Old 05-11-2015, 09:09 PM   #1
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Atomic's 1968 Tradewind Twin Renovation
Hello! We are just getting started with a major renovation of a 1968 Tradewind Twin - "Windy". There is lots to love about her including a great layout, length, weight, an intact interior, a decent body, and new axles. However, the trailer is in need of a major renovation due to floor rot and an unsafe frame. Over the past few months, we've removed the interior, cleaned the vinyl walls, dropped the belly pan, and removed the rear subfloor. We now have a clear picture of the work ahead of us, which includes a shell off restoration and building a new frame. Like many before us, we are somewhat disappointed in uncovering unexpected major work (especially the need for a new frame). However, Mrs Atomic and I are looking forward to the challenge. Here are a few pictures of the trailer.
Atomic_13 is offline   Reply With Quote
Old 05-12-2015, 05:16 AM   #2
aquinob's Avatar
Portsmouth , Virginia
Welcome aboard. Wow, that is such a pretty trailer, whoda thunk it needed a new frame. Do you have some pictures of the damage?
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-12-2015, 06:00 AM   #3
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
One of the all-time finest,
If there was a graph depicting the of best of Airstream's entire 80 year design history, the lines would likely converge at the '68 Trade Wind.
Yours will be better than new, how cool...
What's the story with the back window?? It's not “period correct”. Wondering why...
Plenty of help on this forum, have fun.
ALUMINUMINUM is offline   Reply With Quote
Old 05-12-2015, 06:36 AM   #4
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Here is an example of the frame damage. Not much was holding the street side A frame to the trailer. The curb side has quite a bit of damage as well. Sad thing is that during the inspection when I pushed down on the front and rear frame it appeared intact. The belly pan hid the damage. I should have lifted up on the A frame as it would have revealed the problem (the front skin pops like an oil can due to the frame bending).
Name:	ImageUploadedByAirstream Forums1431432820.599220.jpg
Name:	ImageUploadedByAirstream Forums1431433390.195404.jpg
I think a PO has replaced a couple of windows (rear and small window in the lower SS in the front).
On a positive note, the furniture and bathroom are in good shape, and it has a newer AC/heat pump, water heater, converter, a fantastic fan, and dexter axles.
In addition to the frame and floor, we plan to refinish the furniture, replace the fridge with an RV model, add a grey tank, rewire, replumb with pex, and modify the gauchos to accommodate 5 sleepers. This is going to take a while.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Old 05-12-2015, 08:47 AM   #5
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Challenges are the "spice" of life! Keep us posted as work progresses..
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-12-2015, 09:27 AM   #6
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Here is a better view of the non-standard issue rear window:
[/url]
It's nice in that it opens like the street side front window.
Here is inside gutted before cleaning:
Here it is after a good scrubbing...
Old 05-12-2015, 03:02 PM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Looks like a plastic wheel well on the street side and a metal wheel well on the curb side. Is that the way it came?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-12-2015, 04:54 PM   #8
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
It was missing the plastic curb side cover. Both are metal above the wheels but the street side had a layer of fiberglass covered with the plastic shell you see in the photo. The curb side had a DIY foam insulation cover.
Old 05-12-2015, 07:25 PM   #9
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
After the new frame, I'm likely to need an upgraded TV. For now the taco works... (especially gutted) As an added bonus you can see the non-standard round window on Windy's street side.
[/url]
Here is an inside photo with the rear floor removed.
[/url]
Old 05-13-2015, 10:41 AM   #10
Rocker66's Avatar
1965 24' Tradewind
Henderson , Nevada
Tacoma towing
Hi Atomic 13 ,
I have the same truck and a 24' 65 Trade Wind ( Yet to tow anywhere ) How does the Tacoma do on the towing ?
Rocker66 is offline   Reply With Quote
Old 05-14-2015, 11:33 AM   #11
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Rocker - My Tacoma has the tow package (6500#/650#) with a stouter suspension and tranny cooler and does fine regarding power on flat to hilly terrain. I typically get 17 MPG at 75MPH without the trailer and 9 MPG towing. We spend a fair amount of time in the mountain west and expect the truck to not fair nearly as well pulling the 4000#/450# trailer. When the restoration is complete I'll likely upgrade to a half-ton 4 door truck for more towing power and room inside for passengers.
Old 05-14-2015, 01:20 PM   #12
aquinob's Avatar
And I griped about getting 19 mpg average with my Tundra with the 4.7 v8. What engine is in the Taco, the 6 or 8? I think I get around 10-11 with it towing, but its been a long time since I had a long tow and the number is always skewed with the non tow miles.
Old 05-14-2015, 01:31 PM   #13
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Bob - here are the specs from Toyota:
4.0-liter V6
236 horsepower @ 5200 rpm
266 lb.-ft. of torque @ 3800 rpm
EPA city/highway fuel economy: 16/20 (4WD, automatic)
I'm looking forward to a larger truck, with more power, and better fuel economy. Aside from the cost of a new vehicle it seems like a no brainer.
Old 05-16-2015, 10:48 AM   #14
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
I'm doing some research into the size and thickness of steel to be used when building a new frame. Seems like many use 5"x2" rectangular tube for the main frame rail and A frame with more variation on how outriggers are made. If one would choose a taller tube, say 6x2, 7x2, or 8x2 would the downside of additional weight be offset by improved trailer strength, room for larger waste tanks, and added road clearance?
I note Airstream added an additional 2" angle to the rear frame to make room for the black tank. I plan to add a grey tank near the axles.
Name:	ImageUploadedByAirstream Forums1431794791.158028.jpg
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
