Old 09-09-2008, 03:37 AM   #101
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Wow! How did I miss this thread? I'm subscribed now. Looking good man!
JP
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 09-09-2008, 03:46 AM   #102
Baltimore , Maryland
I have been following along from the beginning, but have not commented as of yet. I too want to be informed when something is posted on this thread, so this comment will put me there. You are doing a super job, keep up the good work,
Old 09-09-2008, 09:43 PM   #103
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Axle
Marc - Taken from the line-item ticket.........
Axle Part Number 11TF60-655E
Description 76 X 58 X 22.5
I will measure my axle in the morning when it's light out and see exactly what those 76" and 58" were dimensions for. The 22.5 in clearly the start angle.
Craig
2333 is offline   Reply With Quote
Old 09-09-2008, 09:50 PM   #104
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Floorplans as of 5 minutes ago.....
Thanks for the support JP and 62O. I wouldn't have gotten this far without following your threads.
Marc - I had posted the floorplans on a thread titled "Airstream Floorplans", but have added a bit since then. This is the latest, but always subject to change.
Name:	Airstream floor plan - TD #1 door view.jpg
ID:	67165   Click image for larger version
Name:	Airstream floor plan - TD #1 rear view.jpg
Craig
Old 09-10-2008, 09:14 AM   #105
Richard77
richard77's Avatar
1959 24' Tradewind
eckert , Colorado and Mexico
Great work! Thanks for the detailed posts of the process!
Richard
Baja Blog http://360panoramas.com
Store http://zazzle.com/zgdesign*
Portfolio http://myflash.biz
richard77 is offline   Reply With Quote
Old 04-08-2009, 11:57 AM   #106
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Tail Lights
The pics really explain it all. The original bargman 99's are gone. The PO had these "wedding cake" ones on. I think they are used a lot in the aftermarket cuz they are cheap, but I don't like them and tried to find some remakes of the 99's. I've been on the VAS waitlist for 3 years and no luck.
I've always liked the earlier style recessed AS tail lights, but $$$$.
So, these are cheap look-a-little-likes from Grote.
I also filled in the random 17 extra screw holes around the lights using rivets. Seriously, how many times has someone made new holes for aftermarket lights!! So it looks a little interesting, but rivets are cool. I'll buff out the swirls in the polishing phase.
ID:	78092   Click image for larger version
ID:	78094   Click image for larger version
Craig
Old 02-24-2010, 02:28 PM   #107
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Ready for Storage
I put the inner end caps back on and the upper skins. I only fastened them with 1/5th to 1/6th the rivets as it's all coming back off again anyway. I was amazed that the rivet holes lined up
I then backed it out of the driveway using a friends F350 and towed it to the ranch. My God that thing is powerful.
The new axles with the higher clearance made it easy and there was no chance of scraping the bottom at all. The F350 pulled it easily without sway bars or a load-level hitch. I only went 55mph. I felt no sway and almost couldn't tell the airstream was there. I know it's more truck than I'll need, but it was actually fun.
Hopefully, I'll get at least one picture of the trailer as it's parked on the ranch.
ID:	96901   Click image for larger version
Craig
Old 02-24-2010, 09:49 PM   #108
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
We all wish you Godspeed and a great year in Africa. Maybe you can find a team of oxen and an oxcart to work on over there!
Zep
Old 02-24-2010, 11:50 PM   #109
Bo&Susan's Avatar
Daleville , Alabama
Love your TROUBLEMAKERS, Too cute! Oh what fun your gonna have LOL. Enjoy! Bo and Susan.
Bo&Susan is offline   Reply With Quote
Old 02-25-2010, 04:26 AM   #110
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Here's what I did for mine. I put the #9 trim rings and lenses over the recessed lights. Looks great!
Old 02-25-2010, 08:24 AM   #111
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
jp.. that was a great idea with the lights. Looks totally original!
Craig
Old 02-25-2010, 12:14 PM   #112
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Good luck in Africa and return back to Colorado safe and sound.
From Ill.
Kip
Old 03-21-2010, 12:44 PM   #113
1962 24' Tradewind
Grand Rapids , Minnesota
Many thanks Craig for your superb documentation of your renovation. I also have '62 Tradewind. I started removing the belly pan thinking I could just pull it from under the shell. After drilling out several rivets, I couldn't see how it was going to work so back to the forum. Fortunately I found your thread and learned that the pan is wrapped around the u-channel. Big headache avoided because I don't want to remove the shell. For me there many other useful items of information in your thread too. Thanks again.
norskrabbit is offline   Reply With Quote
Old 09-12-2015, 06:30 PM   #114
Ruther Glen , Virginia
How did it turn out????
leahroehl is offline   Reply With Quote
Old 09-13-2015, 10:06 PM   #115
1962 24' Tradewind
1962 Tradewind
It turned out reasonably well. We started out with the idea of restoring it to the original condition but found out the parts were unavailable and it would have been prohibitively expensive so we renovated it. We replaced the toilet (it was in good shape except for the seals which weren't available), the water warmer which leaked, the furnace, the refrigerator and the axle brake and suspension assembly. I also replaced the water heater and furnace vents with modern vents and made new aluminum surrounds for the vents. We replaced the galvanized water tank with a 20 gallon plastic tank and then also had room for a 20 gallon gray water tank under the sofa bed in the middle of the trailer. And then the sink and shower drains were rerouted to that tank.
Our biggest problem was the 20 year accumulation of mouse debris in and under the trailer. I opened the belly covering and cleaned out the mess. We got an odor neutralizer from a commercial cleaner which worked quite well; its mixed with water and sprayed on. It took 4 application where the urine saturated the wood but one application worked on other surfaces.
We revarnished the woodwork and painted the walls and ceiling with a textured Behr paint. My wife reupholstered the sofa beds and made some curtains. We polished the outside to the point where it is very shiny. However, there are 50 years of dings and scratches and a dent in the front corner which I can't do much about without spending a lot of money. But its very usable and pulls like a dream.
Old 08-23-2018, 04:40 PM   #116
1962 24' Tradewind
Oceanside , CA
This is an amazingly helpful thread! It doesn't answer the question I originally was looking for, but inspires me to document more! I hope Craig and his family are doing well!
Blockhead is offline   Reply With Quote
1962 24' Oddball? Mark in Modesto 1959-69 Tradewind 36 03-30-2019 07:04 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
