Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 08-28-2007, 08:34 PM   #1
bgarver
Profile:  1959 24' Tradewind
Fuquay Varina , North Carolina
59 Tradewind Dump valve
Can anyone tell me what kind of waste valve was standard on the 59 TW? I have heard everyone talk of Thetford valves and have looked them up on line, but they bear no resemblance to mine. It is all black and has a slide from the rear bumper. I only have a black water tank, so the gray drain out after the valve. Hence, I suppose the answer is a porto-tote. I have a 5 gal tank that will use for now.
Anyway, after messing with the valve today, I find that it won't close completely. If I knew the brand, maybe I could repair it. Any ideas? If need be, I can post pics. We seem to like pics on here alot.
bgarver is offline   Reply With Quote
Old 08-28-2007, 09:14 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
If it is all black, it is probably a Valterra slide valve and a replacement for the original 2" brass gate valve.
Stick with Valterra. They are cheap and you can find them everywhere.
If it's brass, I would still replace it with a Valterra Valve because the original valves are hard to repair.
See pictures in my photo album of the original valve.
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 02:01 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 0 10-02-2002 08:28 PM
Tedford dump valve 77caravaner Waste Systems, Tanks & Totes 0 09-29-2002 05:58 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 01:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 09:38 AM
