Old 09-13-2017, 02:16 PM   #29
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by Aerowood View Post
Any damage or just moved over a bit.
Just moved over a wee bit...a friend of mine just pushed back to the original position. As you can see it could not go any farther and would not of fell off the frame as the chain hoist was holding it from the top.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 09-13-2017, 07:09 PM   #30
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Wowwwwww
Seems like you did indeed dodge a bullet
DDickey
1957 Custom
Link to my renovation: http://www.airforums.com/forums/f44/...cy-150509.html
DDickey is offline   Reply With Quote
Old 10-17-2017, 06:17 AM   #31
1956 22' Caravanner
Originally Posted by islandtrader View Post
Living in southwest florida and on a barrier island at times it can be perilous. We normally leave in August and come back early October. This is the best time to see the rest of the U.S. when our weather sucks. We always button up the house for hurricane season. Not to bore anyone with the facts, but we were only 50 miles from the eye, and were in the bullseye until it turned and hit Marco.
The Airstream was tied down but this picture should tell you something.
Attachment 294752
Now that I am back home I had a chance to look at the Airstream and assess any damage. None to speak off. However what is really interesting is how the wind of the hurricane does change direction once it passes over your area.
The picture above shows the shell being blown to the east...meaning wind off the gulf...Now picture number two shows some minor damage to the eye brow on the west side of the trailer. Meaning the trailer was first blown west, then east. Oh well I'm really happy that this was the extent of the damage.
Old 10-23-2017, 06:36 PM   #32
1956 22' Caravanner
Done...
Well I think I am completely done taking everything off the A/S...with the exception of an eyebrow or two. Now hopefully the “more” fun will start by doing construction 🔨 instead of de-construction I wonder if bucking all those rivits in will get as boring as taking them out.LOL
Old 11-11-2017, 06:22 AM   #33
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Tanks
Hey islantrader,
I realized last night that I told you something a little different than what I ended up doing with my tanks. I have three waste tanks, two grays tied together in the frame with a black tank in the middle of them. Originally, the aft gray tank was going to handle the shower and the sink, but I decided to rearrange my bathroom and now the aft tank only handles the shower (the pic omits the fore gray tank), and the fore gray tank will handle the kitchen sink and the lavatory. The key to making it all work was to raise the bathroom floor 3" over the frame.
DDickey
1957 Custom
Old 11-12-2017, 09:12 AM   #34
1956 22' Caravanner
Originally Posted by DDickey View Post
Hey islantrader,
Thanks...this is what I am doing, a little like yours, but in different configurations
Name:	Scan 173160003-7.jpg
Old 11-15-2017, 08:12 PM   #35
1956 22' Caravanner
Fabrication and repair
Today I needed to repair some c channels that were bent up for god knows what reason.
I cut out the destroyed ones, and then got my brake and got to work. After making the new channel I sistered them in,and now I’m all set to move on to the next repair
Old 11-27-2017, 10:03 AM   #36
1956 22' Caravanner
I wonder why?
While up north for the thanksgiving holiday I was looking at a few of my b4 AS photos and my wife and I always wondered why Airstream never continued the bottom trim piece all the way to the wheel wells...so I did a quick touch up to see what it would look like.
We like the look...
Old 12-09-2017, 07:43 AM   #37
1956 22' Caravanner
Low Rider !
Today was the day to pull the frame out from under the AS. My tanks (grey and black)came in, so now it is off to the welder to have him put in some brackets to hold them and also do a few other things that I did not notice the last time I took it there.
I am lucky that I can lift the AS on and off by myself, and that really has been great especially trying to get everything to fit. Now with the body on rollers, it will be easy to work on the top and start chasing down leaks...
I love this slammed look....goes back to my hot rod days....
The golf cart makes pulling the frame easy.
The two grey tanks in position.
Old 01-04-2018, 05:21 AM   #38
1956 22' Safari
Williston , Vermont
Lifting the Shell
Thanks for taking the time to make these posts. I am about seven months behind you in restoring my 1956 Safari. Unlike you I live in Vermont were it is now 15 degrees, up from -10F a couple of days ago. Prior to the cold weather we got our trailer stripped and the floor removed. This coming spring we will be separating it from the frame because I have exactly the same frame problems you did.
A couple of questions about your lifting mechanism:
1. On early photos you appeared to have tied the two sides of the trailer together with 2x4"'s ? screwed into the ribs? There seemed to be a bunch of them with some upward angled braces as well. In later photos they seem to be gone, not needed?
2. One one picture it looks like you are pulling against a 5/4" x 6" x 12'? board against the roof with your chain hoist. I am assuming that was through the center vent panel?
When we get these trailers done we should make a swap. You come up here in the summer and we'll visit you in the winter.
Mark
steinVT is offline   Reply With Quote
Old 01-05-2018, 07:45 AM   #39
1956 22' Caravanner
Mark
#1...you are correct, after crawling around I saw that I only needed 2. I screwed the 2x4 into the ribs flush to where the floor would be. That way every time I need to check the fit they will not get in the way.
#2...Yes pulling through the center...I was lucky to have the beam...with a chain hoist I can raise and lower anytime and check the fit...
#3...anything is possible...
Old 01-07-2018, 08:40 AM   #40
1956 22' Caravanner
New Wheel Wells
For the life of me I can not understand why AS in building an all Aluminum trailer put in galvanized wheel wells. Mine were shot...one from rusting out and the other from a blow out.
I found a HVAC shop that made some up for me. I had them done in Aluminum. The shop used what they build pans out of here in florida in the salt air on the gulf. It is heavier than the outside skins by a gauge or 2. Plus they are coated to keep them from corroding. I actually put paint stripper on the coating and it did not come off. So I think these will last for some time...
Blow out...
Old and New
New
Old 01-07-2018, 09:29 AM   #41
1966 22' Safari
Fredericksburg , Texas
The wheel wells look great. Wished I would have thought of that. My galvanized ones were in decent shape so I sanded them down and used Por 15. I hope they hold up. Keep up the great work and the informative posts. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 01-13-2018, 07:09 AM   #42
1956 22' Caravanner
1 step back 2 forward
Just to rehash...last spring I took the frame in for repair. New A up front, some patches and out riggers. Very happy with the work. Brought it home, cleaned it up and then used POR15 silver. Since the frame was not to see UV no top coat was applied over it. Fast forward the por15 did not hold up very well rust is showing thru, and boy did it yellow even though it was not in the sun.
Back to the welder to install straps for the grey and black water tanks. Brought it home pressure washed it and some of the por15 peeled right off. Por15 does not go over rust oleum primer well. No big deal only a days worth of quick sand an two cans of Eastwood rust aerosol encapsulator product (which i like better). And the trailer looks good again. Now I can start on the c channel and belly pan.
Oh yes I decided to put in a "hidden" false floor...to store things that should not be seen by every one...Click image for larger version
How the black water tank sits...
Audrey :: 1956 Airstream Caravanner islandtrader Airstream Registry Discussions 0 06-08-2017 08:01 AM
'75 Ambassador Extreme Reno Starts Now bedfords 1974 - 1979 Ambassador 91 09-06-2016 01:14 PM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
