Old 05-20-2018, 10:20 PM   #183
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
I wrapped up the pantry, built the box for the side-by-side fridge/freezer (Isotherm Cruze 200 12VDC/110VAC, Danfoss compressor), and installed the closet flange and toilet this weekend.
Once the fridge is installed Iíll span the area between the pantry and fridge to complete the galley. The sink (IKEA 21Ēx17Ē), faucet (?), and cooktop (Ramblewood GC2-43P) will be installed here.
Lots of options for galley counter tops (Formica, cork, wood, copper sheet, etc). I have access to the equipment to glue up a thin (103Ēx28Ēx1Ē) butcher block. Alternating maple with walnut treated with food safe (mineral or danish) oil would really look nice. Likely on the heavy side (100#s?) but it would be over the axles. Crazy idea?
I found a perfect sized stock tank for a shower pan. I still need to build a riser box, install a drain, and a Hepvo waterless gas trap. Itís exterior will be enclosed in cedar. Still thinking through how divert water into the pan and not on the pocket door wall. Corrugated metal/plastic?
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 05-21-2018, 07:39 AM   #184
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Atomic's 1968 Tradewind Twin Renovation
Quick calculations indicate the butcher block would weigh ~95 lbs and a particleboard/Formica top would weigh ~65 lbs. Leaning towards walnut sapwood which would carry the striated floor pattern to the countertop.
My brother owns a millwork business. He has several 6 head moulders, large glue/clamp stations, and a 50 inch wide belt sander. This should make short work of the project.
Old 05-21-2018, 08:14 AM   #185
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Example here:
Old 05-21-2018, 06:32 PM   #186
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hey, a stock tank for a tub. Just like the cowboys used to use. I assume it is a plastic molded tank.
I wonder. What if you trimmed the top lip off on the two sides of the tank that fit up to the wall so the tank is close to the wall. And then you fabricated a shower wall from a piece of FRP plastic and let it overlap into the tank. The FRP is glued to the walls, and the overlap area could be fastened to the tank. The tank will be boxed in so it isn't going any place.
The shower plan I got for my Trade Wind had a lip around three sides of it where I could overlap the FRP shower wall. I believe I just used shower calking to hold it in place.
Actually the bathtub in my Overlander is close to a stock tank, and it is used as a shower pan. I'm keeping it in the trailer. I did paint it "toilet white". So it looks like everyone else's tub.
David
Name:	1405 Shower Rear Wall Installed (Small).jpg
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 05-22-2018, 05:39 PM   #187
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Airstream's '67/'68 bath design, placing the tub perpendicular to the trailer center-line allows a six-footer to shower with a few fingers of head-room. Your plastic tank achieves the same. A coopered looking tub surround would suit the Manly theme.
I read earlier that you consider exposed, on-wall, copper plumbing. Google Images shows hundreds of “Clawfoot Tub Curtain”,the common solution to an oval tub.
https://www.google.com/search?q=claw...w=1152&bih=750
Picture below is an odd example of sweated copper taken from that search, most are commercial chrome. Suspended or supported 1” K copper should bend easily, might even incorporate the shower head. There's stainless waterpipe.
I made a curtain rod from 1” stainless boat-rail. It was easy to fit to trailer's compound curvature and bulk-head with common nautical rail components.
http://www.airforums.com/forums/f46/...on-147648.html
Sounds like wood is your plan. Your friend's work is tempting, Is he making your cabinets? Most will agree with the romance and beauty of oiled wood, but considering functional reality, wood countertops would be too much responsibility for me.
Stainless steel would be my practical counter-top, impervious to Manly activities like rebuilding carburetors, dressing wounds, soldering, fish reel repair, cleaning weapons, chemical solvents, animal fluids, dry ice, hot pans, adhesives... Wood takes care, stainless survives mindlessness.
The story would be that it's a re-purposed autopsy table.
ALUMINUMINUM is offline   Reply With Quote
Old 05-22-2018, 07:46 PM   #188
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Aluminuminum: Your description of "manly" activities on a stainless steel countertop is superb! I might add that packing trailer wheel bearings is easier on a stainless countertop versus a wood one.
David
WBCCI #8607
VAC Region 11
Old 09-30-2018, 09:31 PM   #189
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
After a busy summer of being mostly on the road or at work, I took a week off to make some progress on the TradeWind.
But before diving into an update regarding the renovation, Iím pretty excited about my new tow vehicle. We have a new driver in the family, so our vehicles needed passed down the line. This was a perfect opportunity to pass on my Tacoma to my son and upgrade to a more substantial truck designed for towing. My Tacoma would have struggled in the Rockies, which is where weíll spend a lot of time with the Airstream. After much research and consideration, I found a sweet deal on a 2019 F250 (Lariat, CrewCab, 4x4, 6.7L Power Stroke). I looked long and hard at F150s but with all the extra people and associated adventure gear we plan to bring along, the payload on the F150s ended up being a deal breaker for me. Boy, how things have changed since I last purchased a truck in 2009 (technology, features, and their costs have skyrocketed).
I started the past week installing LED dome and reading lights. I sourced these from Vintage Trailer Supply and am really happy with the them. I can tell you it felt pretty good when I flipped the switches and all worked as planned. I also installed a switch bank near the door that turns on the LED scare light, an LED light that shines from under the trailer on topp of the the step, and the third switch delivers power to the exterior LED running lights (for rallyís). Iím hopefully by making the trailer completely LED, Iíll minimize power consumption.
Here is some handy tools for the above job:
Following the lighting, I replaced my fantastic fan since it was leaking. The old shell was cracked by the tapered head screws so I used stainless machine screws with washers this go around.
I decided against a forced air furnace for the trailer and instead installed a Dickinson P12000 LP stove. These are designed for sailboats and the reviews online are quite favorable. Iím optimistic it will sufficiently heat the trailer and really appreciate that all the combustion is isolated outside of the trailer so water vapor doesnít lead to concentration on cold mornings. I also purchased a Olympian Catalytic Heater - Wave 6 for the bathroom. It still needs installed but on very cold nights we could crack a window and run this in addition to the Dickinson.
Lastly, I installed a Isotherm Cruise 200 freezer/fridge. I still need to cut a hole in the subfloor to vent the area behind the fridge. Iím not all that excited to provide an access point for ants, etc. Iíll have to read up on methods to allow cool air to enter behind the fridge to cool off the compressor. Perhaps I should louver the access panel instead.
Next up is to install the catalytic heater in the rear bathroom, the walnut butcher block top for the galley, and then the sink and cooktop will be on deck.
Old 10-01-2018, 06:12 AM   #190
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Here is how the heater attaches to the cabinet.
I placed the heater on an angled wall which for my layout and heater location had several benefits:
1) Improved firebox window viewing.
2) Improved the flow of heated air by placing the heater closer to the trailer center, rather than wedged on the wall between the deep refrigerator box and the dinette.
3) Created a void between the heater and the refrigerator which will be insulated. Evidently these heaters donít warm the rear wall all that bad but it canít hurt to minimize heat transfer to the refrigerator.
4) Provided a bit more clearance for those entering the street side dinette seat.
This boxed area will be capped with a residual section of the walnut counter top but will sit 2Ē lower than the galley counter top. Iím installing a school bus fan on this small counter top section to move heated air from here to the rest of the trailer. The sidewall has a removable panel to allow access to the various 12VDC and AV cables that exit the wall in this location.
P.S. My apologies for the atrocious grammar of my prior post. I shouldnít write late at night after a hard week of physical labor.
Old 10-01-2018, 06:24 PM   #191
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Definitely a very unique installation of your heater and fridge. I hope that it works as well as it looks, cuz it looks fantastic!
Dan
Old 10-01-2018, 06:53 PM   #192
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome back on the Trade Wind job. You are inspiring me to get back at the Overlander. Your "appliances" are certainly high tech and different from the standard RV fare that I use.
Congratulations on your new Super Duty. We got one 5 years ago and it has performed very well with no defects or problems noted. We tow the wife's 34' Limited (8000 lbs) up and down Colorado mountain crossings with no problems. It is about 30% more efficient than our former V10 gas van. Your new truck is a significant upgrade over our 2013.
I did not recognize the tools you bought for your LED installation. Can you elaborate a bit for me.
David
WBCCI #8607
VAC Region 11
Old 10-02-2018, 06:19 AM   #193
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
David, regarding the tools used, Iím using heat shrink marine crimp connectors on my 12VDC wires to stabilize the connections for bumpy rides. As you know, this trailer will see some use on unpaved roads to access fly fishing spots and for boondocking.
These connectors require just the right amount of crimping power and then an application of heat. Once heat is applied to the connector it shrinks, activates an air/waterproof sealant, and adheres the wire to the connector. It makes for a excellent, long lasting connection superior to wire nuts or soldering. Here are the tools used:
Wirefy Heat Shrink Wire Connectors - Electrical Terminals Kit - Marine Automotive Crimp Connector Assortment
https://www.amazon.com/dp/B07124B886..._AQ1SBbZE30SRR
HydraLink Sealed Multiple Wire Closed End and In-Line Butt Connectors
https://www.cableorganizer.com/hydra...re-connectors/
Step Down Butt Splices
https://www.cableorganizer.com/step-...ce-connectors/
Klein Tools 11063W Wire Cutter and Stripper, for 8-20 AWG Solid and 10-22 AWG Stranded Electrical Wire
https://www.amazon.com/dp/B00BC39YFQ?ref=yo_pop_ma_swf
A speedy wire stripper the cuts the wire and strips the insulated jacket in one simple squeeze.
Titan Tools 11950 Ratcheting Wire Terminal Crimping Set
https://www.amazon.com/dp/B01N43O0UJ?ref=yo_pop_ma_swf
This set allows the proper crimp to be applied to most solderless terminals, including insulated, closed end, heat shrink, and spark plug terminals. The ratcheting crimper minimizes over-crimping a connector. The array of crimping dies included in this set make it possible to select the correct die for the style of terminal.
Power Probe MT Micro Torch
https://www.amazon.com/dp/B000P6WMKK?ref=yo_pop_ma_swf
Produces a very small flame that is faster than a heat gun for the shrink tube but use with caution and donít catch you trailer on fire! Can also be used for soldering.
Old 10-02-2018, 06:43 AM   #194
1966 22' Safari
Fredericksburg , Texas
Didnít realize they had step down butt splices. Will be ordering today. Thanks for the information. The proper crimps, heat shrink, etc is the way to go. Thanks for the posts. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 10-05-2018, 07:52 AM   #195
1964 24' Tradewind
Lawrence , Kansas
Thanks for the post. Been wondering about those connectors
ttbikes is offline   Reply With Quote
Old 10-05-2018, 05:15 PM   #196
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the tool descriptions. I've been doing it the old way with crimp butt connectors and electrical tape. Not near as good as yours.
David
WBCCI #8607
VAC Region 11
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
