Old 09-05-2018, 08:06 PM   #309
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It's good to remind one's self of the progress being made every now and then. Your Trade Wind is gaining value every week seems to me. Having the ceiling up is big progress. The rest of the skins will be easier.
Keep it going.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 09-06-2018, 12:05 PM   #310
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Looks great Dale. Your Airstream will be better than new when you get finished because it will be custom built to your and Terry s specifications. You also will never be able to put a price tag on what it means to have done it your way.
Dan
Old 09-10-2018, 08:01 PM   #311
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
shore enough
Boy, cutting a 2 3/4" hole in the side of the Tradewind involved some trepidation, but it turned out well. The stainless steel Furrion outlet is a gearhead's dream.
Name:	180910 01 shore power 1.jpg
ID:	322176   Click image for larger version
Name:	180910 02 shore power 2.jpg
Name:	180910 03 shore power 3.jpg
Slats is offline   Reply With Quote
Old 09-10-2018, 08:05 PM   #312
Slats's Avatar
1966 24' Tradewind
Well, I guess it is an inlet, but you got my drift.
Old 09-10-2018, 09:17 PM   #313
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Slats
Nice job on the outlet installation. It is an outlet. Just like a regular 120 volt receptacle is an outlet.
Dan
Old 09-11-2018, 06:37 PM   #314
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Slats: I've installed three of these Furion 30 amp inlets/outlets. They are a well made piece. It is a 30 amp "twist to lock" connector, so a guy need the right female plug on the end of the power cord. That was not mentioned in the ordering literature I used. I also found the set screws that tighten the stranded wire to the Furion unit seemed weak to me. Stranded wire always compresses some when tightening, and then compresses some more after you wiggle it a bit. I had no problems with them, it just seemed like the set screws would strip before I was satisfied my wires were "goot n tite".
David
WBCCI #8607
VAC Region 11
Old 09-13-2018, 04:52 PM   #315
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I installed the Furrion outlet in my Caravel.
The absolute worst part was putting the big hole in the trailer. It was seriously nerve wracking.
Yours looks nice.
Dingo Girl is offline   Reply With Quote
Old 09-13-2018, 07:54 PM   #316
Slats's Avatar
1966 24' Tradewind
Thanks. My friend of a friend electrician came by today and ran all the wiring for the tail lights, running lights and brakes, topping it all off with a spiffy new 7 pin connector. It was something I could have done, perhaps, but to watch (and sort of help) someone who has done such stuff all his life was a pleasure. He could do perfect shrink-wrapped solder joints in very short order. Plus, he is just a really good guy and I enjoyed his company.
Old 09-13-2018, 07:57 PM   #317
Slats's Avatar
1966 24' Tradewind
By the way, I'm thinking of putting a battery box the front of the trailer (on the outside). Anyone done this? Pros and cons? Theft worries?
Old 09-14-2018, 06:35 PM   #318
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I think Airstream started putting batteries in the front on the "A frame" rails in about 1976. Unfortuntally my 1975 Overlander as well as the mid sixties Trade Winds had the battery in the back. Not great.
I vote for a forward mount of the battery. I believe you can buy a lockable battery box for the battery pack you have planned. You can build a platform on the A frame behind the propane tanks. I see on Air Forums others have done this.
I moved the battery of my 75 Overlander forward and mounted it under the gaucho. It is a "vent less" AGM 12v group 27. We don't boondock much, and horrors of horrors, I have a generator. The downside of my decision is I elected to leave the converter and fuse panel in their original locations curb side under the bathtub as that is where all the 12v circuits (4) originate. No one would recommend this due to the voltage drop with long battery cables. I used big honk'in cables and ran them under the belly pan and into the spare tire cavity. I measured a 0.2 volt drop from the battery to the fuse panel. We shall see if I can get buy with this arrangement.
David
WBCCI #8607
VAC Region 11
Old 09-16-2018, 05:37 AM   #319
Mtmanor's Avatar
1967 22' Safari
1966 24' Tradewind
Columbus , Ohio
Batteries in front
Yes, I have the batteries moved out to the tongue.
Had a steel mesh "basket" installed between the propane tank and the front of the trailer.
Then we used a heavy duty plastic battery box with lid from Ebay to keep 2 6v batteries end to end. I spray painted it metal grey and it was just ok to look at.
The boxes don't come with a locking mechanism and we were using a screw to keep the lid on. That was a mistake. During my last trip the lid flew off and was lost in the mountains of NC. Oops.
Now in the process of reinstalling another box. Same one but I will pay more attention to how it locks, the paint job, and will add a couple of drain holes in the bottom.
I wasn't worried about theft because I don't usually leave the trailer anywhere unattended. And the box is exactly to size. It's not that easy to just take a battery out.
I'm not sure I'll do this again on the newest project only because I don't always remember to take the spare tire in the back of my truck. I'm researching adding the spare to the front of the trailer instead. And getting AGM's for inside.
Mtmanor is offline   Reply With Quote
Old 09-16-2018, 07:52 PM   #320
Slats's Avatar
1966 24' Tradewind
getting ideas
AGMS just aft of the wheel wells was my original plan and I think I will stick with it. But, just for the heck of it, before get the belly pan back on I will still run some fat battery cable lines up to the tongue just to keep my options open.
I dragged some of the bathroom stuff inside the other day to get an idea of what I want to modify (pick below). The big cabinet that takes up the whole street side corner is on the chopping block. I think I'd rather put a sink and counter there. I like the feeling of openness I get from having the full end cap to roam around in. There should be plenty of storage space below the sink, as the only systems stuff that will run through there will be the drain line from the kitchen and bathroom sinks and the pex plumbing to the bathroom sink and shower/tub. I'm of a mind in general that storage space only invites stuff to store and I'm getting to be more minimalist as I age. But I'm all ears to hear what experienced folks have to say about this plan.
Name:	180915 bathroom 1.jpg
ID:	322718   Click image for larger version
Name:	180915 bathroom 2.jpg
Old 09-16-2018, 10:58 PM   #321
1970 25' Caravanner
Incline Village , Nevada
i like your idea to remove that big cabinet. certainly would open things up more. You could still make space under counter and sink if you need it.
Jeremy9107 is offline   Reply With Quote
Old 09-17-2018, 08:49 AM   #322
1964 24' Tradewind
Lawrence , Kansas
Opening up the trailer is a great idea. We did it a little differently than what you are thinking. We wanted to leave the back wall to facilitate bathroom privacy. Also that cabinetry provided great storage. What we wound up doing is removing the street side bulkhead. What ever you decide, opening the trailer up is a great idea.
ID:	322760   Click image for larger version
ttbikes is offline   Reply With Quote
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 03:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 08:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 07:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 12:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 10:01 PM
