Old 05-15-2018, 06:48 AM   #71
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Milestone
It's looking great!
DDickey
1957 Custom
Link to my renovation: http://www.airforums.com/forums/f44/...cy-150509.html
DDickey is offline   Reply With Quote
Old 05-20-2018, 07:57 AM   #72
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Water Testing
Before putting the shell back onto the frame I thought I would do some water testing and sealing. This way most of the crud is still on the ground and not on my brand new floor...LOL
What is interesting is that the end caps showed no sign of water intrusion and after a good soaking still were good. The only leaks so far are where they were before...did some blue pad die grinding to get the corrosion off and then sprayed the seams with leak seal...this stuff works great. It also comes in a clear formula, which might come in handy for quick repairs on the roof. I also have a quart of flex seal that someone gave me and will use this to coat everything that has a hole in it.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 06-02-2018, 02:51 PM   #73
1956 22' Caravanner
Lift on...
Finally got the shell back on...just in time for hurricane season. Putting the shell on is always a PIA. No matter how you plan it there is always a rivet or stray pieces of aluminum that hangs you up. It seems like you kick, push, shove and say bad things about somebody's mother. Then like some miracle you hear a loud noise and everything is solid. I do have to say when that shell is on the frame it is rock hard no jiggle...
A couple pictures showing the inside. I hard mounted the shell to the frame at four points. Now all the fun begins putting the 600 rivets in that I took out oh so long ago...
Off on a river cruise for the month of June so no more action til July.
Old 06-02-2018, 04:39 PM   #74
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Shell on
Congratulations! Shell on is a milestone for sure
DDickey
1957 Custom
Old 06-02-2018, 06:07 PM   #75
1966 22' Safari
Fredericksburg , Texas
You sure have come a long way. Glad the shell dropped back on without issue. I think that was my first initial big concern. But I found that there are a few concerns after the shell goes back on. I love challenges. All is looking great. Keep the progress going. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 06-03-2018, 05:03 AM   #76
MsRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Send a message via Yahoo to MsRivet
Woo-hoo and a yiiipppeee ki-yay!!! Good job! We can't wait to get to this point on ours. That point will be a sigh of relief. One question . . .
Did you do anything special to the decking joints? What type of joint did you use?
Safe Travels ~
MsRivet
Not all those who wander are lost.
Living the Dream ... Plan B
The 70 year journey of our Airstream Liner . . .
https://www.airforums.com/forums/f60...ey-176336.html
MsRivet is offline   Reply With Quote
Old 06-03-2018, 06:24 AM   #77
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Congratulations, can't wait to see the rest!
chrisetmike is offline   Reply With Quote
Old 06-03-2018, 07:46 AM   #78
1956 22' Safari
Williston , Vermont
I can only imagine how good that feels. Going to be a long time until I am there. At least I don't usually have to worry about hurricanes, only snow.
Congrats, Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old 06-03-2018, 08:59 AM   #79
1956 22' Caravanner
Not sure I understand the question fully. All boards and edges were epoxy sealed and painted. The joints on the sub floor are just butted up to each other with a bead of silicone caulk to water proof them. The C channel has a moisture barrier between the channel and the floor. And the sub floor also has a barrier on it floor to frame...hope this helps.
Old 06-04-2018, 04:15 AM   #80
MsRivet's Avatar
1948 22' Liner
1963 22' Safari
Oakland , Florida
That answered my question. Thanks so much! Some, and thatís only a handful of people, have added wood cabinetry biscuits to the subfloor joints. Preventing vertical movement across the width of the long subfloor joints. Overkill? Probably. We are not far from adding the new decking subfloor onto the new frame. Just polling what others have done.
Enjoy that river cruise!
Safe Travels ~
MsRivet
Old 06-05-2018, 01:06 AM   #81
1956 22' Caravanner
The neat thing about the forum is that you do get a lot of ideas. I saw the biscuit thing (and I am a wood worker) and said really? If you look at the number of bolts going through the sub floor I do not see how there can be any movement. That being said my wife has accused me many times of over engineering things on past projects. So you pick your battles....good luck.
Old 06-30-2018, 02:27 PM   #82
1956 22' Caravanner
New Tow Vehicle
Needed to move the airstream from outer bay to the middle bay for more room...
So much easier with the golf cart...
Old 07-15-2018, 08:45 PM   #83
1956 22' Caravanner
What A PIA
After buck riveting the body to the c channel ...the next little challenge is putting the wheel trim on. Three hours oh what a PIA😂...you have to cut the c channel and then heat it up. Then hold your breath while you bend it and hope it does not kink...all said and done. It turned out pretty good..
Old 07-16-2018, 03:35 AM   #84
1956 22' Safari
Williston , Vermont
Pretty good? I would say it came out great. I am hoping to reuse my old wheel trim, but we will see.
How did you apply the heat? Aluminum is tough as it doesn't change color right up the point of melting it. A little scary.
Mark
Audrey :: 1956 Airstream Caravanner islandtrader Airstream Registry Discussions 0 06-08-2017 08:01 AM
'75 Ambassador Extreme Reno Starts Now bedfords 1974 - 1979 Ambassador 91 09-06-2016 01:14 PM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
