Old 11-27-2016, 10:50 PM   #99
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Chiseled away at a few odds and ends this weekend.
I cleaned and tested the AC, water pump, and converter. I decided to paint the AC cover silver.
Name:	ImageUploadedByAirstream Forums1480311026.036612.jpg
Name:	ImageUploadedByAirstream Forums1480311075.962757.jpg
I removed the curb side vista view window to replace a weathered piece of plexiglass. It was evidently hot glued into the U shaped channel. It took nearly a day behind the heat gun, scraping the channel clean. The new panel was cut to size and installed with a gasket from vintage trailer supply for a 1970s trailer. This required I remove one side and the bottom of the gasket. Trempro 635 was used to seal the outside glass perimeter and the mitered corners. The window frame was reattached to the shell with bucked rivets. Mother nature's leak testing (it rained) indicated a successful job.
Name:	ImageUploadedByAirstream Forums1480311447.160915.jpg
ID:	276079Click image for larger version
Name:	ImageUploadedByAirstream Forums1480311459.065136.jpg
ID:	276080Click image for larger version
Name:	ImageUploadedByAirstream Forums1480311732.799646.jpg
The old vista view pull shades are weathered and too short. I need to source some new blind material (1/8 ABS or HDPE sheet?). Anyone ever replace these with new material?
My aluminum LP tanks were in sorry shape so I spent a day polishing them. They need a bit more work but look much better.
Name:	ImageUploadedByAirstream Forums1480311810.129242.jpg
Name:	ImageUploadedByAirstream Forums1480311479.052375.jpg
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 11-28-2016, 06:02 PM   #100
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hours and hours and hours of work, but enjoyable work. I like doing Airstream projects in the shop. Great job on the vista windows. They are infamous for leaking and difficult to repair. Removing, cleaning, resealing, and re-riveting is the best way to go.
David
Old 03-22-2017, 09:22 PM   #101
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
With the weather warming I’m back at it. Over winter I tinkered on the trailer here and there sealing various minor leaks after each storm. I found AcrylR and Airstream’s applicator to be quite helpful. I also coated all the inside seams with Trempro 635. I'm fairly sure I applied and re-applied Captain Tolley's Creeping Crack Cure to every rivet on the trailer.
I was pleasantly surprise to learn that Vintage Trailer Supply (VTS) carries the round gasket (with an attached T) to reseal the rear and side access panels. If you tackle this be sure to cut the gasket long and compress it to allow for linear shrinking with age. You can install the gasket without disassembling the panel frame if you use a plastic chisel to insert the rubber T into the frame slot. I noted the factory added a dime sized dollop of what looks like AcrylR to the inside of the mitered corners. I did the same.
I was able to source some 1/8” ABS sheet to replace my weathered vista view pull down shades. I transferred the aluminum handles from the old shade to the new ABS sheet.
I removed and resealed the lower stack windows. The smaller of the two windows had been replaced with a piece of glass 1/2 too short so a crack was present alongside one of the side walls. I had a local glass shop temper a new piece of glass 1/2 inch longer. No more leaks! Here is what the original gaskets looked like from 1968. I applied a bead of Trempro 635 to the outside and used the VTS recommended gasket to the inside.
With the trailer sealed up and water tight, I moved on to the AC wiring. This required installation of the 30 amp power cord inlet on the outside of the trailer. I also installed a 30 amp breaker box and wired it RV style with a floating neutral (not connecting ground to neutral). The ground BUS bar is attached to the frame with an 8 gauge copper wire.
I added the following breakers:
1) 30 amp breaker which feeds the breaker box rales with power from the campsite pedestal (protects the 10 gauge wiring from the trailer to the shore power).
2) 20 amp breaker / 12 gauge BX wire routed to the AC (I added grommets for added protection against chafing and shorts, though with armored BX cable it likely isn’t necessary)
3) 15 amp GFI breaker / 14 gauge BX - exterior outlet and the interior outlets near water
4) 15 amp breaker / 14 gauge BX - microwave
5) 15 amp breaker / 12 gauge BX - hot water heater
6) 15 amp breaker / 14 gauge BX - remaining outlets, refrigerator, and converter
Next up is to:
Add a layer of Reflectix alongside the inside of the shell. I should have done this prior to routing all the AC BX wire but I can slide it behind them.
Following the Reflectix I’ll install the 12 volt wiring (making sure AC and DC wiring are not routed through the same grommet). I’ve purchased a 500’ spool of 12 gauge stranded white white to home run as much of the 12 volt wiring to the 12 volt fuse box as possible. I know you can ground to the frame but this will hopefully avoid ground issues later. I also purchased several different colors of stranded wire for the positive wire to have multiple different 12 volt circuits. The converter, batteries, and 12 volt distribution/fuse panel will be located under the front window.
At some point I want to install the following electrical gadgets and therefore need to pre-run the following wiring:
- Solar - red and black 4 gauge welding cable routed from the roof, via the fridge vent, to the battery
- TV - audio output to stereo, RG6 coax to connect campsite cable to the TV, HDMI to connect a DVD player to the TV
- Stereo - 16 gauge speaker wires to speakers, RG58 antenna cable to roof via fridge vent
- WiFi booster - requires 50 ohm / low resistance coax with with male N connectors from AC on top of the trailer (location of the WiFi antenna) to the WiFi repeater (inside trailer above fridge). The repeater is connected to a mid ship internal antenna with the same type of cable.
- 4G cell booster - will install factory antenna on exterior roof and route cable down refrigerator vent to internal booster once purchased
- AC drip cup drain tube from AC to grey tank
- Water pump control switch (8723 control wire from cabinet switch to relay next to water pump)
- LED light switches (needs wires ran from lights to switches and then to 12 volt distribution panel)
- Marker light switch - route black and green wire from the 7 conductor box to a switch area to power LED marker lights while camping
Following the routing of the 12 volt and accessory cables I’ll install the Roxul fiberglass insulation and then install the interior walls. Then on to interior paint, flooring, bathroom parts, cabinets, plumbing, etc.
So when so I get to go camping?
Old 03-23-2017, 06:24 PM   #102
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
"so when do I get to go camping?" When you get it all done! Hang in there, you're making good progress. I thought I'd whet your appetite with this photo of our 66 Trade Wind out camping with our granddaughters. There is a reward at the end of the journey.
David
Name:	1607 Wellington Trade Wind Castle (Small).JPG
Old 08-07-2017, 06:47 AM   #103
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
After some summer fun trips, I'm back at the renovation.
Over the past few weeks I:
1) finished up the 120VAC system
2) ran eight 12 VDC circuits (used 10 or 12 gauge stranded wire depending on application and voltage drop; grommeted all rib pass throughs, and home ran all grounds back to where the DC distribution panel will be)
3) added a conduit in the wall from the fridge vent to the floor for future wires (wifi/LTE booster antenna)
4) ran various other non electrical wires (thermostat control wire, RG6, RG58, HDMI, speaker wire, 4 AWG welding cable for solar)
5) added reflectix to the inner walls (affixed with spray adhesive and aluminum tape)
6) installed the AC (this involves an improvement of the support brackets, painting the shroud silver, and added dometics' drip cup system to catch condensation)
7) installed the end caps (adding a layer of Roxul safe and sound insulation to the top of the cap prior to lifting it into place, used spray adhesive to hold it in place, up sized to rivets to 5/32 for extra strength)
Next up is the remaining fiberglass insulation and interior skins. Then on to cabinetry.
Old 08-07-2017, 08:26 AM   #104
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
progress photos:
Old 08-07-2017, 06:09 PM   #105
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well hello again Atomic13. Your going to have a brand new 1968 Airstream with all the modern amenities. You have thought of everything I believe. It will be a very special trailer indeed.
Thanks for the very informative posts. It may be next spring before you get to go camping in your Trade Wind. Sorry...
David
Old 08-07-2017, 09:16 PM   #106
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Might have to sleep in an aluminum tent this fall.
The goal is having the Tradewind functional by this time next year to cycle around the fine state of Wisconsin. We plan to pedal 80-100 miles each morning, fly fish in the afternoon, and enjoy the comfort of the airstream each evening. Nice way to spend a week, I believe.
Old 08-08-2017, 06:10 PM   #107
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wisconsin is a great state. Similar to Minnesota and Michigan. The Great Lakes. It is a worthy goal for your new Trade Wind. It takes me about 7 hours to ride a 100 miles (way back when). But I don't have that Atomic factor. You have 13 of them. And don't forget swatting mosquitoes in the evening. There are plenty in Wisconsin.
David
Old 08-20-2017, 09:17 PM   #108
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Replaced a side panel today. Required removing the door. Big project, but it turned out well. While I was at it I replaced the door catch and door handle bumper. The vintage trailer supply replicas are nice. The old catch (and the new one) must be steel. Lots of galvanic corrosion under it. I separated the two different metals using splicing tape.
Old 08-21-2017, 11:02 AM   #109
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I never did replace the one on my 66 Trade Wind. The old one was a rusted mess. I figured a bungee cord worked well enough. I don't want to get too fancy.
I did buy one of the VTS door holdbacks for my son's 69. He didn't like my bungee cord idea. But I did not insulate it with tape. That's a good idea. The holdback is stainless steel, so rust shouldn't be as much of a problem.
Excellent work on that big side panel. My son's 69 has the street side panel replaced when he bought it. I've made a couple of patches, but never replaced a panel.
David
Name:	1602 Door Holdback 1 (Small).JPG
Old 08-26-2017, 09:01 PM   #110
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Enjoyed meeting a fellow forum member, Dale (aka "Slats"), today at the Roasterie coffee shop in downtown Kansas City!
Old 08-27-2017, 07:30 AM   #111
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Ditto. The difference between reading stuff here and an in-person conversation over a cup of coffee is hard to put into words. Suffice it to say that meeting up with and sharing stories with Brian a/k/a Atomic 13 made my Saturday.
Slats is offline   Reply With Quote
Old 08-27-2017, 05:32 PM   #112
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It's great you two creative Airstreamers got together to share ideas. I've met a lot of nice Airstreamers on the road.
David
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
