Old 02-02-2016, 06:40 AM   #43
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Atomic's 1968 Tradewind Twin Renovation
The trailer came with two 2010 Dexter 3500 pound (7000 total) axles, 10 inch drums, 22 degree start angle.
In general these are my remaining steps on the new frame:
- outriggers (got 'em cut but they need end curves and two need slots for the step)
- front hold down plate
- galvanized sheet above the step
- entry step
- bumper and bumper box
- LP tank holder
- rear receiver hitch for bike rack
- spare tire support structure
- holding tank supports
- if needed, install a few gussets (TBD) to resist inward rotation of the bottom of the main frame rail
- pre drill holes for 4 BAL stabilizing jacks
- paint frame and wheels
Anyone have an estimate for how much weight your gear, food, clothes, etc adds to the trailer on trip? I'm sure it depends on # of people and trip length but any guesses? Knowns for us: 30 gallons of water (240 pounds), ~ 100 pounds of food and ~100 pounds of personal items (clothes, toiletries) for 7 days for 5 people. I'll have 52 gallons of grey and 20 gallons of black water capacity.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 02-02-2016, 08:02 PM   #44
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the info on your Dexter axles. My axles are also 10" drums and 22 degree start angle. Mine are 3000 pound axles. The gear we load into our trailers varies a lot. I travel with about 1/2 a tank of fresh water. My waste tanks are mostly empty although I keep about 5 gallons in the black tank just to keep it wet and sloshing. I doubt if we load a 100 pounds of clothes or food. I carry about 80 pounds of propane. The battery is about 55 pounds. The microwave is about 30 pounds. There is maybe 30 pounds of dishes and cooking utensils.
I have a question concerning your folding step that you took off. I have learned that the rear most links follow the slot in the outrigger with a simple follower on the end of the link. How are the front links attached? Can I pry the links away from the slot and have the follower come out like on the rear links? Or do I need to take some belly pan material away to access a fastener under there. I need to remove my folding step as it was bent by a stump when it wasn't stowed properly before pulling away. (Called a dumb ars attack!)
David
Name:	1601 Step Bent.jpg
Old 02-03-2016, 07:15 PM   #45
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
David, I have not removed my step from my old frame yet. When I do I'll take a picture from the back side. I'm not sure if this is the same as ours but this is on eBay. Can't tell if there is a bolt to loosen. Click image for larger version
Name:	ImageUploadedByAirstream Forums1454552051.040645.jpg
Old 02-03-2016, 07:27 PM   #46
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the ebay pictures Atomic. I don't think it is the same step as ours, it looks like a newer version. But the followers attached to the end of the links look similar. The rear links on my step are bent and are out of the slot. It appears it was designed so the strength of the link holds the follower in the slot.
It would be nice to know how this front link is attached to the outrigger.
I hope I'm not diverting you from more important tasks, like welding outriggers and the like.
David
Old 02-04-2016, 06:04 AM   #47
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
The frame is a couple hours away from me, at present. I'll be certain to post a picture on the weekend of 2/13 (my next opportunity to work on the AS). I know for sure the inner most arms hold the pegs in place with tension. Don't recall how the outermost connection looks.
Old 02-04-2016, 12:45 PM   #48
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
David, I talked a family member into texting me a photo for you. Here is the step connections to the outrigger. The rear pin can indeed be removed by flexing the arms. The front connection appears to be pressed on and likely requires you access the area to remove it. Click image for larger version
Name:	ImageUploadedByAirstream Forums1454615095.385536.jpg
ID:	256792Click image for larger version
Name:	ImageUploadedByAirstream Forums1454615115.212859.jpg
Old 02-04-2016, 06:42 PM   #49
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you Atomic, I owe you! Now I know what I need to do to remove the bent steps.
I enjoyed seeing the Kansas City sunshine in your photos. And you can see exactly why you built a new frame for your Airstream. Corrosion is the bane of ferrous materials.
David
Old 02-21-2016, 08:28 AM   #50
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Parts trailer
Well, life always throws you curve balls... grab a cup of coffee, this will be a long post.
I've been looking for a parts trailer to replace various parts and pieces that were either missing or damaged on my '68 TradeWind. In particular I was hoping to find one with exterior end cap panels in decent shape. I was also looking for period correct rear and side windows. As luck would have it I found one (1968 Overlander, International Double). Ironically, this is the trailer my wife wanted all along.
The down side it was 600 miles away. The up side was it was priced right --- very right, to be honest. So my son and I changed our plans from making further progress on frame welding for my TradeWind to taking a road trip for our second airstream recovery mission.
It involved the usual, lots of miles full of apprehension that the photos looked better than reality, that it would even be there after the 8 hour drive, and that we wouldn't be another Craigslist scam victim. But, surprisingly, it all worked out great. After replacing the tires, being glad I brought all the right tools, diligently checking the axle hubs, and pushing through a nasty midwestern ice/snow storm, we made it back to Kansas. After washing off the road salt, I can't be any happier with the shape the exterior shell is in (don't mind the blue tape - I was hoping to not to loose anything on the drive home).
It was a trailer that has been passed down through a nice family since the mid '90, with a single owner prior to that. For the past 25 years, it has either been parked as a fish camp by a river on their property or driven the 10 miles back to their home. Overall, it's seen limited use during it's 48 years.
Like so many other AS owners, the grandson had aspirations to restore it and began disassembling the interior but life got in the way of the project. Regrettably, he informed us that all the bathroom components were beyond repair and he had discarded them. It's in need of a solid cleaning, because fish camps aren't meant to be clean and time wears all things down. The current residents (mice) have enjoyed their home. Perhaps they don't know it yet but they now live in Kansas and are about to be harassed by one very hungry farm cat.
So now we are faced with a tough question... which do we keep and which do we sell? Given the trailers are only 2 feet different in length it seems silly to have both. The fortunate thing is that both trailers can complement each other and have extra parts the other trailer needs. So in the long run, both are better off now, with exception of the bathroom area. Obviously, the trailer we keep will get priority regarding parts but I'm really happy that the secondary trailer has potential to make a nice airstream for someone else. I've also considered simply trying to sell as many parts of the TradeWind to help other trailers further along in the process. For now, we are leaning towards restoring the Overlander as our trailer. Here is why:
- It's the trailer we were looking for all along
- It will more comfortably sleep 5 (the size of my family)
- It's an international line, so it has more bells and whistles
- We prefer the look of walnut wood over ash
- The shell is in better condition
- The missing parts in the Overlander are available in the TradeWind and will make a 100% complete trailer
- Amazingly, my newly welded frame will work with a simple ~ 16" addition to the rear frame rails.
- The Overlander frame (which hopefully is in good shape) can be easily modified to fit our TradeWind.
During the process of swapping parts, we plan to keep the new owners of our TradeWind in mind and make decisions and investments that we'd have made if we were keeping it ourselves. My family has a long history of taking pride in craftsman quality work.
As for the disposition of the TradeWind, it will have to take a back burner position. Once we get the Overlander's shell on the new frame and everything water tight, I might divert my attention to the TradeWind, getting it ready to sell. If we decide against making the TradeWind a parts trailer, I'm not sure how far I should restore it before trying to sell it. I know for sure I'd want to modify the original Overlander's frame, add a fish plate to the C channel to improve it's strength, and treat it with POR 15. We'd need to add a new plywood floor and reattach the shell. It only makes sense to get it water tight, as well, so I don't have to keep it covered in our shop (which has limited space). To, me this would be a great opportunity for someone who wants to restore an airstream right, but doesn't have the space, time, tools, or skills to do a shell off restoration. I'm leaning towards not rewiring and closing up the interior skins as I suspect the next owner would want to do some work on the dents, dings, and scratches. Guess it boils down to how much I want to sell it for and how much time I have. Perhaps, it would take less time and money to part the trailer out... tough decision.
Old 02-21-2016, 07:18 PM   #51
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
How about that! Aluminum-itus is a disease you know. There are folks on these forums who have several and keep wanting more. They're fun to work on and travel with.
I think you are wise to shift the focus to the 68 Overlander considering your family. You can create the sleeping spaces you'll need. The international trim is nice indeed. The Overlander may have been Airstream's top selling model in 68, just like the 25s and 27 footers are currently. You're shell off frame restoration on the Overlander will go quicker now that you have done it. Building a new bath is a big project.
I'd recommend preparing the Trade Wind for sale as a project trailer. Finish it with the new strong frame, axles, subfloor, good windows and doors, and ready for towing (exterior lights and brakes all work). The next phase the new owner would initiate is interior design with associated plumbing and wiring. I'd leave the belly pan off so the new owner can arrange the waste water tanks they need in the locations they need. I'd leave the interior skins off also, but maybe clearly label them so they can be replaced more easily. The new owner will need them off to complete the wiring upgrade and insulate it to their satisfaction. Lastly, I'd include any parts like cabinets bulkhead walls and the like for reuse or patterns for new. The interior of your Trade Wind looked quite good and the new owner will likely want that originality.
Now what is a 68 Trade Wind like that worth? I like to say, although there are lots who disagree, that a good vintage Airstream shell is worth $5000. Dents and missing windows and doors significantly detracts from that price. A good shell along with a new frame and new running gear add significant value. I don't think many of us amature restorers expect to get paid much for our labor or overhead. You may take a haircut on the Trade Wind, but you may make it up on the Overlander.
Coffee gone...
David
Old 02-22-2016, 07:31 AM   #52
I'm an Overlander guy.
But the TW is a great trailer, if you decide to change plans, it'll make a good camper for someone else.
Good Luck!
Old 03-15-2016, 09:29 PM   #53
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
I burned a few vacation days to move the Tradewind closer to having its shell back on.
I used a plasma cutter and jig to create curves on the outriggers and then attached them to the frame (making sure they were square and level with frame rails).
My brother helped me fabricate the slotted step outriggers with his mill.
Name:	ImageUploadedByAirstream Forums1458098472.076338.jpg
The step needed some repair work but it's working great now. Click image for larger version
Name:	ImageUploadedByAirstream Forums1458098488.316508.jpg
I installed 2" straps for belly pan attachment down the center of the frame and along the outriggers. The outrigger straps needed moved outward to accommodate the 6" deep frame (my skins will not reach as far under the frame).
Name:	ImageUploadedByAirstream Forums1458098513.329170.jpg
I torched the bumper from the old frame and attached it to the 6" frame rail by tapering a 12" section of rectangular tubing (since the bumper is 5" and my frame is 6")
Name:	ImageUploadedByAirstream Forums1458098539.592281.jpg
We decided to use 16 gauge galvanized steel for the front hold down plate. Hopefully it will play nicely with the Alclad. Might still isolate it.
Lastly, I fabricated a spare tire holder under the A frame. I need to add a center bolt to keep the tire from sliding off the holder.
Name:	ImageUploadedByAirstream Forums1458098584.699234.jpg
Next up is painting the frame, installing plywood, and everything that goes in the belly pan (tanks, sensor and break wires, 7 pin wire, insulation, etc.)
Old 03-15-2016, 09:36 PM   #54
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
It's nice to be nearing the completion of the frame welding. It's dirty and hard work, but I've really enjoyed it. Click image for larger version
Name:	ImageUploadedByAirstream Forums1458099377.408950.jpg
Old 03-16-2016, 01:49 PM   #55
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Holding tanks arrive today!
I finished up a few minor projects and regrettably need to head back to work.
The subfloor end curve patterns and measurements match up well with the frame.
Name:	ImageUploadedByAirstream Forums1458157363.568395.jpg
Pre fit the propane tank rack (will paint separately from the frame)
Name:	ImageUploadedByAirstream Forums1458157428.980817.jpg
Repaired the ends of my wheel wells.
Name:	ImageUploadedByAirstream Forums1458157468.253112.jpg
Added a second welding pass to my coupler (should be super strong).
Name:	ImageUploadedByAirstream Forums1458157615.655933.jpg
Painted the wheels.
Name:	ImageUploadedByAirstream Forums1458157717.704282.jpg
Old 03-17-2016, 09:45 AM   #56
1967 24' Tradewind
Blairstown , New Jersey
<Regrettably, he informed us that all the bathroom components were beyond repair and he had discarded them. >
Check your PM.
Wayne
rasmuw is offline   Reply With Quote
1968, frame repair, full monte, shell off, tradewind
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Lychgate
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
