With my first rally hurling down on me, I've been obsessing more than usual
. I'll elaborate, in case you've missed the rash of threads I've stared...
First, I started freaking out about my aluminum wiring- too late to replace- so, I instead examined all the outlets for signs of corrosion and to be sure all terminals were tight. They were in great condition, so I am leaving that alone. I saw on the net somewhere that they make an AGFI, similar to the GFCI outlet but it protects against arcing. Does anyone know anything about that?
I have to put the issue to bed, so to speak, lest I decide to use the trailer as a museum because of all the potential hazards of ownership.
Which I have made a list of, while knocking on wood, of course:
Towing-
-tires, running gear, sway conditions, windows falling off....
Going broke-
renovations, many trips to make up for the renovations, diesel
Divorce-
backing up & hitching up, all while yelling to be heard over the diesel (neighbors losing all respect for you)
Aluminum wiring-
Off-gassing
-of newly purchased AGM battery (that you thought didn't need to be vented)
Carbon monoxide poisoning-
Or leaking LP... must worry even though, you'll have detectors- what if they quit working....
There's more, I'm sure, stay tuned for more threads
TRUE STORY:
While waiting for my new Equalizer WD and sway to come UPS, we had to bring the trailer to the plumber's house to set the finish (fixtures) and run the new LP to the appliances.
My husband was towing in MY truck, while I followed in his [nasty] little truck
.... Anyway, as per my head beatings, he was to drive extremely slow and I'm following to see if anything falls off, burns up... or explodes...
All is fine, cell phones are working, and it hits me.... What if I drive behind on every trip so I can monitor the back and sides, and, and...
See what too much information can do??
Margi ball, where are you????? Ebay, I know....
