Old 07-16-2018, 07:12 AM   #85
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by steinVT View Post
Pretty good? I would say it came out great. I am hoping to reuse my old wheel trim, but we will see.
How did you apply the heat? Aluminum is tough as it doesn't change color right up the point of melting it. A little scary.
Mark
I used a hand help propane torch. I just heated it up for maybe 10 seconds, just hot enough so I could not touch it. Then I just started bending it around a metal pipe until the radius was close. Once close I fitted it into the wheel well and used a leather hammer to tap it into place. Of course you have to use a lot of bad words otherwise it won't fit...
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 07-16-2018, 07:42 AM   #86
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Great Job
Fortunately my trim was in good enough condition to reuse. I thought about replacing it, but heating and bending new trim scared me off
DDickey
1957 Custom
Link to my renovation: http://www.airforums.com/forums/f44/...cy-150509.html
DDickey is offline   Reply With Quote
Old 07-25-2018, 05:35 PM   #87
1956 22' Caravanner
Windows...Time Sink
Today and I mean just about the whole day I worked at putting in my back escape window in. One of the problems I was facing is that the j hinge was cracked and not salvageable...after striking out numerous times in trying to find one or even make one, I decided to use aluminum piano hinge. The only real draw back I could see is that replacing the glass might be a PIA. Worst case scenario is drill the rivets out and replace. The other little challenge was the previous owner(s) thought the best way to fix a leak was to remove all the hardware and then caulk everything shut. IF that did not work then put more caulk on it and see what happens.
Anyway the trial fit seems to work out well, and now the next step is to get the gaskets in place, put the glass in and rivet it to the shell.
Oh yes and make a hinge cover...I have been check other threads and I have not seen one of these. Maybe it was something that was done on some trailers and not the others...feel free to chime in.
The pictures tell the story...
Old 07-25-2018, 10:17 PM   #88
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Escape Window
I had to do the same with my emergency window. After I installed it I found water would occasionally slip past the piano hinge, where the two pieces are tied together with the center pin. It's not a water tight connection. On mine the hinge point is far enough below the drip cap that if we have rain with wind in the right direction it gets wet and I'd get drips off the top of the window onto the floor.
My solution was to buy silicone rubber strip to lay on top of the hinge. I riveted it to the skin above and on the side of the window opening. just below the drip cap. Its flexible enough that it doesn't hinder opening the emergency window and lays flat enough to keep it tight against the hinge.
https://rubbersheetwarehouse.com/pro...edium-hardness
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-27-2018, 07:45 AM   #89
1956 22' Caravanner
Kiss
KISS- keep it simple stupid
Your idea is a lot simpler and quicker than the aluminum shield, and most likely a better solution. Thanks.
Old 07-29-2018, 07:40 AM   #90
1956 22' Caravanner
Luggage Door Opening
Some time in its long storied life the trailer had a blow out and this destroyed the luggage compartment door opening. So I had to do a little rebuilding, but its coming along . I hope to get the door done before I head out on our summer hiatus for the next 8 weeks.
Blow out damage
Before
After
Old 07-30-2018, 08:16 PM   #91
1956 22' Caravanner
Moving Day
Getting ready for hurricane season...so time to move Audrey to a safe place under the house...
Old 07-31-2018, 09:44 AM   #92
I tow where I'm told.
MrRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Itís good to have a secure place for the AS during H....... season. Our 2004 picked up a few extra dents and dings during Irma last year. We are considering hitting the road when the next one makes a direct strike to Central Florida just to prevent unnecessary damage to it and the 48 Liner.
Safe Travels!!
Tim
MrRivet is offline   Reply With Quote
Old 08-01-2018, 06:59 AM   #93
1956 22' Caravanner
Originally Posted by islandtrader View Post
getting ready for hurricane season...so time to move audrey to a safe place under the house...
The safe place...
Old 10-18-2018, 06:56 AM   #94
1956 22' Caravanner
Yikes...Look at this!
Well after a summer hiatus we are now back in Florida. Time to get back working on the AS.
Before we left (the first week in Aug.) I put in the back window/screen for a trial fit. The glass was out. Anyway the screen was exposed to the outside air and within two months it is rusty as all get out. Now I do live on the intercostal waterway and I am about 1/4 mile away from the gulf of Mexico but gee whiz this is a little disturbing how fast things go to hell around here.
I think before I mount anymore screens and windows I will spray them with eastwoods Aluminum spray rust encapsulator. Then for the door I think I will use the bronze screen...more extra work...
Old 12-29-2018, 03:13 PM   #95
1956 22' Caravanner
Back in the saddle. Finally
As the saying goes life gets in the way...Wanted to get going on this in November when we were finally back home. However home remodeling and a boat that needed some TLC, plus the holidays...UGH
First thing I wanted to get done is replace the curb side rear panel and the back panel. They were too lumpy and beat up to try fixing.
So Today I took advantage of some free labor (son in law) as his family are staying with us over the Christmas break.
He started with the rivet tool remover and I followed up with the drill and punch for the ones that did not pop. This job really goes much faster with two people.
Hopefully before the end of the year I can cut the patterns and then install.
I plan on sealing the seams with a good shot of silver tempro and then use flex seal on the back side.
Old 12-29-2018, 04:56 PM   #96
1966 22' Safari
Fredericksburg , Texas
I thought you dropped off the earth. Glad youíre back at it. I think a lot of Renovators look at the exterior skin and figure itís better to replace now than not do it and wished you had. Smart move. Ask your son in law if he would like to drop by central Texas on his way home. I need an extra hand shellacking the cabinets. Looking forward to seeing your progress.
Bubba L is offline   Reply With Quote
Old 12-31-2018, 07:00 AM   #97
1956 22' Caravanner
Replacement panel
Originally Posted by Bubba L View Post
I thought you dropped off the earth. ...
Not quite that far but off the AS Radar Screen...LOL
Made a little progress yesterday...laid out the new aluminum and then trace the old panel.
I think I have every known sheer to man. However what I found that seems to work well is scoring the aluminum 7-10 times and then using a wide blade fat max sheer.
I have an electric dewalt metal sheer and that thing is a PIA to use. I wish I knew the trick to using that thing...
Now the fun part, lining the panel up, drilling the holes and then figure out how to spread the tempro 635 without making a complete MESS
Old 12-31-2018, 09:42 AM   #98
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
I've always wondered what the Airstream would look like it we only polished the lower/upper half. Thats a great visual of your shiney lower right rear with the oxidation on top. Now we know. Thx
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Audrey :: 1956 Airstream Caravanner islandtrader Airstream Registry Discussions 0 06-08-2017 08:01 AM
'75 Ambassador Extreme Reno Starts Now bedfords 1974 - 1979 Ambassador 91 09-06-2016 01:14 PM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
