Old 05-06-2019, 06:31 AM   #127
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
More Patches
When deciding where to put my shore power hook up and city water line...I just could not force myself to drill new holes into an already holy AS. Even though it is more mid ship than I would like. I decided to patch a opening that was already there, by installing my hook ups there.
All in all my wife likes it and that's ok by me....
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 05-08-2019, 02:01 PM   #128
1956 22' Caravanner
Insulation
After over analyzing everything on insulation I decided to use 3/4" Poly Foam EPS. Instead of trying to keep heat out, I am going to try and keep the cool in. There is only so much you can with 1.5 inches of space. The wiring will go on top of the insulation. Again pro's and cons but hey it is my trailer...
What I do like about installing the stuff is that you don't have to be to exact on size. And you can use almost every bit of the 4x8. If you cut short you just cut a scrap piece shove it in and then tape it up. I also am taping every seam.
Todays work the back 13 panels.
Old 05-18-2019, 06:57 AM   #129
1956 22' Caravanner
Another Milestone!
Nothing earth shattering...just finished 99% of my insulation. Only left the rear sections open where the tail lights and license plate will be installed.
Used 11 4x8 sheets of 3/4 inch eps, about 20 tubes of adhesive and one roll of foil tape.
Now on to the next challenge W I R I N G
Old 05-20-2019, 06:36 AM   #130
1956 22' Caravanner
Wiring
I forgot how many feet of wire any vehicle takes when you re-wire something. Just for starters I ordered 200 feet of wire. I used over 150 feet on just the trailer lights alone.
I did heat shrink disconnects on all the lights just as a ease of replacement. Most likely will do all connections on the dc end with disconnects.
Also installed the fresh water tank inlet. Small steps but really pushing hard to have wire and plumbing done b4 our summer hiatus ...
ID:	341209 Click image for larger version
ID:	341211 Click image for larger version
Old 05-21-2019, 05:48 AM   #131
I tow where I'm told.
MrRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Outstanding progress! Getting past those huge “Milestones” is always a great motivator.
Safe Travels!!
Tim
MrRivet is offline   Reply With Quote
Old Today, 07:43 AM   #132
1956 22' Caravanner
Another Hole Covered
Just got this louver panel from joyflea...it really is a lot nicer looking than the standard stuff you can buy.
Audrey :: 1956 Airstream Caravanner islandtrader Airstream Registry Discussions 0 06-08-2017 08:01 AM
'75 Ambassador Extreme Reno Starts Now bedfords 1974 - 1979 Ambassador 91 09-06-2016 01:14 PM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
