Old 10-17-2006, 07:57 PM   #43
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Hot water tank removal...
The last thing left in the trailer was this tank. So...
  1. It is secured to the floor with some metal braces, mine pulled out by hand because of the floor rot. Disconnect all the copper piping. There was an overflow rubber tube, which drained thru the floor, into the belly pan. Not sure how often it overflowed, but that water just sitting in the belly pan couldn't be good. This pic shows the flashing behind the tank on the side wall.
  2. Now it's gone.
  3. Outside, here's the access panel to the gas valves, etc.
  4. Removed all the necessary panels.
ID:	27125   Click image for larger version
Name:	outside covers 1.JPG
ID:	27127   Click image for larger version
Name:	outside covers 2.JPG
Craig
2333 is offline   Reply With Quote
Old 10-17-2006, 08:04 PM   #44
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Next...pull out the tank
Nice to discover that if you disconnect everything really close to the tank, it will easily push/pull right out the hole made for the access panel!
  1. Here is it 1/2 way out. Too easy.
  2. Rust and Rot. From the inside, when this was sitting under the sink, there wasn't any evidence that it wasn't it great shape and I could just keep using it as is. The floor is rotted and this whole area damaged from sitting water.
  3. The bottom of the tank is rusted out, and this extends to the inner tank as well.
I wouldn't have even seen this unless I had committed to the complete restoration. I will scrape this tank, let me know if you need any of the hardware. Not sure what I will replace it with yet.
Inner panels next....
Name:	pull out tank.JPG
ID:	27129   Click image for larger version
Name:	floor under tank.JPG
Craig
Old 10-17-2006, 08:19 PM   #45
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Nice work Craig. Makes it all worth while to take things like this out and discover the hidden mess. Keep at it.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 10-17-2006, 09:25 PM   #46
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
All this in less than a month! Way to go. You must be very busy with your family, job, trailer, life..........good job, nice progress and documentation as you go.
Dave
Fyrzowt is offline   Reply With Quote
Old 10-18-2006, 12:11 AM   #47
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
I wouldn't toss out that outside cover. They are very hard to find in that good of shape. FYI I would ebay it or post it on here for sale.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 11-08-2006, 09:13 PM   #48
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
...Took a Break..
..Well, we got hit with that big snowstorm about 10 days back and that certainly stopped work on the trailer. Then we had Halloween. Fortunately, I was right at the point where the inside was stripped, but the shell and floor were still on, so naturally.... a HAUNTED AIRSTREAM!
So, I turned the trailer into a "Monster Lab". I had a couple red light bulbs flickering on and off, fog machine, scary music, the obligatory jar of eyeballs (peeled grapes), intestines (spaghetti), fingers (carrots), and a few other props. The kids loved it and were really scared. I had fun too.
It really looked great at night, the pictures don't do it justice.
Name:	Snow Day Trailer.JPG
ID:	28371   Click image for larger version
ID:	28373   Click image for larger version
Craig
Old 11-08-2006, 09:29 PM   #49
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Back to work.....
....The lower inner panels are off (pic 1). You can see I started to peel back the folded over portion of the belly ban (pic 2). But I am coming to realize that once all the lower rivets are off and the belly pan "unfolded"....is anything but a few "Hidden" rivets holding the shell on?!?!
That one diagram I pilfered from jordan's thread (A-Merry-Can) because it seems to apply well to my trailer and it looks cool.
1. If what I said is true, then how can one drop the belly pans WITHOUT literally having the shell off?
2. Once the belly pan is off, the few rivets left holding the shell on are through the outer edge of the U-Channel and the lower end of the side wall ribs.... and a lot of the ribs don't even go all the way down to the U-Channel (pic 3), so it's like a handful of rivets at best. Is this correct?
Hopefully once I better understand it, then I'll know the sequence I should take. If it appears to be what it looks like, then what I really should do now is:
1. Brace the shell on the inside.
2. Remove all the outer rivets around the whole trailer at the lower end of the shell.
3. Raise the shell.
4. Pull out the trailer.
5. Then unfold the belly pans from the U-Channel.
6. Drop the pans.
7. Unbolt the U-Channel and remove.
8. Remove the floor, fix frame, new axle, put in new wood floor, rebolt channel, etc.
Does this make sense?
Name:	Lower Skins off.JPG
ID:	28375   Click image for larger version
Name:	U-Channel peel up.JPG
ID:	28377   Click image for larger version
Craig
Old 04-30-2007, 10:02 PM   #50
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Shell Off
Wow.
I could blame the weather (it did snow here every weekend in Jan and Feb), I could blame other obligations (work, etc), I could blame a lot of things... but who cares, it's water under the bridge (or wind under the shell), cuz I am back on track now.
5 months it sat in the driveway like that picture in my last post.
The last 2 days I was in a fugue. Had good weather and an open schedule.
During the 5 months, I did occasionaly get out there and drill out the lower skin rivets. Sometimes I'd do 2 sometimes 20. It took a total of about 2-4 hours I'm guessing. It went a LOT faster with the rivet removal tool.
Tip - Buy this tool if you are taking off more than 30 rivets, it's priceless.
I've read here how a few (NorCal, A-Merry-Can, Jim, Flyfisher? Someone, the names are all a blur) did the shell themselves, so I knew it could be done.
1. Search for hidden rivets and cut them off from the rear with a dremel tool.
2. Brace it across at the 4 ribs that are thicker alluminum. You can't miss these main supporting ribs, they are at the square corners before the curve of the endcaps. Obviously thicker than the rest of the ribs.
3. Run 2 longer braces along the sides (also capturing the door).
4. Start jacking it up with a car jack... then stop when it doesn't budge.
5. Search for more hidden rivets . Just for reference: 2 inside each side of the door jam at the bottom, these go into the steel "L" brackets on either side of the doorway. 2 rows of them (one on top the other) into the steel plates at the front and the back below the windows (the front plate is only about 18 inches wide, the rear was the width of the window). Then one on either side of the wheel wells. Then one at each of the 4 thicker supporting ribs.
6. Start again jacking it up at one corner, put a little stress on it and then go around with a putty knife and run it under the outer skin. This un-catches any rivet stems that are still catching in the rivet hole (When you drill and pop off the rivet head you can try to "nail-punch" the stem back into the trailer, but some just don't budge and these are the ones that the shell catches on later). The putty knife also loosens the vulcum goo. As you do this, the corner will suddenly pop-up! So, give just enough lift-stress with the jack to maybe raise it 1-2cm before going around with the putty knife (but, not enough to warp or kink anything).
7. Once a corner gets up 1", then put a few wood blocks under the wood framework there and go do the adjacent corner.
8. Keep going around corner to corner till it's all up, then you can just jack right at the mid-point of the front and rear. Go a bit at a time building your support under the woodframe. I stacked cinder blocks on the floor of the trailer.
9. Once it's up high enough, then build another wooden framework right undeneath the first one, but you need to have it extend out past the sides of the shell to sit on cinder block supports that are on the ground (or homemade sawhorses as others have done) see picture.
10. Lower the shell onto the outer supports.
11. Secure to ground. Lots of options here. I drilled right into the driveway and screwed in 4 big eye bolts then lashed the framwork to them. Overkill? No.
11. Pull trailer out from shell and get to work.
Notes:
- Google Search 53-400 Rivet Removal Tool. Everyone sells the same one, just get the best price.
- A single 2x4, serving as a brace between 2 main ribs (either front or back), secured to the ribs with only 2 screws on each side, can lift an entire side of the shell, from a single mid-beam jackpoint. I don't recommend this, but it happened. See picture.
- I used a minimum wood framework for the intial lift and then further braced it later. Only two 2x4's across the width and a small one bridging the door. All my exterior skins are on and only the lower inner ones removed. This obviously provided a lot of torsion strength as I had no noticeable flex.
- You need to raise it up high enough for wheels, wheel wells, propane tank holders, etc, to clear the bottom of the skin as you pull out the trailer. Some of those are removable and could lower the sillouete of the trailer considerably.
Hope this more detailed account of the shell-off helps the next guy who needs to do this him or herself.
Disclaimer: This is only the way I did it, you should build a much stronger shell support frame (before you start jacking it up), have 10 friends help you, use a better jack, have stronger outer support structures, and ground it more securely.
Name:	Hidden rivets.JPG
ID:	36509   Click image for larger version
Name:	Lifting Shell.JPG
ID:	36512   Click image for larger version
Craig
Old 05-01-2007, 12:10 PM   #51
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Yeah, us! Thanks for this writeup.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 05-01-2007, 09:38 PM   #52
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
You're Welcome Ingrid!
I have been peeking in on your thread since I joined the forum and now I fear window repair!
I've read and totally understand how lots of people get their trailer gutted and then stop there. I did for 5 months. So, I'm really pushing hard to get past that point. It's like I see the top of the hill now and hope to crest it soon! (I think that point comes when you rivet the shell back on)
Craig
Old 05-02-2007, 09:54 PM   #53
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
Moving the trailer around......
Here's how I got the trailer out. I bought a trailer dolly from checker auto (29.99 sale). It's easy to use, would be nicer if it came with a brake because my driveway is not flat.
Anyway, I just pushed it out and pulled it off to the side.
I started unfolding the belly pan from the U-channel at the left front corner and got into it for 10 minutes before it rained. It's alot easier with the shell off.
BTW: My 7 year-old could easily move the trailer around on the flat surfaces with this dolly. Right tool for the right job.
Name:	Pushing trailer out.JPG
ID:	36716   Click image for larger version
Name:	Keep 'em seperated.JPG
Name:	Belly pan starting to drop.JPG
Craig
Old 05-02-2007, 10:04 PM   #54
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
U-Channel detail
As you unfold the belly pans off the outer lip of the U-Channel, you still have to pry a bit with a screwdriver because quite a few of the rivet stems are still in the hole.
I noticed a few interesting things.
1. The Channel that is around the curves is thick and it's bolted down using semi-substantial bolts. I haven't yet noted if those go only through the wood floor or if they go all the way into the frame underneath.
2. The Channel that is in the straight sections is thin. Appears to only be screwed into the wood floor with 1-inch screws.
The curved sections seem in decent shape so far and I think I can reuse them. When I put the shell back on though, I don't expect the rivet holes to line up and I will likely have to drill new holes.
Does anyone think this will weaken those U-Channels?
Name:	U-Channel detail.JPG
Craig
Old 05-04-2007, 12:27 PM   #55
1967 24' Tradewind
Images: 38
Yes...
That's good to know, that we're not the only ones who hit a wall at the shell off point...part of our problem is a fallen down fence, which is going to be hopefully finished today. Then we'll have room to do the shell-off.
Don't fear window repair...just fear me doing window repair!!
~ Hurley
ingrid
Old 05-04-2007, 04:46 PM   #56
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I had no problems lining the old holes up but I clecoed the skin to the channel first and then bolted the channels down second. I think most everybody else did it the other way around. I also added a lot of holes later. My project is also not a complete shell off but more like a half and half. I've already done the back half and am in the process of separating the front now, if the weather cooperates.
1962 24' Oddball? Mark in Modesto 1959-69 Tradewind 36 03-30-2019 07:04 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
