Old 08-30-2012, 08:59 PM   #29
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
This is the old pressure system , right. What,I have is a big tank that looks like it is off of a air compresser and under the sink is a air compresser.
jbev59 is offline   Reply With Quote
Old 08-30-2012, 09:00 PM   #30
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
Here is the fresh water fill
Old 08-31-2012, 04:48 AM   #31
Baltimore , Maryland
The air pump pressurizes the system and pushes the water through the lines. You can also pressurize it by pumping it up through that valve on the cap. You will quickly know if you have a leak....
Old 09-02-2012, 04:40 PM   #32
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
My biggest question is so I try to get press water system working or do I replace it with updated tank and pump. I have 2 places to fix in plumbing that I know of. Should I replace copper with plastic limes?
Old 09-02-2012, 04:50 PM   #33
Central , Mississippi
Here's what I would do...
Chunk the nasty ole' metal tank. Get a plastic one and replumb with pex and a modern pump.
Your milage may vary...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-02-2012, 04:57 PM   #34
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Replace. Your need to do it. That old plumbing needs to go.
ddstech is offline   Reply With Quote
Old 09-02-2012, 07:50 PM   #35
reinergirl's Avatar
Hollis , New Hampshire
That old metal tank is heavy and filled with ???? Replace with a plastic one and lighten the load enough to add more amenities you'd enjoy!
reinergirl is offline   Reply With Quote
Old 09-02-2012, 09:29 PM   #36
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
Before you remove the metal tank you should check it out. My 63 Tradewind still has its original metal tank and it is good as new. Fill it with water and add some bleach to clean it. Remove the cap under the trailer to drain it. Repeat if junk comes out.
Of course, if the tank leaks then all bets are off.
My tank doesn't leak, and no rust, crud, or junk ever comes out the tap. The water tastes fresh. I did remove the old pressure pump and just converted it to the new style water pump.
Good luck
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 09-03-2012, 09:23 AM   #37
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
That's kinda my thinking , I will check the tank replace copper with pex . Here is a pic of a spot I polished.
Old 09-03-2012, 09:34 AM   #38
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
I have the original jack plate, dolly wheel and wheel choks. I will get some pics today and post them.
Old 09-03-2012, 05:54 PM   #39
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
Here are the pics of dolly wheel and jack plate.
ID:	167390   Click image for larger version
Old 09-03-2012, 05:56 PM   #40
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
We worked on peeling up floor tiles
ID:	167392   Click image for larger version
Old 09-03-2012, 06:24 PM   #41
Originally Posted by jbev59 View Post
... Here is a pic of a spot I polished.
Oh No...you went and started down THAT slippery slope...
Old 09-07-2012, 06:56 AM   #42
jbev59's Avatar
1963 24' Tradewind
grove city , Ohio
We are still working on peeling up floor tiles, slow going. I think I might start on plumbing this weekend.
