Old 05-29-2018, 07:27 PM   #261
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Originally Posted by dznf0g View Post
I hear ya. Maintenance, awareness, and mor maintenance. If ya dont like that, you got a wrong hobby and lifestyle.
That's why we all got into this lifestyle, right? A shared passion for preventive maintenance in exotic locations?
TheGreatleys is offline   Reply With Quote
Old 05-29-2018, 07:28 PM   #262
dznf0g's Avatar
Oswego , Illinois
Uhhhhh, yup...
-Rich-
Old 05-29-2018, 10:30 PM   #263
2007 22' International CCD
Dale and Terry get a '66 Tradewind
Sounds very familiar. Joined the Navy, went all over the world going all kinds of corrective and preventative maintenance on all kinds of complicated stuff.
Hm. I thought I got out of that business, but there is plenty of evidence to the contrary even now.... and I thought I had retired.....
Old 06-16-2018, 09:44 PM   #264
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
At a standstill
Not much to report of late. Got all the Reflectix in, but re-wiring has me mildly baffled at the moment. Although I have done minor wiring repairs over the years, I never have had much of a grasp of how it all fits together. Looks like I'll be subbing this part out.
Slats is offline   Reply With Quote
Old 06-17-2018, 07:27 PM   #265
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm not making much progress on my project either. Too many summer activities including rebuilding my son's 2nd story deck. I did finally get my new shower wall installed. What a pain that was for me. Now onto the tub.
Our Airstreams mainly run on 12vDC as you know. That wiring scheme is a bit easier than the AC stuff.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 06-30-2018, 08:35 PM   #266
Slats's Avatar
1966 24' Tradewind
ready to install front end cap
All the wiring has been run and the Roxul is in place in the front, awaiting reinstallation of the end cap, likely Monday. Boy, has it been hot here lately. But as you can see from the pic, the Coleman Mach 8 is thankfully on hand to meet any cooling needs.
Name:	180630 front end insulation done.jpg
Old 06-30-2018, 09:02 PM   #267
1974 27' Overlander
Looking good!
Sent from my Nexus 5X using Airstream Forums mobile app
Old 07-01-2018, 07:50 PM   #268
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Fire up the generator and run that new AC. We're sending more hot weather your way. We even have an extra wildfire or two if you would like one. Colorado is way too hot and dry.
I remember taking a temp reading on the exterior of the Airstream in the Colorado sun. I got 130F. My black pickup exterior was even hotter. I'll take a Minnesota blizzard anyday over this weather. Your new insulation will help prevent that heat from getting inside your Trade Wind.
David
WBCCI #8607
VAC Region 11
Old 07-01-2018, 08:52 PM   #269
Slats's Avatar
1966 24' Tradewind
Yeah, when putting in the Reflecitix one day I pulled the trailer out into the the summer sun. While standing inside, I put one hand on the section with Reflectix and the other on the bare section next to it. It was a simple (and very convincing - ouch!) test that clearly demonstrated the heat reducing value of the Reflectix. The layer of Roxul should be icing on the cake.
Old 07-03-2018, 12:35 PM   #270
Slats's Avatar
1966 24' Tradewind
end cap in
It took only three tries to set the end cap in place before getting it right. My assistant, Elliot, a sophomore engineering student at K.U., was a big help. He not only assisted in the heavy lifting, but also reminded me that my collection of clecos might be of use in holding the end cap in place.
Now, if only I had thought that the rivets going into the rib (as well as through not only the end cap but also the trim piece) had to have 3/8" heads instead of 1/4" ones, I'd be further along. Just ordered more rivets.
Name:	180702 elliot assists.jpg
ID:	315844   Click image for larger version
Name:	180702 elliot assists 2.jpg
Name:	180702 front end cap in.jpg
Old 07-03-2018, 08:45 PM   #271
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Is the front end cap fiberglass (like the bath end cap) or molded plastic. Seems like I recall it was molded plastic where the overhead cabinet was molded into it all as one piece (except the wood doors of course.) I wonder what that big end cap might weigh. And I'm sure it is floppy as all get out.
Nice to have a helper.
David
WBCCI #8607
VAC Region 11
Old 07-04-2018, 07:10 AM   #272
Slats's Avatar
1966 24' Tradewind
It is fiberglass, which I neglected to consider in trimming a small corner of it with a dremel it to get it to fit over the window. Got a slight case of itchy arms from that, something I had hoped to avoid altogether by using cellulose instead of fiberglass for insulation. The end cap was more floppy than heavy.
Old 07-21-2018, 09:32 PM   #273
Slats's Avatar
1966 24' Tradewind
rear end cap in
Today, again with Elliot's help, the rear end cap was hoisted into place, held in place with clecos and then riveted. Went pretty smoothly. As with the front one, the Roxul made us use a good deal of pressure to get the rivet holes to line up. At one point, when I stepped outside the trailer after the air conditioner had been running a while, there was condensation along the rivet lines where there was only Reflectix on the inside, but none where Roxul covered the Reflectix and where foam tape had been applied to the rib before the end cap was riveted to it.
Name:	180718 rear end cap.jpg
ID:	317677   Click image for larger version
Name:	180721 rear end cap riveted.JPG
Old 07-21-2018, 09:42 PM   #274
Slats's Avatar
1966 24' Tradewind
....... and, speaking of the air conditioner, I am really happy with the Coleman Mach 8 13,500 BTU unit I and the condensate pump I added to it. With the bottom still exposed I can watch the condensate trickle down from the pump into the vinyl tube that I ran through a grommet in the refrigerator duct ceiling outlet and down through the refrigerator vent hole in the floor.
Old 07-25-2018, 09:03 AM   #275
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Slats
The end cap looks great!
Glad to hear that you like the Coleman AC unit. That is the one that I will recommend that my son and DIL use in their 78 Caravanner (Texas heat).
Dan
Old 07-25-2018, 08:40 PM   #276
Slats's Avatar
1966 24' Tradewind
end caps out of order, buying local, etc.
The thought occurs that it may seem strange to install the end caps before the middle sections. But I wanted to wait until I get together with my electrical guy before covering over the wiring with Roxul, just in case he has any suggestions on running additional wiring for anything. But getting the end cap in gives me a tangible sense of accomplishment.
On another matter, I stumbled onto a great little trailer parts supply place in KC this morning, K.C. Home Trailer Co. Inc. on the Kansas side. It is about a half mile down the road from Airparts Inc., where I get aluminum and related stuff (rivets, bucking bar, clecos, etc.)
I wish I had known about K.C. Home Trailer when I first started down the full Monte path. It is a seventy year old family owned business situated in a relatively modest sized building in a light industrial area of town. It has shelves stacked to the ceiling with all manner of rv parts and narrow aisles in between the shelves. Dusty boxes of stuff abound. Toilets, tanks, refrigerators, water heaters, furnaces, vent fans, electrical supplies and much more are all there in a semi-organized fashion. The owner is very personable and is an amazing fount of knowledge of all things rv.
Reminded me of my axle adventure, when I realized after getting ill-fitting Dexters from an out of town supplier that I could have gotten ones with custom brackets from an overlooked local company that also happens to be a Dexter dealer, staffed by extremely knowledgeable and very helpful folks.
Don't get me wrong. The internet is a wonderful tool and it offers great communities of like-minded folks with common interests, but there are ways in which it simply never will be a satisfactory substitute for good old brick and mortar one on one in person human contact.
Old 07-26-2018, 07:08 PM   #277
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You found a great little business. Very nice write up on why dealing with real folks seems to work out better. I get my aluminum from Airparts and the nice folks that work there. I really like my local hardware store. So much more helpful than the "big box" outfits. Actually, Vintage Trailer Supply does a good job too. I've had good luck getting help on the phone with them.
There are better sources than just "Amazon" point and click, and hope for the best.
David
WBCCI #8607
VAC Region 11
Old 07-29-2018, 01:36 PM   #278
Slats's Avatar
1966 24' Tradewind
What are these?
Today's prize, to be announced, goes to the kind soul who can tell me what these things are before they get stuffed with Roxul and covered over.
Name:	180728 what is this.jpg
ID:	318339   Click image for larger version
Name:	180728 what is this 2.jpg
Old 07-29-2018, 08:36 PM   #279
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm at a loss. Loser I am! David
WBCCI #8607
VAC Region 11
Old 07-29-2018, 08:57 PM   #280
Slats's Avatar
1966 24' Tradewind
Well, as I recall they were just empty open-ended rectangular boxes hanging there when I removed the ceiling and exposed them. They were a mystery then and they remain a mystery still. So be it.
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 04:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 09:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 08:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 01:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 11:01 PM
