Old 01-31-2007, 12:20 PM   #1
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
Help With Gaucho Fronts
Well I have no idea how these cabinet fronts are supposed to stay attached to the frame. My only guess is there was something... that is no longer present???
Help!! Here's some photos:
ID:	31630   Click image for larger version
sequoiacoast is offline   Reply With Quote
Old 01-31-2007, 01:03 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Those puppies are totally different than my 71 which has tambour doors on an aluminum frame. I would be interested to find out if they are original or built by a PO.
Old 01-31-2007, 02:46 PM   #3
1968 24' Tradewind
Eureka , California
I'm pretty sure they're original; they were also the same on the front gaucho that I removed. They're cool because they slide back and stay out of the way. The only hardware that was attached to them was the roller/bumper type closure at the bootm. Other than that there's a plastic piece on the top, that may have broken and been the way it attaches?
Old 01-31-2007, 03:00 PM   #4
1968 20' Globetrotter
1955 26' Cruiser Overlander
Bastrop , Texas
Our 68 Safari has a creased plastic-thingy there attached to another piece that slides back. I've heard of people replacing it with a strip of leather or a piano hinge. I'll try to take some good pics tonight (light permitting) while I'm packing for the Texas Vintage Rally. - Jill
Jill and Eric
WBCCI #8689
68 Globetrotter
Overlander Underground (Travel and Restoration Blog)
emo59 is offline   Reply With Quote
Old 01-31-2007, 06:20 PM   #5
Bastrop , Texas
Sequoia - I took some pictures that I hope will help. I put them on my blog so that you can see big pictures without slowing down the loadtime of the forum pages.
Go here:
http://web.mac.com/emott1/iWeb/Site%...%20Fronts.html
hope this helps!
Jill and Eric
WBCCI #8689
68 Globetrotter
Old 01-31-2007, 07:18 PM   #6
1968 24' Tradewind
Eureka , California
Thank you for the pics! That's exactly what's missing on mine !!
So, I see the report/piano hinge deal... with the door front in the down position, am I also seeing more wood on the other side of the hinge? So if you took them out it wood be a door front, hinge, then another piece of wood?
Old 01-31-2007, 09:43 PM   #7
Bastrop , Texas
Yes, think of it like a knee joint. If the outside cabinet front is your lower leg, and your shin is the part you see when the drawer is closed, there is another piece (femur) attached on the other side of the hinge and it has some kind of stop on it, so the door won't slide completely out. The back piece is measured so that it's depth is just enough that the entire cabinet (including back piece of wood) is flush to the front when slid all the way in the top (as if the leg were completely straight.)
Does that make any sense at all? It's the only way I could think to describe it in words.
Jill and Eric
WBCCI #8689
68 Globetrotter
Old 02-01-2007, 08:51 AM   #8
1968 24' Tradewind
Eureka , California
Yes, it makes perfect sense! And I don't think I could have figured it out without asking.. and without your explantion and pictures!
So thank you and I hope it helps others too! Have fun at the rally!!
Old 02-07-2007, 01:31 PM   #9
1968 26' Overlander
Clackamas , Oregon
You'll see at the top of the door is a stip of plastic, this is actually a hinge, a plastic hinge that breaks over time. On the other side was a piece of wood that acts as a guide and slides backwards when you lift up the door and slide it into the channel up above. I left the plastic pieces in place, bought some 3/4" wide aluminum piano hinges, painted them to match the color of the wood, and it works great. You need the wood sliders which "I think" are just a bit wider than the door itself. Regards
pfefferd is offline   Reply With Quote
Old 02-10-2007, 01:54 PM   #10
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
I tried top soo the pohots and my browser said it couldn't find them. Are they still there?
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 02-10-2007, 02:56 PM   #11
1968 24' Tradewind
Eureka , California
I think they're gone- maybe emo59 will post them here? If not I can take a picture of the ones I have and my solution to the missing plastic hinge...
Old 03-25-2007, 08:16 PM   #12
1969 25' Tradewind
Auburn , Alabama
Please do, I have the same problem.
seabornj is offline   Reply With Quote
Old 03-25-2007, 08:41 PM   #13
1968 24' Tradewind
Eureka , California
K- will do, in the AM!
Old 03-26-2007, 04:37 PM   #14
1968 24' Tradewind
Eureka , California
I used a piano hinge and a piece of ply with a scrap block on the top of the rear-most ply to stop the front from being pulled all the way out. The bottom has a roller catch to keep the fronts closed.
Here's pics...
Name:	goucho fronts.jpg
ID:	34642   Click image for larger version
Name:	goucho front hinge.jpg
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
1980 Caravelle -side gaucho needs help!! glacierrunne General Interior Topics 2 06-07-2006 09:17 PM
Poll: Dinette VS Gaucho... robertandjenni Interior Restoration Forum 18 06-26-2003 11:40 AM
Adults Sleeping on Gaucho..is it comfy? cykakris Our Community 11 06-23-2003 05:26 AM
Original Gaucho Foam-Measurements? 74Tradewind General Interior Topics 1 02-20-2003 06:31 AM
