I have used a hoe and sharpened flat bladed shovel before in boats and they work well in large areas. I have found that a very sharp Scraper is very helpful in small areas.
You may try a heat gun to remove the adhesive but only after removing the foam that could burn or create harmful fumes.
Good Luck!
