Old 02-28-2019, 08:22 PM   #421
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Originally Posted by Joyflea View Post
The White looks great . But I could not get any info on the sinks . Keep up the good work . Blue
Thanks for trying.
Slats is offline   Reply With Quote
Old 02-28-2019, 08:28 PM   #422
Slats's Avatar
1966 24' Tradewind
Originally Posted by TouringDan View Post
Slats
Looks great! I like it too. Are your cabinets going to be wood colored or painted?
Dan
Thanks. As for cabinets, I haven't thought that far ahead, other than vague notions of landlord white with a blue Corian countertop. Still toying with Tuscan hues, as well.
Old 03-01-2019, 01:36 PM   #423
Slats's Avatar
1966 24' Tradewind
..... but here is a picture of the intersection of our kitchen countertop, backsplash and appliance hutch door, to give you an idea of our appreciation of color.
Name:	190301 kitchen colors.jpg
Old 03-01-2019, 02:47 PM   #424
1970 25' Caravanner
Incline Village , Nevada
Slats, looking great.
I sure do miss those flying metal projectiles from the grinder brush. If you ever want the pants scared off of you, YouTube videos of grinder injuries. When a grinder project comes up now, I just invite a buddy over and offer for him to do it!
Jeremy9107 is offline   Reply With Quote
Old 03-01-2019, 03:20 PM   #425
Slats's Avatar
1966 24' Tradewind
Life's scars
Gosh, I had almost forgotten about that brush with death. The scar is now only barely perceptible. Less so, for sure, than the ones that remain from my 1977 MGB sports car crash. An the 1971 head-on highway crash of my Triumph 650 motorcycle. The Tradewind is a safer pursuit, for sure. I think.
Old 03-02-2019, 06:45 PM   #426
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Oh so many ways to get hurt. Humans are like water balloons with a few sticks inside. Not very strong against steel, rock, fire, water, or chemicals. My last crash was in my 67 MGB 48 years ago. A fender bender. I haven't crashed since. Knock, knock, knock.
Work safe everyone.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 03-09-2019, 04:15 PM   #427
Slats's Avatar
1966 24' Tradewind
using grey water to flush toilet
After I got my mind of off past injuries, I started thinking of future ways to create mayhem and my mind somehow drifted to toilets.
Here's my thought: instead of using perfectly good water from the fresh water tank to flush the toilet, how about hooking up a pump to run a line from the grey water tank to the toilet? Or am I crazy? Or maybe just mildly demented?
Old 03-09-2019, 04:18 PM   #428
Slats's Avatar
1966 24' Tradewind
Well, I should have googled my thought first. There is a ton of stuff out there about doing just that.
Old 03-09-2019, 06:54 PM   #429
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Dale and Terry get a '66 Tradewind
Slats
I am so glad you mentioned this. I like your idea. As you know we have a porta potty. It holds four gallons of fresh water for flushing. After this supply of water is all used, from now on I will fill the porta potty with gray water instead of fresh water. This will extend our time before we need to dump the gray water. In fact, in our case no pump is needed. I will just fill a container from my gray water and carry it inside the Tradewind to fill the porta potty reservoir. Thanks Slats!
Dan
Old 03-09-2019, 07:45 PM   #430
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well, there goes your dreams of riches with a patent application.
Actually, people in Japan are so efficient with water and everything else. Wash water used as toilet water is common.
These 60s trailers had a grey drain to the back of the trailer. Maybe you can rig a pump and strainer from the grey tank to pressurized the toilet inlet line.
Your not crazy after all.
David
WBCCI #8607
VAC Region 11
Old 03-09-2019, 08:30 PM   #431
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Slats
Dan
Maybe already suggested; been there done that; I suggest you swap the porta potty for a Natures Head. Both require no plumbing and I am 1000 times happier with my NH than the porta potty.
FC7039 is offline   Reply With Quote
Old 03-09-2019, 10:19 PM   #432
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Thank you for the suggestion. We considered a composting toilet but the Curve porta potty is a much better solution for us for the following reasons:
- it fits the console better than the NH.
- it weighs less than 10 lbs.
- it costs less than $150.
- it is easily removable so I can get to other stuff under the console.
- we only pea in it. You have to remove urine from your NH just like we need to remove it from our Curve.
- most importantly, after making this decision over 5 years ago we are happy using the Curve.
Dan
Old 03-13-2019, 08:11 PM   #433
Slats's Avatar
1966 24' Tradewind
overhead kitchen cabinet day
Moving on from toilets to kitchen cabinets, I rehabbed my water-leak-damaged kitchen cabinet and range hood today. It is nice to move stuff from the pile against the wall of the building back into the Tradewind. The last picture is the bead that goes between the cabinet and the bedroom wall (and in between other pieces as well). What is it called, where can I get replacement material and do I really need it?
Name:	190312 kitchen cabinet damage.jpg
ID:	335603   Click image for larger version
Name:	190312 kitchen cabinet damage 2.jpg
Name:	190312 kitchen cabinet with range hood.jpg
ID:	335605   Click image for larger version
Name:	190312 kitchen cabinet with doors.jpg
Name:	190312 kitchen cabinet bottom view.jpg
ID:	335607   Click image for larger version
Name:	190312 cabinet rope 2.jpg
Old 03-13-2019, 08:15 PM   #434
Slats's Avatar
1966 24' Tradewind
Here's a better picture of the bead stuff.
Name:	190312 cabinet rope.JPG
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 03:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 08:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 07:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 12:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 10:01 PM
