Closed Thread
Old 05-19-2011, 03:59 AM   #57
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
I'll contribute my money for a front- mount one--I imagine they'll be a couple hundred? :-) i know what its like to make something with big overhead! Rae
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline
Old 05-19-2011, 01:13 PM   #58
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Thanks Rae - I suspect you're in the right neighborhood, yes.
I'm expecting a revised quote this afternoon from the metal fabricator, and then will update everyone on how soon we can pull the trigger!
bredlo is offline
Old 05-19-2011, 01:40 PM   #59
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Excellent.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline
Old 05-19-2011, 03:56 PM   #60
reinergirl's Avatar
Hollis , New Hampshire
Brad,
As you know I'm interested too. I also want to mount it in the front (as was original to my Overlander) but I WANT the "dimple". I don't know how the tire cover removes (can someone enlighten me?) but I like the set up in the picture below. I don't even see that they cut off the bottom of the cover. Maybe there's no reason to make two versions????? One thing of note, I suspect that maybe the Overlanders (and other models too) had extra room in the front to allow the spare tires to be mounted there?
reinergirl is offline
Old 05-19-2011, 04:26 PM   #61
bredlo's Avatar
1954 22' Safari
Shelly,
If you had a long enough tongue (I realize that's a rather personal statement) it'll probably be perfectly possible to use the "valley and cone" style on the front instead of the flat. You'll just need to make sure you have room to pull it forward far enough to clear the tire.
As for the construction of the flat front version, it'll be easy to create with the same tooling, so I'll probably do a batch anyhow. They have a hinged section that allows it to lift straight up - pretty nifty, and while these photos (of someone else's cover) look awful, I imagine it'd look perfectly nice when new and clean (and dynamite polished).
ID:	130216   Click image for larger version
bredlo is offline
Old 05-19-2011, 04:27 PM   #62
Baltimore , Maryland
Brad, I would be willing to put in an order for three and even put the money up in advance...
Frank's Trailer Works is offline
Old 05-19-2011, 05:23 PM   #63
reinergirl's Avatar
Count me in. I'll make it work somehow!!! I'll put the money up front too. Anyone near me want to combine shipping? Heck, maybe I'll use it as an excuse to go see Frank's place .
Old 05-19-2011, 05:36 PM   #64
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
IndyAnne: any 68 Trade Winds with this cover?
The front mount seems good to me. I hope I can make room for it.
Wait -- did any other 68 J.C. models have this front tire cover? I need to check out the frame/mount for it while I am already tinkering around with rearranging stuff.
Anne
Originally Posted by bredlo View Post
Hi all,
Wow, thanks for the continued interest in my idea. I've been in touch with the aluminum spinning company; they've seen my original in person. I toured their facilities and confirmed that they can indeed produce a replica that buyers could either polish or leave raw.
The main question is upfront costs, as I'll need to put up a couple thousand dollars to make the first batch... the costly part being the full-sized maple and steel "dies" that the aluminum is formed over. Still, I'd really like to get the first batch created this summer (batches probably being 2 dozen or so), and have even been in touch with VTS about the possibility of facilitating easier (less costly) shipping, which would open this up to more folks as well. Nobody's going to get rich off re-making these, but as with most things Airstream: it's a passion.
With several people having asked about tongue-mounted front covers rather than having them on the back bumper, I believe that can be accomplished as well -- most importantly, using the SAME tooling as the rear covers. It will involve skipping the last couple of steps in the forming process where the inner valley and cone are formed. This way it will be a flat front, with the the bottom 1/5th or so cut off so it sits flush with the tongue, and a small hinged door added on the side to let it slide straight up over the spare. That's how all the originals that I've seen photos of were constructed, and is great because you won't have to remove your LP tanks to pull the cover off the spare.
I'll put in a call again with the company here in Chicago, and in the meantime, if anybody would like to put in some of the seed money for this project - with the knowledge it'll be applied towards their cover - I'm open to considering that. I'm happy to provide additional details, more accurate overall costs and intended timelines for added peace of mind, as I'm happy to keep this project transparent and educational.
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline
Old 05-19-2011, 05:38 PM   #65
The door is always open. Come by any time....
Old 05-27-2011, 11:30 AM   #66
bredlo's Avatar
1954 22' Safari
Quick update: it's been a week, but I'm expecting an quote today on these. At that point I'll crunch a few numbers and attempt to move forward on this.
bredlo is offline
Old 06-16-2011, 01:43 PM   #67
bredlo's Avatar
1954 22' Safari
Hey, fellow continental kit enthusiasts.
In the interest of keeping this project both financially transparent and easy to keep track of... I've created a Kickstarter page here.
The way it works, essentially, is that you "pledge" the purchase price for one cover, but are only charged if we reached the minimum order size by July 16th (30 days from now). If we don't, you're out nothing. If we get enough people, I imagine I could have the covers produced within an additional month. So I'd say we're looking at mid-August if everything goes well.
I'm not terribly confident that we'll have the numbers for this to work, but I'm happy to try - and encourage you to spread the word to help get these back in production. Thanks for all your patience, too!
Don't forget to click on the photo -- there's a video slideshow with dimensions, etc.
bredlo is offline
Old 06-16-2011, 02:15 PM   #68
1957 26' Overlander
Images: 45
My pledge has been sent
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
Old 06-16-2011, 05:01 PM   #69
bredlo's Avatar
1954 22' Safari
Awesome, if there's a serial number stamped into them, you'll get 001!
bredlo is offline
Old 06-16-2011, 07:43 PM   #70
reinergirl's Avatar
I'm in and have pledged! Number 2
Closed Thread
Spare Tire Cover Replacement pcbueg Classic Motorhomes 15 02-16-2018 08:08 AM
Spare Tire Mounting question polarlyse Tires 5 05-05-2011 07:31 AM
Suggestions for a spare tire carrier? NicheVintage Tires 5 04-28-2011 10:59 PM
Spare Tire Holder vhariable 1974 - 1979 Sovereign 1 04-08-2011 03:09 PM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
