Old 01-09-2019, 11:36 AM   #295
coloradoup's Avatar
1966 24' Tradewind
Olathe , Kansas
Talking That All sounds good!
Brian I think you can support this another way and not spend much needed dollars on plywood and angle iron. Just take some of that left over 2x2 metal you have at your dad's shop and weld in a chunk right down the middle of your spare tire area directly under the sub floor.
Next set up that fancy dado blade on your table saw and crank it up two and a quarter inches. Run you spare wheel and tire across it and dado out a slot for that 2x2. Pretty sure your dado doesn't go 2 inches wide so you will need to make a few passes at it. Now I know what you all are thinking but I figured that out too. Make sure you mount that wheel with the notch facing in when you go to use it. That way nobody thinks it looks stupid!
PS, don't forget your pump.
coloradoup is offline   Reply With Quote
Old 01-09-2019, 04:35 PM   #296
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Funny stuff, Mike. I'm a bit concerned about wheel balance with the 2" slot removed out of the spare.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 01-09-2019, 07:42 PM   #297
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Wheel weights on both sides of the notch?
Slats is offline   Reply With Quote
Old 01-10-2019, 07:28 AM   #298
1964 24' Tradewind
Lawrence , Kansas
By the way, I believe VTS has a fresh water tank with baffles. It is not that much more than the same size without baffles.
ttbikes is offline   Reply With Quote
Old 02-17-2019, 08:22 PM   #299
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Atomic's 1968 Tradewind Twin Renovation
I decided to place the 60 gallon freshwater tank at the front center of the trailer. It was installed using 2” 11 gauge (0.125”) steel angle that spans the main frame rails and a section of 1/2 Baltic birch plywood the same foot print of the tank. Prior to installing the tank, I sandwiched a strip of foam between the steel angle and the tank to prevent chaffing.
Following the tank installation, I finished the remaining plumbing between the freshwater tank and the galley. Vibration damping hoses, a particulate strainer, and an antifreeze siphon valve was inserted between the tank and water pump. I pre-ran a wire for a water pump switch by the galley sink and the shower area, which will activate the water pump using a 30 amp automotive relay. A low point drain exits through the subfloor through the spare tire area under the trailer. This also serves as a vent for the freshwater tank when filling. Lastly, I arranged a valve layout that permits filling the tank from either the front gravity fill neck or city water.
The only remaining plumbing items involves installing a city water inlet and finishing connecting the water lines and drains to the bathroom components and water heater.
I also made some changes to the galley.
Originally I whitewashed the galley drawer fronts. they ended up having a peach hue which frankly looked terrible against the white faceframe and walls.
I opted to paint the drawer fronts an olive drab green and ended up liking it. It’s a nice hint of subtle color and will match the green wool blankets we’ll use for bedding.
I’m moving on with the installation of the front dinette. More to follow.
Old 02-18-2019, 10:09 AM   #300
Slats's Avatar
1966 24' Tradewind
You can’t go wrong with olive drab. It is, I think, an under appreciated hue.
Old 02-18-2019, 04:10 PM   #301
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
In my "rebellious" high school days (which were not as exciting as I make them sound) I would occasionally wear a Vietnam era olive drab army trench coat to the dismay of my then girlfriend (and now wife). I still have the coat and used it for a color match for the drawer fronts. Nothing like a bit of personalization in the trailer.
Old 02-18-2019, 07:09 PM   #302
Slats's Avatar
1966 24' Tradewind
I've always thought olive drab looks cool with a red accent, such as the red found on your cabinet doors. Here's a little something to toss on your gaucho to continue the theme (subject, of course, to your wife's approval):
Old 02-18-2019, 07:13 PM   #303
coloradoup's Avatar
1966 24' Tradewind
Olathe , Kansas
I too love the olive drab hue! Looks even better in person..
Old 04-23-2019, 01:41 PM   #304
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Nice weather has finally arrived and the work schedule is slowing a bit which has freed some time to work on the trailer. I was able “rough in” the curbside couch and its adjoining bulkhead.
I’ve been waffling back and forth about this area being a couch that converts into a bunkbed. In the end, the compromises I would have had to make (tall side walls, considerably heavier construction, window obstruction, etc) made it not worth it. Instead this area will be a comfortable couch that pulls out to a 48”x78” bed. Tight but it will sleep two still allowing a pathway to the rear bathroom from the front dinette. The front dinette will also sleep 2 adults and perhaps a third person if they are small (e.g. kid). So let’s call it a 4.5 sleeper.
Just aft of the couch will be a closet for clothes. The pocket door will close just aft of this closet and fore of a bathroom vanity cabinet.
Old 04-23-2019, 04:33 PM   #305
Slats's Avatar
1966 24' Tradewind
Looks great, Brian. It is comforting to hear that I'm not alone in my waffling.
Old 04-23-2019, 07:49 PM   #306
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Atomic 13: Happy to see you back at it. I was a bit worried.
Heck, I waffle all the time, usually Sunday mornings. I'm efficient at making them, and I can eat a lot of them.
The couch looks great. Your Trade Wind will be very comfortable indeed. It could be said your trailer is kinda like the Caravanner. Open layout, and no fixed beds.
My old Trade Wind was just the standard twin bed layout, and it wasn't too bad. The new oversized mattresses helped a bunch.
Press on when you get time.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
