Old 06-29-2019, 08:55 AM   #141
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Screen Door
I think this is it for the completing the door.
I never did like the concept of riveting the screen part to the door to the back side of the door. If you have to replace the screen that means popping off the rivets and re riveting the screen back in.
My solution was to go to the Depot and buy a make your own screen frame and some aluminum screen. Insert this into the door and have the screen spline show out ward so you could change the screen easily. All went well with the exception of the aluminum screen...I just could not make it look good sitting in the frame. So plan B was use the fiberglass screen. It works. Now I won't worry if the dog or grand kid punches it out.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 06-29-2019, 11:59 AM   #142
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Great idea, I like the ability to replace without disassembly.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-05-2019, 08:15 AM   #143
1956 22' Caravanner
Inside Panel Replacement
When I first got the Airstream I thought I would pull the original panels, strip them down and repaint.
After trying every paint stripper known to man, I decided that I will not live long enough to strip everything off. Plus after removing 50 years of everyone else's modifications I decided that there were far to many hole to replace.Besides when you look at the pictures you will see for what ever reason the previous owners used about a 100 slotted head screws to re fasten the 13 panel...ugh what a PIA to remove.
My plan is a simple one...trace the old, cut and fit. Then treat the panels with Aluma Kleen, and then a light metals conversion, install and paint.
Hopefully I will get this done (everything except paint and install) before we leave this god awful feels like 110 heat for August and September .
Slotted heads to hold panel...??
Aluma Kleen
Light Metal treatment
I like the artsy pattern...maybe clear coat and keep it this way
The goto tool bag, that keeps me organized
Old 07-05-2019, 04:15 PM   #144
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Love it . And man that’s a nice paper weight. Heat and hurricanes, that is one thing I don’t miss . Keep up the good work , Blue .
Joyflea is offline   Reply With Quote
Old 07-06-2019, 05:40 AM   #145
1956 22' Safari
Williston , Vermont
I guess I didn't realize how lucky I was that all of my panels were the original Zolatone. Just rough them up with the DA and move on. And using screws instead of rivets, painful. The PO came from the school of "Everything looks like a nail if all you have is a hammer".
Nice work, you will have the newest antique trailer around with all the new aluminum.
It's hot in Vermont, I can't image what it's like in Florida.
Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old Yesterday, 07:55 AM   #146
1956 22' Caravanner
Trial fit
Just a few more pictures on the panels...definitely need 3 people to put up 4x12 panels.
Audrey :: 1956 Airstream Caravanner islandtrader Airstream Registry Discussions 0 06-08-2017 08:01 AM
'75 Ambassador Extreme Reno Starts Now bedfords 1974 - 1979 Ambassador 91 09-06-2016 01:14 PM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
