Old 01-12-2018, 02:37 PM   #1
Portland , Oregon
How to level 1957 22'
It's me again. I'm planning on keeping her on a driveway that has a slight incline. What's the best way of doing this? It has an icebox instead of a refrigerator (cute, but not sure if that'll be enough) so at least I don't have to worry about it catching on fire.
I also need to add that I've never had an Airstream, any other RV and am pretty green when it comes to mechanical work. I'm going to want to know so much!
Anything is much appreciated!
P.S.
A little off topic, but does anyone know what difference between 13 and 7 panels is?
tomifost is offline   Reply With Quote
Old 01-12-2018, 04:41 PM   #2
1966 22' Safari
Fredericksburg , Texas
Airstreams went from 13 panels to 7 panels in 1957. Google Vintage Airstream Photo Archives and enjoy the reading. A good visual of changes over the years. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 01-12-2018, 08:00 PM   #3
2007 22' International CCD
Originally Posted by tomifost View Post
———-snip———
P.S.
For one thing, there are a lot fewer seams to leak. The current stretch formed caps don’t look as iconic as the many riveted segments, but there is a lot less to get leaky this way.
Gotta admire the work and craftsmanship it took to make the 7 and 13 segment ends, though.
Old 01-13-2018, 06:40 AM   #4
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Depending on the slope...I would get 4 of theses....
https://images-na.ssl-images-amazon....L._SL1500_.jpg
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 03-07-2018, 06:42 AM   #5
Portland , Oregon
Where do you recommend placing them? I just got my 57 and imagined a frame on the bottom, but nope. Aluminum bubble all around except for hitch and bumper. I've been living in it and the sway is starting to warp my perception of the ground.
Old 03-07-2018, 07:13 AM   #6
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Follow the rivets
There is a frame hidden above the belly pan. Rivet lines will indicate the frame member locations.
BambiTex is offline   Reply With Quote
Old 03-08-2018, 06:21 AM   #7
1956 22' Caravanner
Some idea of the frame structure....
Old 03-08-2018, 07:49 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
P.S.
You asked about leveling:
1. Level the trailer from side to side using either wood or plastic blocks beneath the lower side's tire to elevate them to equal elevation/levelness.
2. Use the tongue jack to level front to rear, after leveling side to side.
You mentioned movement of the trailer in another post:
1. Those jacks that can be added to the trailer are not jacks for lifting the trailer. They will lift the trailer, but doing so might bind the door and/or overstress the structural parts of the trailer. Use those jacks for stabilizing, not lifting or leveling. (I think every Airstream owners manual will tell you this)
Wheel/tire scotch blocks will also help with stabilizing and prevent the trailer from rolling downhill.
add edit:
This video explains it pretty well
https://www.google.com/search?q=how+...&oe=#kpvalbx=1
add edit 2:
7 or 13 panel; when standing at the end of the trailer count the number of individual panels you can see. Older models have 13 flat panels riveted to create the curves. Newer 7 have pre-formed radius panels at the curves. If the center panel over the window is shaped like a fish's tail, that one is a "whale tail".
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
No kidding. How level is level? upnorththree Towing, Tow Vehicles & Hitches 19 03-25-2017 01:14 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
