07-29-2009, 02:46 PM
1967 24' Tradewind
Greenville
, South Carolina
1967 Tradewind Renovation
Well as I suspected the PO did not do a very good job on the floor repairs. he put a new piece of flooring over the black tank and guess what it was supported by...............................the black tank! So in order to do things a bit better I have decided I'll need to remove the rear bathroom first. WAIT! Can't do that until I remove the gaucho. here's where I'm at after my first days of work. Stopped when the outdoor in the shade temperature hit 102 degrees. I think it was hotter than that in the trailer with no air! Will post progress as it is made. Feel free to jump in with criticisms, comments, ideas, sage advice, etc. as I am new at this.
Thanks, Michael and Vicky
07-29-2009, 04:06 PM
1968 28' Ambassador
Cedaredge
Did you get the bath/shower out the front door. I couldn't get mine out of the 68'
And my ducting was under the floor, looks like yours is above.. Was the bathtub on top of it.?
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-29-2009, 04:12 PM
Austin
See all those dirty nooks and crannies as you pull stuff out? Now you get to make it all sparkling and new. Well worth the effort for that alone, I'd say.
Keep up the good work, it's going to take many hours, but you'll get there.
You've been around a while so you probably already know this, but for anyone who is tackling what you are about to, I always suggest reading the Major Renovations threads. Many of them are lengthy, but they pay great dividends when you encounter many of the same things these owners already have. IMO you get much better info from these threads than you do from asking questions on the forum, unless it's something VERY specific.
Good luck!
07-29-2009, 04:18 PM
1967 24' Tradewind
Greenville
, South Carolina
Jason,
I tried to get it out the door and did not make it on the first try. I do think it will go out with some contortions. Was SO hot in there that I gave up and left it in the front of the trailer for now. I'll be trying to get it out the door tomorrow and will let you know. Yes, the bathtub was on top of the ducting held up by a platform. see pic
07-29-2009, 04:27 PM
1967 24' Tradewind
Greenville
, South Carolina
Marcus,
I've read and reread many of those threads. Besides them being a great resource for information, they provide inspiration. Yes, I have been around for little while, but so far have only deconstructed, which doesn't take a lot of craftsmanship.. Sold the Silver Streak after gutting and removal of rear floor area. Sold it because wifey would not allow two in the yard. Thanks for the encouragement and your numerous helpful posts.
07-29-2009, 04:33 PM
1958 26' Overlander
Mesa
Michael, I feel your pain. It was 113 yesterday, but only 108 today.
But Airstreams get even hotter inside. That's why I do all of my work in the morning and evening.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
07-29-2009, 04:38 PM
1967 24' Tradewind
Greenville
, South Carolina
Yes, I'm sure you can relate. It was 114.5 here yesterday and is 107.8 here right now. Whoo Hoo...a cooling trend. I'll be out there tomorrow morning soon as it is light! Now I am curious and am going to place a thermometer inside to check the temp difference.
07-29-2009, 06:14 PM
1968 24' Tradewind
Oxford,
, Mississippi
Know what you are going through. I have a 68 Trade Wind that I have completely gutted. Mississippi summers are hot and humid, no fun in an aluminum box!! Take your time and think things all the way through before doing anything. An hour spent thinking completely through the next 3 steps of demo in your mind will save hour 20 hours of actually work. Trust me. I replaced all the rear foor up to the first cross member. It is not hard, but be prepared, it takes time. The best suggestion I gleaned from the forms was to make a pattern of luan ply, make it fit perfectly and then use it as a pattern on the new floor. This tip saved me untold hours. Cardboard is just not stiff enough to really get the fit correct. The finish floor is heavy and you have to take in in and out many times go get the fit just right so the light weigh pattern ply is the way to go.
Good luck.
07-30-2009, 01:29 PM
1967 24' Tradewind
Greenville
, South Carolina
Tub Removal
Jason,
It was a struggle and I was not too worried about the finish on the tub since I am going to redo. Not looking forward to putting it back in while trying not to destroy the finish. had to remove the magazine rack to do it and must be flexed and cussed at extensively. here's how it was positioned to come through the door. BTW right now it is 98 outside in the shade and 104 in the trailer. I'm done for today.
07-30-2009, 01:38 PM
1967 22' Safari
1960 Caravel
Edmonds
Good job! The tub is about the hardest thing to get out of the trailer. When you put it back in get some help. An extra set of hands really helps when it comes to putting the tub back in. Stay hydrated!
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
07-30-2009, 02:14 PM
1967 22' Safari
1960 Caravel
Edmonds
This might help you too.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
07-30-2009, 03:14 PM
1958 26' Overlander
Mesa
Good job, Michael. Wow, that's a tight fit for your tub. I'm glad things aren't that tight for my '72.
1958 Overlander
4CU 1st VP
07-30-2009, 03:39 PM
1967 24' Tradewind
Greenville
, South Carolina
Lee, Thanks for the diagrams, I have a couple of them in the owners manual (I think) and yes they will help with reassembly. Am trying to decide if I should just go ahead and add a gray tank while I'm doing all this.
Mike, thanks for the encouragement.
07-31-2009, 05:23 AM
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
You guys in California and Arizona have all the luck. Yours is a dry heat! LOL
Good luck with the project. Everything takes at least three times longer than you thought it would but paydays come regularly with the satisfaction of completing some small aspect of the larger job.
Gatorade is your friend.
08-02-2009, 05:18 PM
1967 24' Tradewind
Greenville
, South Carolina
Bathroom is out!
Was able to put in quite a few hours today. Here's where it's at.
08-05-2009, 05:37 PM
1967 24' Tradewind
Greenville
, South Carolina
What's up with this?
Can't figure out why these cutouts are on the exterior skin and in the U-channel on both side above the frame. Take a look.
08-05-2009, 08:30 PM
San Angelo
I believe those might be weepholes, to get rid of condensation?
Frederic
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
08-05-2009, 09:16 PM
1967 24' Tradewind
Greenville
, South Carolina
Had not thought of that. although I would not have expected them to be so large 1.5" x 6"
08-06-2009, 07:35 AM
1967 24' Tradewind
Greenville
, South Carolina
Rear floor removed
Not the horribleness that I have seen hidden under some floors. Frame looks like no major problems. The U-channel had some little 'T' shaped nails that that were difficult to remove when they weren't rusted way. Now I get to try and recreate the corner curve where it was completely rotted away. The plan is to put the old floor on a piece of luan then put the U-channel in it's original position and tracing the curve of the U-channel where there is no floor. Then will use the luan to test fit.
08-06-2009, 07:40 AM
1967 22' Safari
1960 Caravel
Edmonds
Not weep holes!
Not weep holes. I'm going to guess that was cut to some rear sag frame repair in the past. If you look at the sprayed black stuff you can see the holes were cut after assembly. Looks like it's weakened the c-channel and it's cracking. You should reinforce or replace those areas. Yep the t-nails are a pain in the @##. Good progress. Keep it up!
P.S. By the time I was done I really hated the spray in foam insulation.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
