Old 10-16-2017, 10:33 PM   #141
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by Atomic_13 View Post
Thanks, thatís essentially the approach I took for the circuits. I just hadnít worked out the best/preferred approach to connect three wires: 1) wire from upstream power supply, 2) wire to the nearby accessory, and 3) wire to the next accessory downstream. Sounds like itís ok to crimp two 12 gauge wires on one side and only a single wire on the opposite side. This is ok with standard wire connectors or are they specialty items?
I do it all of the time with 12 volt circuits, so long as the terminals are sized properly, two wires in one terminal solves a multitude of problems, and it cuts the number of total connections by a lot.
If I were to bury a 12 volt connection in a wall or ceiling, I would solder and cover the splice with two or maybe three layers of quality shrink tube. A splice like that is forever and actually stronger and more durable than the host wires.
J. Morgan is online now   Reply With Quote
Old 10-16-2017, 10:39 PM   #142
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Thanks! Makes sense. Fortunately, all my connections are accessible.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 10-18-2017, 08:49 PM   #143
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I think I read somewhere somewhere that you are going to paint inside with car paint. If so, consider Industrial Imron. It can be rolled and/or brushed and still flows out nice. It can be economical, it covers like mad, an activated gallon goes a long way.
Old 10-30-2017, 06:02 AM   #144
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Thanks for the suggestion. The inside is approximately 460 ft2. Do you think two gallons would cover this?
Iíve been going back and forth between this product and an exterior latex designed to withstand the temperature induced expansion and contraction of the skins. I would think both would need a primer capable of adhering to the vinyl coating on the walls. Iíve heard the some use Kilz Adhesion for this.
This past weekend, I met up with Slats and ttbikes from the forum. Tim had sourced a good exterior latex option at Sherwin Williams. I plan to check that out as well.
I spent the weekend installing a new lower wall in the rear bathroom area and the window trim pieces. After I patch a few more small holes/cracks on the interior skins Iíll be ready for paint.
Old 10-30-2017, 06:50 AM   #145
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
what a terrific project, and you could'nt have picked a more worthy trailer to do it to. my Overlander sat out in a hunting camp for 18 or more years, and was nasty as all get out, but still in solid usable condition. we have truly enjoyed it
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-31-2017, 11:24 AM   #146
clydecrashcu's Avatar
1984 31' Excella
1976 Argosy 24
Olsburg , Kansas
one of previous owners
We purchased it on ebay out .of Valpariso, Indiana. Was a Un. of Indiana party trailer by owner before us. Lots of reg and white on interior.
rear window and side window replaced before we bought it. original windows are square corners not rounded as you know. Trailer may have been end of year production with 69 windows, interesting aspect of trailer.
When we got the trailer the eyebrow window by door was broken out, had replaced that small section of plywood. Didn't get into anyother part of of flooring. That was our first trailer. Now I know more about repairing trailers.
Your doing a good job. You have met our friend ttbikes (Tim). He told me that he met you but didn't know the 68 was ours. Hope to meet you and see the trailer. Lee
clydecrashcu is offline   Reply With Quote
Old 10-31-2017, 07:43 PM   #147
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Atomic's 1968 Tradewind Twin Renovation
Lee - thanks for the history on this old Tradewind. As I mentioned in my direct message, youíll have to join us the next time we meet at the Roasterie in downtown KC. Iíd like to see your Argosy.
Old 11-05-2017, 04:42 PM   #148
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Lee - per your request here are some pictures of the brackets for the original bunk bed in my 1968 Overlander.
Old 11-26-2017, 03:14 PM   #149
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Interior walls patched, installed, and painted.
Bondo was used to repair holes in the fiberglass end caps. A notched chisel was used to replicate the surface texture on the surface of the Bondo to conceal the patching.
Wall prep / painting involved:
1) degreasing with super clean (3 parts water, 1 part super clean)
2) surface prep with Savogran(R) trisodium phosphate (1 cup TSP to 1.5 gallon water)
3) fresh water rinse
4) dry time
5) one coat XIM UMA bonding primer (used 0.75 gal)
6) two coats PPG Break-Through acrylic interior/exterior paint (V51-410, used 1.75 gal)
7) Interior temps were kept above 50F during painting and for 24 hrs afterwards in a low humidity environment.
Old 11-26-2017, 03:32 PM   #150
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
4) dry time
Attachment 299838
Attachment 299839
Attachment 299840
That looks freaking nice. Nice job Atomic!
Old 11-26-2017, 07:51 PM   #151
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It looks great. So many painted interiors end up not so great. Yours is fantastic.
Do you think your paint recipe would work on ABS thermoformed plastic bathroom furniture? My bath was painted but it looks very flat and chalky.
David
Old 11-27-2017, 05:37 AM   #152
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Thanks to you both. I forgot to mention above that a 3Ē roller worked well on the end caps. Anything wider (even a 4Ē roller) left paint edge lines.
David - none of what I painted was ABS, only vinyl wall covering and fiberglass end caps.
Iím assuming that when you say ďbathĒ you are referring to the surround and cabinet pieces and not the tub. If itís the tub (which I donít believe is ABS), Iíve read people have had good luck with a two part epoxy product, such as ďMr TubbyísĒ http://www.tubbydiy.com
Regarding other items, I have a few pieces of ABS above the windows and the fridge vent that need painted. I havenít adequately researched what the best approach is for ABS.
Anyone have suggestions?
Old 11-27-2017, 03:41 PM   #153
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
[QUOTE=Atomic_13;2039129]Interior walls patched, installed, and painted.
Is envy still on the list of the seven deadly sins?
Nice job.
Slats is offline   Reply With Quote
Old 11-29-2017, 06:16 AM   #154
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Dale - itís certainly a pivotal point in the restoration. Youíll be there sooner than you think. Brian
1968, frame repair, full monte, shell off, tradewind
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 Safari Twin - Parts from renovation for trade LOS ANGELES safairi Airstream Classifieds 1 03-29-2014 06:51 AM
1968 Renovation Almost Complete "Atomic Overlander" hartley1212 General Interior Topics 4 10-11-2011 10:35 AM
Atomic Pod :: 2008 Airstream International Signature Series CCD bolerama Airstream Registry Discussions 0 08-19-2011 08:30 AM
Atomic Airstream Forrest Airstream History 34 01-26-2009 07:20 PM
