Old 07-05-2019, 01:04 PM   #365
Springtown , Texas
Originally Posted by Slats View Post
To be candid, I hadn't thought of that. But now that you mention it, I did subconsciously shy away from using them for heavier applications than fastening my solar port and my shore power inlet, both of which are attached with pretty small stainless steel bolts that don't require all that much torque.
Yeah no worries in those applications for sure. Even so the "tighten" torque is seldom the problem easily standing up to the standard torque spec of the intended fastener size, it's the loosening that gets you. Much like a rivet when properly installed it is very difficult for them to fail when tight.
CarterKraft is online now   Reply With Quote
Old 07-05-2019, 02:03 PM   #366
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Atomic's 1968 Tradewind Twin Renovation
Thanks for the additional info about rivnuts.
I tested out the water pump relay and must admit I was pretty smitten when it worked! Follow confirmation that it did, I joined the wire junctions with heat shrink adhesive crimp connectors and tidied everything up with zip ties and wire looms.
Following that project I built a shelf that is located above the bathroom vanity. The Ď68 bath had a 110VAC outlet that I opted to carry forward into my renovation. However the wires exited the interior endcap in a less than ideal location just above the sink. Therefore, I wanted a shelf to conceal the wiring heading away from the sink. Itís made from cypress, which was the same wood species used as the lighter wood in the butcher block vanity top. The shelf was finished with several coats of Waterlox, which is an awesome concoction of tung oil, linseed oil, water gum, and phenolic resin (a wood hardener).
Next up Iíll make a pair of ceiling mounted walnut strips that will hold fly rods when the trailer is used for fishing trips (which I hope is often). Iíve also ordered the shower pan, shower valve, and an oxygenics shower head.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 07-05-2019, 03:14 PM   #367
1966 22' Safari
Fredericksburg , Texas
Shower Pan
Attachment 345486
Attachment 345487
Attachment 345488
Attachment 345489
Attachment 345490
Attachment 345491
Brian, where did you order your shower pan from? I was hoping to find a place that would fabricate one off a drawing. Thanks
Bubba L is offline   Reply With Quote
Old 07-05-2019, 03:56 PM   #368
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Bubba- I order a standard 24x32 shower pan off amazon. Iím going to make my own shower surround (might use thin tile with flexible grout). Still considering weight aft of the axles.
Lippert Components 210371 White 24" x 32" Rectangular Right Handed Drain Shower Pan https://www.amazon.com/dp/B00OM0YKDC..._lC8hDb7GQZ9JQ
Old 07-05-2019, 06:47 PM   #369
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I was going to do that, I even went so far as to weld up a stainless pan.....
But then I was walking through Lowe's one day and I spied a 32" square three piece enclosure complete with a door and the rest is history.....
Old 07-07-2019, 08:21 AM   #370
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Brief update: completed the fly rod holders and installed them above the couch. For those who donít fly fish, having a place to store rods at camp is helpful to keep these fragile (and expensive) 9í rods from getting broken. I likely will not travel with them fully rigged on the ceiling.
I also cleaned up the three 10.5 gallon galvanized tubs that sit below the couch. I added reinforced PVC ribbing to the base edge to prevent it from marring the floor (link below)
Trim-Lok Edge Trim - Flexible, PVC Plastic Edge Protector - Fits 1/16" Edge, 3/8" Leg Length, Single Gripping Finger, 25' Length https://www.amazon.com/dp/B00NL45NQI..._x8FiDbTRZD2NW
Old 07-07-2019, 05:49 PM   #371
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Your Tradewind will clearly be the star of the annual Roasterie convocation. High bar indeed.
Slats is offline   Reply With Quote
Old 07-08-2019, 05:24 AM   #372
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Looking Great
Eddie Bauer, Tommy Bahama, Pendleton, all pale in the light of Atomic's Orvis edition.
ALUMINUMINUM is offline   Reply With Quote
Old 07-10-2019, 02:14 PM   #373
MiTWind69's Avatar
1969 25' Tradewind
Kalamazoo , Michigan
Secondíd. Trout - beware! I see a fishing trip in your near future.
MiTWind69 is offline   Reply With Quote
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
