angel
1963 24' Tradewind
When I mentioned to the RV text that I was glad it didn't start a fire and that it could've been much worse his comment was " aluminum doesn't burn very well so it probably wouldn't of started a fire" .
He did look over my other systems and said all is well.
Thank you so much for all your support while I was trying to figure this out.
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Need help locating fuse on Armstrong TR21-12 air conditioner Hillbilly75 Interior Restoration Forum 28 07-02-2014 08:17 AM
Pls help with locating fuse box brainatplay Sprinter and B-van Forum 2 10-18-2013 10:19 PM
Need help locating VIN? Spirit 1970-79 Tradewind 6 08-29-2012 10:42 AM
Need some help locating a light fixture bake315 Lights - Interior & Exterior 2 05-19-2008 09:51 PM
