Old 07-15-2015, 07:15 PM   #29
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Caravel in background of picture # 3
You can see the next project in the background of that 3rd picture. Right now it is stored in a temporary enclosure to keep it dry as it leaks like a seive... it is also full of car parts.
Chuck
cwbiii is offline   Reply With Quote
Old 07-20-2015, 06:02 PM   #30
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Got all the subfloor off and dropped front half of belly pan yesterday. Pulled out the black waste tank (which was white with "4/22/66" written in black magic marker on top). Will need some intensive tutoring on replacing the black tank and adding a grey tank. Any suggestions for how to narrow my search terms to find posts specific to this?
Slats is offline   Reply With Quote
Old 07-22-2015, 05:51 PM   #31
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Kansas City Slats,
Black and gray tank selection and configuration is a major project. The little black tank in our Trade Wind is totally inadequate in my view. Heck, it is only 3" deep at best. Way too shallow for effective draining of the tank. But a larger tank means moving the toilet, or rigging an above floor tank. I mounted a larger tank between the frame rails, but I had to move the toilet between the frame rails also. A gray water tank can go many places between the frame rails as drain inputs to the gray tank are inch and a half pipe.
I used Inca Plastics in California for my tanks. They have a huge on line catalog. I thumbed through the catalog until I found a tank that would fit my locations. The tanks have a molded in shoulder so I could hang the tanks from angle irons. The tanks are about 52" long, 17" wide, and have 4" above the shoulder, and 5" below the shoulder. Inca also sells these neat grommet fittings that allow easy connections of the toilet, drain lines, and vent lines.
The size of the tanks allowed me to route a below floor flex heat duct to the bathroom. The original Trade Wind had cold air return ducts under the subfloor. I elected to "reverse the air flow" and route heat from below, and cold air return above the floor. Running a heat duct to the bathroom would take away a lot of storage room under the bed. And we Minnesotans like warm bathrooms!
Inca served me will. Two 25 gallon tanks, 7 grommet connectors and shipping was about $600.
David
Name:	1404 Waste Tanks Installed.jpg
ID:	243643   Click image for larger version
Name:	1404 Waste Tanks See Level Senders.jpg
Name:	1404 Waste Tanks Rubber Mounting Rail Interface.jpg
ID:	243645   Click image for larger version
Name:	1311 Tank Black Removed.jpg
Old 08-02-2015, 09:05 PM   #32
Slats's Avatar
1966 24' Tradewind
Thanks for the help. Ready to take to sandblaster and then welder. Got the axle bracket bolts loose after 3 consecutive weekends of squirting them with PB Blaster.
Old 08-03-2015, 04:21 PM   #33
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Old bolts are difficult to work with. Thank goodness for penetrating oil. It helps. I finally got my axle bolts loose, and then I found the rear one was trapped by the swing arm. I had to hack saw the head off to get it out. Always something with these old Airstreams.
You mentioned adding new black and gray tanks to your Trade Wind. The tanks I purchased from Inca Plastics required me to fabricate a "tank cover" to protect them, and to keep them warm. Some vintage Airstream enthusiasts don't like anything hanging below the frame rails. It does take away ground clearance. But I think I am okay with my new axles. I can run a string from the rear tire to ground contact point to the frame skid angles. The pan clears that straight line. So I will "hit the skids" before I hit the pan.
Soon you will have a clean, solid frame to work with. Then you get to paint the thing.
David
Old 08-03-2015, 08:38 PM   #34
Slats's Avatar
1966 24' Tradewind
Thanks. How many inches lower than the belly pan do they sit?
Old 08-03-2015, 11:49 PM   #35
1968 24' Tradewind
1967 17' Caravel
Tank Depot...
I bought mine from Tank Depot, two 35 gal that I had to alter the frame to make them fit... not the easiest job but quite possible when you are doing a shell off restoration. My 24' unit has these, the rear unit (black) fits just between the rails. The gray tank is in front of this and it runs front to back and almost butts against the rear-rear axle There is a channel between the 2 that is about 10-12" wide for the drains to run to the sewer connection. I built enclosed and insulated boxes for the tanks to sit in and then I support the whole mess with a framework that allows me to access and drop the tanks if necessary. I recently tested everything and I appear to have a leak in the black tank when it is overfull. This is likely one of the 2 seals, toilet or vent. I plan to pull the toilet and RTV the seal before I put it back in. I will do the same to the black vent but it is harder to access. This should seal the tank from leaking.
The gray was perfect, I was able to fill the tub with no sign of leaks anywhere.
Nearing time for its maiden voyage... I just built my own fans to fit in the standard 1' vents. They came out pretty nice, I will post the 2nd unit I finish... as the first is already in. It has great airflow but the motor is a bit whiney... I'm going to look for a quieter motor as an upgrade. I used a PWM speed control and that works great. I can adjust it to run slower which is quieter and uses less energy. It turned out so great that I'm considering making a bunch of them and selling them for reasonable price.
Similar to a fantastic fan but much simpler to install since you don't have to cut out those neat old vents... it just slides inside with a minimum of alteration. The first unit was pretty labor intensive but I figured out a way to make the hardest part (the aluminum sheet metal that everything attaches to) a lot simpler with a small investment in a couple of dedicated power tools. That reduces the labor significantly and makes it possible to make these in reasonably small quantities (50-100) and still have it be a profitable venture. I figure that there is probably a total market for about a thousand of these so it has to remain a garage project to be viable. If I can identify a quieter motor then it will be perfect. I have an original unit in one of my vents to compare it to and it is quieter as a fan than the original and moves more air for the same energy cost (60-80w).
Chuck
Old 08-04-2015, 06:47 PM   #36
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My tank pan is 5" below the frame rails. The ground clearance is about the same as my 86 Limited.
I fitted the standard 22 degree starting angle with my new axles. I could have opted for a higher starting angle, and thus more ground clearance. But I rarely travel rugged campsites or steep angle entrance ramps to fuel stations.
I can now post a picture as uploading was off line for a couple of days.
Sounds like Chuck has a fantastic vent design.
David
Name:	1406 Waste Tanks Pan Insulated.jpg
ID:	244588   Click image for larger version
Name:	1412 Waste Tank Valve Cover 1.jpg
Old 08-05-2015, 07:32 AM   #37
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Chuck
are there weight issues on 70G of tanks ?
timhortons is offline   Reply With Quote
Old 08-06-2015, 08:41 PM   #38
Slats's Avatar
1966 24' Tradewind
David
So David, which frame rails? Here are some pics, the first for the fun of it, because the shell looks like it is floating. The second, the frame, is for you to pinpoint for me where the tanks go, if you would be so kind.
ID:	244770   Click image for larger version
Old 08-06-2015, 09:54 PM   #39
1968 24' Tradewind
1967 17' Caravel
70 gal...
It adds a bit of weight, but I've had both tanks full with no propane tanks mounted on the front or water in the fresh water tank and it still has more hitch weight than I can lift. 70 gal is about 500 lbs if both are full. I used heavy duty axles (3500 lbs ea) when I replaced them, the originals were rated at 2500 lbs. The tanks are mounted relatively close to the axles and I beefed up the frame to carry the load so I don't expect any problems to occur... but Murphy likes to stick his fingers into things... so time will tell if I've done this right.
100 gal (700 lb) is the full water load possible with all 3 tanks full... not a likely scenario... at least for on the road.
If I remember correctly the trailer weighed in at about 3800 lb (empty) in stock configuration... and up to 5000 lbs loaded. I now expect to weigh in at about 4000 lbs (empty) and max out at 7000. The weight distribution is still pretty good. I will weigh it under each tire separately to make sure the weight is relatively evenly distributed in the dry configuration.
Wet weight is "centered" between the frame rails for all 3 tanks and the weight is a low as it can get for stability. The fresh water tank is 100% above the floor, the other 2 are 100% below the floor. I will also carry a 6 gal plastic jerry jug in the tub for fresh water reserve and manual refill.
I'm still searching for a quieter motor for the fans... the whine the ones I bought is a bit annoying even at low speeds. Its mostly motor noise, I took the fan blade off and ran the motor without it just to check. I will find an acceptable solution... I have inquiries with several motor manufacturers to see if they make a quiet version of this specific motor. Otherwise I may have to choose a different fan assembly or pick individual parts to build the fan assemblies from. Its a solvable problem. I'm trying to apply the KISS principle for the present.
I was off the air for a couple of days... lightning whacked us and took out my fios modem and a couple of network asset power supplies. We just got back up an hr or so ago.
Chuck
Old 08-07-2015, 08:35 PM   #40
1968 24' Tradewind
1967 17' Caravel
My tanks...
My rear tank just fit transverse between the last 2 cross bars. The one in front of that was longitudinal and I cut the lower part of the 2 crossbars in front of the axle and welded in a dropped box frame for the second tank. This put the original toilet position directly above the rear tank and the tub above the other tank. Perfect for the original plumbing with just a slight bit of modification.
The gray tank inlet and vent are both under the tub. The black tank vent is under the sink in the corner. I welded 3/16" steel sheet metal with a lip in it to the original frame to create a lowered area to cover these tanks and drainage.
I can still slide sheet metal similar to the original from the back into the lip to seal up this part of the underbelly. I will take a picture of them from the back tomorrow and post it. The tanks will not be visible since I put them inside a separate sheet metal box with insulation to help extend the season here in New England. These boxes hang from the box frame(s) I welded in.
I don't remember exactly how much down I extended the frame... and it tapers slightly up in the back to provide exit and entry clearance. The heavy duty axles added about an inch and a half clearance over the old axles plus I pushed the axles slightly together and those clamping wheel chocks now will work where before they would not. I have enough clearance to slide around on a creeper under the trailer when it is on the hitch. When level it is a bit tight under the back. If I lower the front a bit though I'm fine. I'm thinking of welding on a pair of industrial duty steel wheels on the bumper just to make sure I won't scrape bottom on a really steep entry dip...but I will wait and see how close it gets first during the trial period.
Chuck
Old 08-08-2015, 08:50 AM   #41
1968 24' Tradewind
1967 17' Caravel
pictures
Here are various pictures of my tanks installed from all directions, plus a picture of the fan installed and operational.
Chuck
Name:	2015-08-08 10.28.22 HDR.jpg
ID:	244905   Click image for larger version
Name:	2015-08-08 10.28.26.jpg
Name:	2015-08-08 10.29.05 HDR.jpg
ID:	244907   Click image for larger version
Name:	2015-08-08 10.29.32.jpg
Name:	2015-08-08 10.30.06.jpg
ID:	244909   Click image for larger version
Name:	2015-08-08 10.32.13.jpg
Name:	2015-08-08 10.26.48.jpg
Old 08-09-2015, 09:19 PM   #42
1968 24' Tradewind
1967 17' Caravel
Another picture... Mission control, are you ready to commence countdown?
The hidden up lighting I finished this week along with a near perfect systems test. All DC, 110v, feed and drain plumbing, and appliances.
It's really coming along though I'm not going to push to get it out this month unless it just happens.
Chuck
Name:	2015-08-09 21.03.38.jpg
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 03:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 08:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 07:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 12:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 10:01 PM
