Old 07-02-2017, 07:56 AM   #1
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence , Kansas
Kitchen Counter Top
Has anyone removed a kitchen counter top? I wondering how it is attached. I am afraid I will tear into it only to fine I have to destroy to cabinet to get it off. I have a 64 Tradewind.
ttbikes is offline   Reply With Quote
Old 07-06-2017, 07:18 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
It is secured with screws. The fun part is finding them, all of them. It might help to post a photo.
I had to remove the counter top in my 66 Tradewind to remove the fridge. I don't remember the screw location, but it was well secured to the cabinet above and below.
Dan
TouringDan is offline   Reply With Quote
Old 07-07-2017, 07:25 AM   #3
1964 24' Tradewind
Lawrence , Kansas
Were the screws from the top under the counter top covering? In my case it appears to be covered with Marmoleum. I do not see any from the top. I am glad to hear the top was not glued. The cabinets are so lightly made I was afraid they would be glued for extra strength. I have not torn into the top because I have a trip planned but will be doing so soon. Thank Dan.
Old 07-07-2017, 07:31 AM   #4
1955 22' Safari
Laredo , Texas
In my 67 they appear to be screwed in from the sides only. On the new ones I am installing, I am screwing down from the top prior to gluing on formica. Very strong but not so easy to remove in the future...
55AS is offline   Reply With Quote
Old 07-07-2017, 09:52 AM   #5
1967 17' Caravel
On my '67 Caravel, I recall the top being fastened to the cabinets from below (through cleats). The thin backsplash was nailed to the side of the wood sub-top and came off with the countertop after some amount of persuasion. For the renovation/restoration, I fabricated a new sub-top and had it covered with stainless steel
David F is offline   Reply With Quote
Old 07-07-2017, 10:25 AM   #6
1964 24' Tradewind
Lawrence , Kansas
I would like stainless steel but my wife is telling me a want Formica.
Old 07-07-2017, 10:29 AM   #7
1955 22' Safari
Laredo , Texas
Personal choice
I put stainless in my last trailer and formica in this one. Both have Pros and Cons. I recommend getting what your wife wants:-)
Old 07-09-2017, 08:15 AM   #8
1964 24' Tradewind
Lawrence , Kansas
Picture made me smile. Just ordered a similar sink and faucet, we have been looking at metal light switch covers and the similar back splash. Wife wants the same shades, and I keep telling her that the Tradewind has 9 windows. Formica, of course, will be used for the counter top. You did a great job!
Old 07-09-2017, 09:02 AM   #9
Mollysdad's Avatar
Formica is so 1970. That stainless top is beautiful.
However, I think the look today is granite. Since that's not possible and the countertops are so small has anyone had new made from Corian?
I followed a thread of a new product (no, not Easy Start) where they did a coating on your old countertops to look like granite.
http://www.miraclemethod.com
Mollysdad is offline   Reply With Quote
Old 12-27-2020, 01:24 PM   #10
1974 27' Overlander
Placerville , California
Laminate Counter Top
So we did some damage to the counter laminated counter top. 1974 Overlander so looks like I am going to have to make one customer or get it made. The side up against the wall looks to be formed up the backsplash so was wondering if anyone has tried to head and for the laminate to match. Very tight and heard laminate will not form that tight. Is this a true laminate(Formica) or did Airstream used something different? I could probably just cut a 2 inch piece the link of the counter glue and nail it to the underside if needed. Any suggestions would be appreciated.
Ron
ronsgto is offline   Reply With Quote
Old 12-27-2020, 04:19 PM   #11
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
There are different grades of plastic laminate with different finishes & thicknesses. "Post-forming laminate" is thinner and can bend tightly - it's made for that exact purpose. It's available in all the same colors as the running lines from most manufacturers. Most millwork shops can help you out with it - it's not really a DIY thing...
The one you are looking for in Formica's line is "Grade 12 HGP". It makes the tight turns at coved countertops.
Shari
Old 12-28-2020, 08:27 AM   #12
1974 27' Overlander
Shari
Thanks much for the info
Ron
1976 Argosy kitchen counter top 28Argosy Cleaning, Stripping & Polishing 9 03-04-2015 08:07 AM
Removal of the kitchen counter top fossil Cabinets, Counter Tops & Furnishings 3 04-11-2006 10:29 AM
Kitchen counter backsplash ideas Safari Tim Cabinets, Counter Tops & Furnishings 13 06-08-2005 03:50 PM
Removing Kitchen counter assembly quality parts Cabinets, Counter Tops & Furnishings 4 12-11-2004 05:47 AM
Re-Laminating Kitchen Counter Pick Cabinets, Counter Tops & Furnishings 4 05-24-2002 07:38 AM
