Old 08-22-2017, 07:00 PM   #15
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Glenritas, you have inspired SilverHoot. Thanks for starting this thread and adding the "chapters" of your disassembly. My son has a 69 Globetrotter which had a similar front room and galley. But his is a gaucho and corner wet bath in back. It is a goofy layout. The bathroom is a joke. I have done some major work to his trailer so your 69 Trade Wind looks familiar. I replaced the last 40" of subfloor on my 66 Trade Wind and rebuilt the bath, added holding tanks, new axles and all the rest.
Your thread here will be very interesting. I'm signed up to cheer you along.
David
Old 08-23-2017, 09:05 AM   #16
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Thanks dbj216
Yah as time permits I'll be posting the rest of the story soon .
I also thought the bathroom was a bit odd .
I mean who thought it was a good idea to have the bottom of the tub 4" higher then the floor and a hand held shower head with a shower curtain that only came up to your chest .
And what's with the shag carpet around the toilet ?
What were they thinking ? Oh ya, it was the 60's . What were they smoking ?
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-23-2017, 09:48 AM   #17
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Hey Hoot and Glenritas,
Oh the memories!!
My floor was so bad in the back that I could not even use the old wood for a template. The new floor needs to be perfect so it will all fit back down correctly. I used cardboard and then made a luan template to cut the new plywood. You will have to put the rear floor in in two pieces with the seam over one frame rail. If you put a round-over with a router on the edges that go into the C -Channel it will really help getting the new wood to slide in. Also I coated topped bottom all round the edge with 2 coats of West System epoxy to seal the edges and keep any future leaks from wrecking all my work. The other thing I did was to lay a couple of layers of fiberglass over the floor in the bathroom between the frame rails from the rear edge out to about the door. It was thin and was not visible when the flooring was installed. It really stiffened the floor area in front of the toilet and also gave extra strength about the toilet flange.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-23-2017, 11:34 AM   #18
Glenritas's Avatar
1969 25' Tradewind
68 TWind
Thanks for you input on the floor it will be helpful to anyone reading this thread .
Spoiler alert : Our Tradewind has been on the road Glamping since spring of 2015. It still has a few things to be done to "finish" the interior .
More will be revealed later in this thread .
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 08-23-2017, 11:45 AM   #19
Glenritas's Avatar
1969 25' Tradewind
The great thing about build threads is the info that can be gained by anyone reading it and the info added by others enhancing it.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 08-23-2017, 08:33 PM   #20
fromthegitgo's Avatar
1969 25' Tradewind
Lockport , Illinois
Glenritas,
I have a 69 Tradewind exactly like yours that I am working on restoring. I noticed in post #12 you mentioned that the furnace for your model is a recalled death trap...how do I find out if mine is a death trap also?
I planned on having it checked out and restored along with the fridge and stove/oven...
fromthegitgo is offline   Reply With Quote
Old 08-23-2017, 09:55 PM   #21
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I believe this will help you figure out if you need to upgrade:
http://www.knology.net/~tcwilliams/Furnace.htm
hope that helps!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 08-24-2017, 09:24 AM   #22
Glenritas's Avatar
1969 25' Tradewind
Fromthegitgo
The heater exchanger rusts and gets pin holes . This lets carbon monoxide into the living space thus making it a death trap.
I replaced all the equipment and systems in my trailer with new .
The refer has the craziest system to light it and the unit weighs a lot more the the new units.
Here's a teaser ....
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 08-24-2017, 09:34 AM   #23
Glenritas's Avatar
1969 25' Tradewind
grandsons
Thanks for the link about the recall.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 08-25-2017, 01:13 PM   #24
1969 25' Tradewind
Lockport , Illinois
Glenritas and goransons, Thanks for the extra information. I never would have known about that recall.
Looking forward to following your thread. Especially more so that yours is exactly the same layout and model as mine. I just have the bathroom to remove and then I will start to take out the subfloor.
Old 08-25-2017, 10:36 PM   #25
goransons's Avatar
1963 22' Safari
No problem, always happy to help people not blow up! We upgraded our furnace in our 69 tradewind and used the existing ductwork and thermostat wiring. A small patch on the outside of the trailer was the only thing you could see, and when polished it wasn't very noticeable. We've been very satisfied with the modern Suburban furnaces.
Scott & Megan
Old 08-27-2017, 08:38 PM   #26
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Glenritas
Thanks for the write up and all the photos.
I guess that I am fortunate that I only had to replace less than one foot of flooring compared to the four feet that you had to replace.
I think that using a steel box to support the black tank was a bad idea by Airstream. I removed the rusted out steel box and screwed the black tank flange directly to the bottom of the floor.
I would always replace a 50 year old furnace with a new one- no safety issues with pin holes in the heat exchanger and the new one will be reliable, more efficient and the fan should use less energy.
Dan
Seeking a 19-21 foot project trailer for Food Truck project debbooooo Airstream Classifieds 0 09-06-2016 01:00 PM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
Got a project here on a '68 Tradewind harestream 1959-69 Tradewind 21 04-05-2007 10:10 PM
