Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 10-22-2006, 08:59 AM   #43
richard77
Richard77
richard77's Avatar
Profile:  1974 31' Sovereign
1959 24' Tradewind
eckert , Colorado
Super Job!! That looks brand new!
The entire AS looks Beautiful .
Richard
richard77 is offline   Reply With Quote
Old 10-22-2006, 09:21 AM   #44
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Originally Posted by sequoiacoast
I have a new refer, that is slightly larger than the old, and needs a 12 volt wire run to it in order to operate the electronic switch for the propane/elec option. My question is, will I be able to add a wire for this - can it come from the control panel (right next door) or will it come from the converter/battery area in back??
You will need to figure out how much current the new Refer will draw. Once you have established this, check what amperage fuse is feeding the place you want to get the power from, will it handle the additional load? Also check the wire size, will it handle the additional current draw. 12awg. = 20amps, 14awg. = 15amps, 18awg. = 10amps.
With all this being said, install an appropriately sized fuse in line for the refer feed and it should not be a problem.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 10-22-2006, 03:17 PM   #45
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
If your new fridge is a three way (which I doubt) the wire would have to run all the way back to the battery on a heavy gauge wire, like #10.
Your's is probably just for the control board so you could get away with finding power close by. I ended getting 12vdc from a power cigarette lighter port that was near by.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 10-22-2006, 05:15 PM   #46
sequoiacoast
sequoiacoast's Avatar
Profile:  1968 24' Tradewind
Eureka , California
Yes, that's what I wanted to hear !
Thanks.
sequoiacoast is offline   Reply With Quote
Old 10-23-2006, 08:30 AM   #47
Gen Disarray
Gen Disarray's Avatar
Lawton , Oklahoma
I ran one from the control pannel for my Dometic. It has worked fine for a year now.
Rodney
Experience hath shewn, that even under the best forms of government those entrusted with power have, in time, and by slow operations, perverted it into tyranny. - Thomas Jefferson
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is online now   Reply With Quote
Old 10-23-2006, 09:12 AM   #48
sequoiacoast
Eureka , California
Hey while I've got you here , I have 2 switches by the door, one I remember operates the exterior light but the other one is for ????
Old 10-23-2006, 09:22 AM   #49
Gen Disarray
Lawton , Oklahoma
Not sure how yours is wired, in mine if you turn on the overhead in the galley area, you can control it using the second switch near the door. That way you dont have to stumble around a dark camper looking for a light switch. Did that make any sense?
Rodney
Old 10-23-2006, 09:27 AM   #50
tbrom
tbrom's Avatar
Profile:  1965 28' Ambassador
NewCastle , Pennsylvania
In my 65 the second switch is for the pump on the fresh water tank.
Tbrom
tbrom is offline   Reply With Quote
Old 10-23-2006, 10:25 AM   #51
sequoiacoast
Eureka , California
New Windows and Gaskets
I removed the window, according to the directions on VTS's website. It had been put in by some PO (not mom's BF-he thought it was a privacy window ). The trim was on it, but badly crimped and wrinkled, so I ordered new trim from Inland. - [Which did NOT fit the glass. It must only fit lexan.]
After the window was out, I removed the old gasket with a putty knife. Next I put a wire brush attachment on my drill and in minutes all traces of old glue were gone. (Watch out for long sleeves and a corded drill !) Then I cleaned the area with mineral spirits and only 9 months later I installed new gasket and .... the WINDOW!!
ID:	27364  Click image for larger version
Old 10-23-2006, 10:27 AM   #52
sequoiacoast
Eureka , California
Yes! That would be great. I was thinking it may have been the pump, like Tbrom said. I guess when all electric is back- I'll find out!
Old 10-23-2006, 10:30 AM   #53
sequoiacoast
Eureka , California
I am still in the process of having new aluminum trim made, but I needed the window clips on. So I put ribbon in between the clips and the glass (like they do when you need to pop batteries out) - that way it will be less scary when I take them off to install new trim!
Old 10-23-2006, 10:35 AM   #54
Gen Disarray
Lawton , Oklahoma
The pump should be on the control panel next to the gauges for the fresh water and black water tanks.
Rodney
Old 10-23-2006, 10:37 AM   #55
sequoiacoast
Eureka , California
New Rear Window
The rear window was also plexi-glass... that you couldn't see through. It managed to keep some rain out, and it wasn't as ugly as the orange one, so I left that one in until a few weeks ago. It was actually the first window I replaced. I only paid $48 for it and got it locally so I decided to try my luck on that one!
I got the window all ready to install, called my big boy out to hold it while I pressed the glass bar onto the double-sided tape and screwed it into place. It was so simple, and exciting, that I lost sleep over it and did the curved one the next day!
Befores and afters:
ID:	27367  Click image for larger version
Old 10-23-2006, 10:46 AM   #56
sequoiacoast
Eureka , California
New Dinette:
I was trying to keep the original water tank in use, but it was quite funky, so I filled it with MANY different things... bleach water, soap, and even mouthwash . It was just too green... and we decided to do a U-shaped dinette, so I bought a new tank off eBay (60$). The new one is larger and different in shape so it can fit in the same place and still fit under a seat for the new dinette.
The only problem was the exterior tank fill need to be moved up. I didn't want an ugly patch so I came up with this instead. Two matching reflectors- make it look planned.
And the pics show my newly painted tongue!
ID:	27370  Click image for larger version
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
67 Tradewind owners manuel BentEar 1959-69 Tradewind
