Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 06-19-2008, 10:37 PM   #1
CLAD
Profile:  1961 24' Tradewind
Cupertino , California
Access door for a 61 Tradewind
I am trying to find a replacement hinge for the storage compartment access door on my 61 Tradewind. The door itself is in good shape but the hinge is pulling thru the rivets that hold it to the door. It is bent also and I think a lost cause.
I have looked in the regular places for a replacement but got nothing. Anyone out there ever had to change one of these things out.
Thank you for the help.
David
CLAD is offline   Reply With Quote
Old 06-20-2008, 06:49 AM   #2
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
Check out McMaster Carr for aluminum piano hinges.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is online now   Reply With Quote
Old 06-20-2008, 11:48 PM   #3
CLAD
Tradewind access door hinge
byamcaravanner
Thank you for the hinge alternative. That one may just work.
The old Tradewind hinge is a piano type hinge that has one leg that is 1 inch wide and the other is abut 3/4 of an inch. The part that is tough is that they do not open in the same plain. The long leg attaches to the Airstream skin 3/8 inch recessed from the plain where the hinge is and other leg attaches to the door.
David
Old 06-21-2008, 04:05 AM   #4
byamcaravanner
I'm not sure I follow you and I don't have one here to look at. McMaster has a page called "about piano hinges" that may give you the info you are looking for. If you can post some pictures or a sketch I might be able to understand better.
Steve & the crew
Old 06-21-2008, 03:04 PM   #5
CLAD
Access door hinge
byamcaravanner
I looked at the McMaster-Carr pages and the hinge that looks similar is on page 2963 and is a load rated aluminum geared hinge. It looks like it would work but I would have to do some bending of the hinge legs.
See pictures of what I have.
David
ID:	62648  Click image for larger version
Name:	Access door hinge.jpg
Old 06-22-2008, 04:02 AM   #6
byamcaravanner
I was thinking of the side hinged access doors... the geared hinge is the one you want. It looks like the one on your trailer is factory customized from the stock hinge. I would first consider doing my best to bend the existing one back into shape.
Good luck!
Steve & the crew
Old 06-22-2008, 10:27 AM   #7
CLAD
Acces Door hinge
byamcaravanner
I was trying to clean and straighten the old one last night, cheaper than buying a new one.
It looks better but but doesn't open or close very well. Since I have the rivets all out it is a great time to upgrade.
David
Old 06-22-2008, 11:40 AM   #8
byamcaravanner
David,
If you think you can modify the one you saw at McMaster...go for it. You are right, no time like now to upgrade.
Good Luck! and post about your efforts.
Steve & the crew
Access door wanted Kim Fox Parts Archive 3 05-22-2005 03:55 PM
Wanted refrigerator access door chrome dome For Sale & Wanted 2 05-17-2004 01:11 PM
Wanted, water heater access door and frame, and "Service center" door. till Parts Archive 1 01-27-2004 11:43 AM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
fridge outside access door twitcher Parts Archive 2 10-17-2003 04:05 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
