Old 03-17-2016, 02:42 PM   #1
maggieevans's Avatar
1966 24' Tradewind
Burnaby , British Columbia
crosspost - 1966 Tradewinds AC questions
Hi All! I'm a virgin when it comes to AC - coming from the Pacific Northwest, we don't have much need of it. However, I'm spending a lot of time in Southern California these days, and boy it gets warm!
My trailer has never had AC installed - and I'm crossing my fingers as to whether it is pre-wired. PO did a lot of changes to the trailer so I worry he may have played with it, if in fact it did exist. The original breaker box is in place - is there a place to check for wiring there?
My thought at this point is to buy a Rooftop unit direct discharge-13000 btu and install it in the middle vent hole 14" x 14". There is some wiring there for the original roof fan, so I'm hoping that if I do not have the original AC wiring, either the fan wiring will work or I can use it to fish heavier gauge. I only have 30 amp power. Is this enough for an AC unit?
I am a little vague on most points ha-ha. I know I need a drain hose - hoping I can run it to the fridge vent on the outside of the trailer and down the inside from there. I am unsure of how much drain water I can reasonably expect. Does the drip hose just drain onto the ground or do I need to plumb it into my grey water system?
Also - any recommendations on a low profile unit would be greatly appreciated!
Thanks in advance for any help you can give me in figuring this all out!
Happy Trails!
maggieevans is offline   Reply With Quote
First Time AC roof install on 66 Tradewinds - questions maggieevans Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-17-2016 04:07 PM
'66 Tradewinds Lock Set and Deadbolt Questions maggieevans Doors & Locks 12 07-23-2013 08:06 PM
Questions about the water system on my '74 25' Tradewinds chuman70 Fresh Water Systems 2 05-26-2007 01:06 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
