Old 09-04-2019, 08:10 PM   #541
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Not if the contest involves speed, if I am in the running.
Slats is offline   Reply With Quote
Old 09-05-2019, 07:37 PM   #542
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
No speed, just methods to mount a waste water tank. I'll start off:
Straps
Pan from the cross members
Angle iron framing
Angle iron from molded shelves on the tank
Above floor tanks
Me, I built special supports so the black tank could be on one side and the gray tank drain could be on the other side. Seems to be working so far.
David
Name:	1802 Waste Tank Black Installed 2 (Small).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 09-06-2019, 07:55 PM   #543
Slats's Avatar
1966 24' Tradewind
That's a pretty impressive set-up, David. What's the thinking on a tank pan vs. no tank pan? The old one I took off was thoroughly rusted through. It appeared to me to be because the furnace duct blew hot air into the pan, thus creating condensation. Kind of like those rusted exhaust systems of old that dripped water from the tailpipe upon engine start-up. I realize using aluminum would eliminate that problem, but still, what is the chief advantage of a pan? By the way, our little get-together at the Roasterie here in KC will be on September 28. Why don't you drag your Airstream to KC for the fun of it?
Old 09-08-2019, 06:50 PM   #544
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That would be fun and I would enjoy meeting you vintage Airstreamers. I can't this year as we have made our fall travel plans for late September.
I hope you make it a yearly "vintage Airstream rally" and maybe next year I will do just that.
Airstreams have heated the tank pans for years. My Trade Wind had it, my Overlander had it, and the Limited has it. It keeps the tanks from freezing up. That is a main purpose of the pans. I don't know if it contributes to the rust out. The Trade Wind toilet was leaking, the Overlander tanks were cracked. I think that was the major reason for the rusted pans in my case.
David
WBCCI #8607
VAC Region 11
Old 09-08-2019, 07:09 PM   #545
Slats's Avatar
1966 24' Tradewind
Danny O'Niell, the owner of the Roasterie, just towed his company Airstream down to the plant. He also owns this '95 diesel version. Both will be there on the 28th for our little gathering.
Name:	Roasterie Airstream.jpg
ID:	351723   Click image for larger version
Old 09-18-2019, 08:17 PM   #546
Slats's Avatar
1966 24' Tradewind
Correction. The Roasterie gathering is this coming Saturday, the 21st, not the 28th.
Old 09-20-2019, 05:54 PM   #547
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Take pictures, make a entry here of your mini-vintage rally. David
WBCCI #8607
VAC Region 11
Old 09-20-2019, 07:08 PM   #548
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Will do, David
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 09-27-2019, 07:03 PM   #549
Slats's Avatar
1966 24' Tradewind
Truma tankless water heater
After talking Truma into selling me the Comfort Plus model they say they only sell to RV manfacturers, not end users/consumers, I put it in the other day. I installed it, sans plumbing at this stage, under the kitchen sink where the old Suburban forced air furnace used to rest. Because the furnace required a larger opening in the shell, I had to fabricate and buck rivet on a piece to fill the gap between the existing cut-out and the heater. I also had to construct a cantilevered stand for the heater to sit on (made out of scrap 2x4s that called for a coat of silver spray paint). I'm not in love with the plastic outer cover, but the person I spoke with at Truma, who used to work for an RV parts supplier, said Airstream uses an aluminum-toned paint that is a close match to the shell and perhaps I could get the paint number for it and order some. All in all, I'm pretty pleased with how it turned out. Now on to getting it hooked up a little farther down the line.
Name:	190923 Truma install 01.jpg
ID:	353087   Click image for larger version
Name:	190923 Truma install 1.jpg
Name:	190923 Truma install 2.jpg
ID:	353089   Click image for larger version
Name:	190923 Truma install 3.jpg
Name:	190923 Truma install 4.jpg
Old 09-29-2019, 06:26 PM   #550
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That is a nice looking unit. Now you can heat lots of water for your hot tub in your Trade Wind, no problem.
I tried painting a white painted Atwood water heater cover some years ago. I used a paint called "chrome" thinking it would be silver gloss. But the paint didn't adhere very well. I ended up covering the white cover with aluminum. So try some modern paints and see what you think. I bet there are better now.
David
WBCCI #8607
VAC Region 11
Old 10-06-2019, 07:10 PM   #551
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Nice work Dale!
I say use whatever Airstream uses to paint plastic and it will look terrific.
Dan
Old 10-10-2019, 04:51 AM   #552
Slats's Avatar
1966 24' Tradewind
Dan -
I likely will do so, but that does not necessarily mean my irregular 3:00 a.m. musings over ways to fabricate an aluminum cover won’t come back.
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 03:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 08:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 07:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 12:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 10:01 PM
