Old 05-09-2019, 08:48 PM   #253
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
POWERING THE 12V DC COMPRESSOR FRIDGE
We now travel with a 65 qt 12v dc compressor fridge (Dometic CFX65DZ). This insures that there is always cold beer and ice when the ammonia fridge sometimes has a mind not to stay cold enough in hot weather. The only problem is that it requires about 30 Ah of energy each day. When riding in the bed of the Tundra it is powered from a 12v outlet I installed.Click image for larger version
When we get to where we are camping I have a 12v extension cord to power the fridge from a connection to the 12v and ground terminals in the 7 pin umbilical cord.Click image for larger version
ID:	340279When we are home the Tundra is parked next to the Tradewind and I installed a 12v outlet in the C channel underneath the banana wrap.Click image for larger version
ID:	340280Click image for larger version
ID:	340281The 12v outlet is powered from the 12v panel box using 16 gauge wire with a 10 amp fuse. The peak power consumption is 50 watts. The average power consumption is about 15 watts which results in 30 Ah per day to keep the fridge operating. The sun keeps the fridge cool using two 100 amp portable panels.
DanClick image for larger version
ID:	340282Click image for larger version
Old 05-10-2019, 06:54 AM   #254
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
If you haven’t already done this , try a small computer fan or two in your chimney of your fridge to pull the heat out . We stayed in Az. One summer and tried this and it worked great , even keep the ice cream frozen. Good luck .
Joyflea is offline   Reply With Quote
Old 05-10-2019, 08:58 AM   #255
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Thanks Joyflea. I actually did install 3 computer fans in the chimney. It didn’t seem to make much difference in the fridge performance which really frustrated me and makes no sense. I have a thread on it in the refrigerator section dated September, 2015.
Old 05-10-2019, 03:53 PM   #256
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Dan , is it open on the sides or are you only letting the hot air go through your fans . I was told by an aircraft engineer that you need it open on the sides and not to fill the area with fans . Something to do with a ventures effect . And of coarse to use it as suction . Good luck , know it worked for us . Haven’t tried it on our Airstream we are building right now . Only using two and controlling them with a thermister type thermostat closed at 140 degres .
Old 05-10-2019, 11:12 PM   #257
1970 25' Caravanner
Incline Village , Nevada
Dan. Are you saying your fridge is not cooling correctly? I have a similar fan set up in the chimney only located about 1/2 way down. Makes me nervous if yours isn't working
Jeremy9107 is offline   Reply With Quote
Old 05-11-2019, 05:40 AM   #258
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Joyflea- Yup, all the air is sucked thru the fan opening area. That would be great if providing openings on the side would improve the performance. Doesn’t make any sense to me though. I need to perform a thorough fridge test- one with the fans on then one with them off.
Jeremy- my fridge seems to work inconsistently. It is not clear to me that the fans help the cooling. I need to do a thorough test.
One additional point is that it doesn’t cool very well at all when we are traveling. This again doesn’t make any sense to me. Maybe the traveling lowers the airflow up the chimney hence affects the cooling.
Thanks for all the comments and help.
Dan
Old 06-01-2019, 07:02 AM   #259
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Dan's '66 Tradewind Improvements
MARKER LIGHT REPLACEMENT
Well I have owned this Tradewind for at least 8 years and it is a bit embarrassing that I am just now replacing the marker lights.
There are a total of 10 marker lights, 5 amber in front and 5 red in the rear. There are three lights across the front and rear and then four corner lights. There is only a black (or green) 12v wire going to each marker light. The body is the ground connection.
Airstream’s installation of the three front and rear marker lights was fine- the black wire going through a large hole to the marker light. Here is a photo.Click image for larger version
Now I can’t imagine why not, but Airstream didn’t provide a large hole for the hot wire for the four corner lights. They only provided a 3/16 hole for the 1/8” hot wire with no grommet. I am amazed that after 53 years of travel the hot wire never shorted out on the aluminum shell ground.Click image for larger version
ID:	342192 I made the hole larger (1/2”) and used a grommet to protect the wire.Click image for larger version
ID:	342194Click image for larger version
I ordered led marker lights from VTS. I was a little concerned as there were only two reviews from 2014, one positive and one negative. The negative one said they weren’t bright enough. Baloney, I wouldn’t want them any brighter. I am very happy with the results.Click image for larger version
ID:	342196Click image for larger version
I know- those nice new marker lights would look better on a clean and polished Tradewind.
Dan
Old 06-01-2019, 07:28 AM   #260
1966 22' Safari
Fredericksburg , Texas
Dan, I agree the VTS marker lights are great. We had the same small wire hole. We enlarged it, added grommets and sealed the hole with Parbond. We only have the standard four. They are bright enough to have them on and be noticeable in the daylight while traveling. With all your bright marker lights on, they’ll see you coming. Looks great.
Bubba L is offline   Reply With Quote
Old 06-01-2019, 07:45 AM   #261
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
ROTABROACH- GREAT TOOL FOR YOUR AIRSTREAM TOOLBOX
I learned about the Rotabroach from Airforums, and ordered one from Amazon. I used it to cut the 1/2” holes for the four corner marker lights. It worked great. Glad to have it in the Airstream toolbox.
Dan Click image for larger version
ID:	342204Click image for larger version
Old 06-01-2019, 09:47 AM   #262
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
PLUMBING VENT CAP REPLACEMENT- Just like my marker lights, I should have replaced my plumbing vent caps years ago. They were all original and in rough shape. Click image for larger version
ID:	342214I got the replacements from VTS and they worked perfectly. Good for another 53 years. Now if you noticed, my own QA failed me. I forgot to insert the vent screen in this vent before installing the new vent cap. I don’t think it is that necessary. The other two vents have screening. We will see if it makes a difference.
DanATTACH]342211[/ATTACH]
Old 06-01-2019, 11:59 AM   #263
Long Island , New York
Great to learn about this tool . . . thanks.
Peter
OTRA15 is online now   Reply With Quote
Old 06-01-2019, 01:32 PM   #264
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
RANGE VENT FAN CAP REPLACEMENT- Since I replaced the marker lights and the plumbing vent caps I certainly couldn’t leave the old range vent fan cap. I don’t believe it was original, at least I am sure the caulking job was not original. It was silicone and looked like it was applied by a 5 year old.Click image for larger version
The old vent cap was secured with 3/16” steel pop rivets, a real pain to remove. I used 5/32” Olympic rivets to secure the plumbing vent caps and for the new range vent fan cap.
Old 06-01-2019, 07:23 PM   #265
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi: I too replaced my plumbing vents and range hood vents with VTS parts on my 66 Trade Wind. I have evidence the galley vent cap was leaking for some time. Your Trade Wind is now a better trailer with the work you did.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 06-08-2019, 08:44 PM   #266
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
NEW CONVERTER FOR LITHIUM BATTERIES. Since I installed lithium batteries, I knew that I needed to get a new converter (battery charger). I called Randy at Best Converters to order one and he recommended the Boondocker brand. One reason was that it has a 3 year warranty versus 2 years for the Progressive Dynamics converter, so I saw no reason not to go with the Boondocker brand. I went ahead and ordered the 70 amp model. When it arrived and I plugged it in I realized I made a mistake. It was my own fault. I didn’t do my homework. The converter required more that 1,000 watts to operate. This was a problem because most of the time when I am using the converter to charge my batteries, I will be running it off my generator which is only 1,000 watts. I had to return the converter and get a smaller model. I also decided to stick with Progressive dynamics, since I have had a 45 amp 9200 series converter for 8 years with no problems. It is also made in the U.S. (my home state of Michigan). The 9100 series, 45 amp model is made for lithium batteries only and is the same size as my old PD converter so installation was easy peasy (see photo).Click image for larger version
After I installed the converter I decided to see how long it would take to charge my lithium batteries. They were down to 12% after camping for 5 days on a shady site (no solar). It took about 4 hours to bring the lithium batteries up to 100% charge. I am more than happy with the time required to fully charge the lithium batteries.
Dan
1963 Tradewind Original Wheel & Tire size?? BurritoWagon 1959-69 Tradewind 20 02-08-2012 02:27 PM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
1961 Tradewind Custom dorchstream Member Introductions 5 05-07-2011 08:51 AM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
uh, oops. original Tradewind dinette design? SpaceEgg 1959-69 Tradewind 4 01-21-2011 08:54 AM
