Old 05-09-2014, 10:59 AM   #533
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Steve, so nice to see a post an update and glad to hear how you and Brissy are doing. Your pictures are beautiful. We had just talked about you at the Vintage Trailer Academy while discussing various heaters.
May we ask why you took out your Hep-Vo filter, as we just installed two of them.
Take care.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-09-2014, 11:29 AM   #534
pbearsailor's Avatar
Port Hadlock , Washington
Mine was in the galley and it was difficult to keep clean over time. It was fine for the first year or so, but then it started draining slowly and the sink drain had that gray tank smell. Maybe just me as there are a lot of them in use.
Cheers,
Steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 05-09-2014, 11:51 AM   #535
1961 28' Ambassador
Mesa , Arizona
Thanks for the response. We just learned from a restorer at VTA that the Hep-Vo works best horizontal which is how the shower was installed and seems the second one is not in yet. Although the packaging shows both horizontal and vertical installation and say' s venting is no longer needed maybe venting is still needed.
Thanks for your input.We will keep this all in mind when/if we install the second one.
Safe travels and if you are in Arizona this coming winter the 4CU unit has several rally's during the season.
Hittenstiehl
Old 05-09-2014, 12:37 PM   #536
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Attack cat?
I'm shakin' in my shoes!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-09-2014, 01:23 PM   #537
Originally Posted by m.hony View Post
Attack cat?
I could tell you stories, but she'd kill me.
Old 05-09-2014, 04:05 PM   #538
2013 Int. Sig 23D
Rrroberts40's Avatar
2013 23' International
Des Moines , Washington
Hello Steve, been on the site for a while but never came across your story until today...I read thru it from the beginning and while it has been some time for you It has all happened for me in one day...I am so sorry for your loss and just wish to tell you that the rebuilding of your trailer is just plain inspiring...My wife and I are heading up to Brinnon Dosewallips campground on Tuesday and thought we would swing thru Oak Bay and see you & your wonderful trailer if time allows...I see there is a upper and lower area there so which would you be staying in? Your story over that 4+ year period was great and perhaps a book could be in your future? Anyway if we can we will swing thru and say hello...thanks for the truly great share!
Russ & Leslie Roberts
Rrroberts40 is offline   Reply With Quote
Old 05-09-2014, 04:28 PM   #539
Absolutely Russ, come on by. I'm in the upper and you'll see us as you come in the entrance. Weather looks good for next week so Dosewallips should be nice.
Thanks for your nice words. This forum was a big part of my support network during that time. 'Tis a very good group around here
Old 05-09-2014, 06:43 PM   #540
tallytwo1994's Avatar
tallahassee , Florida
Originally Posted by pbearsailor View Post
Letting my old thread slide again. But a thousand nights in a row in this old trailer is pretty good isn't it? Brissy the cat and I have now done one difficult winter in Washington state and two much easier winters traveling as far south as Organ Pipe National Monument on the Mexican border. We've probably put something like 5000 miles on it each winter. For the summers, I'm just started the third one as a campground host at Oak Bay, a small county park south of Port Townsend.
Full timing in a 22' fifty seven year old trailer has been just fine. All the systems work the way I had hoped they would and most importantly Island Girl has been just about totally reliable. I had a pressure water pump fail, but it was already a few years old being sourced from my boat. A couple of months ago I saw one of my door side windows flapping in the wind going down the road. The crank arm, one of the originals, had broken and was a five minute fix with a spare onboard. One Bal jack screw has stripped out and I haven't come up with a good and easy fix for that. Good I can see how to do, but easy is proving harder. I also replaced the HepvO valve in the galley with a conventional P trap and air admittance valve. Special mention for being absolute crap is the plastic latch for the RM2510 fridge which is now up to three spring failures.
Solar. I liked solar a lot on the boat and I like it even more on the trailer. I started with two panels taken from the boat with a 110 watts total and I was OK for the first two years, but I had to be careful. Last fall I stopped at AM Solar and replaced my panels with two 100 watt panels. I already used their mounts with the 3M tape. I had plenty of power all winter and only had electrical hookups for maybe three nights. I am careful with use, have all LED lights and don't run any high power items. I do rotate the panels into the sun with the AM Solar arms if parked for a few days, but I do fine even with them flat.
I did buy a Honda eu2000i generator. This winter it was used exclusively to run the microwave and the all important espresso machine. The generator is great, starts on the first pull always, and is quiet. Even though I do not depend on it, I'd never consider buying a cheaper generator. The campground host in me hates to see anything other than Hondas and Yamahas.
The Dickinson Newport heater. I had the diesel version on the boat, but always envied the folks that had the clean and easy to light propane model. Now that I have the propane version on the trailer, it's been as good as I'd hoped. There's no ducting like a furnace, so I do have to be a little careful with my tanks below the floor, but it's been fine in temperatures down to 20 degrees or so. It is colder back by the bed and warmer up front but that works fine. It usually gets turned off at night unless it's below freezing and then it runs all night. The 12 volt power draw is extremely small which is a big reason solar works so well (no furnace blower to run).
Internet is with Millenicom with a MiFi running through an external antenna. Millenicom just had a price increase making it not quite the great deal it was, but I still like the ability to have internect without a contract. About the only place I haven't had coverage in my wanderings has been Joshua Tree. It's probably good for me to be forced off the internet a couple of weeks a year when I'm in there.
The awning has been great--makes the trailer bigger. It has an aluminum tube in it along the long edge that is used to roll the awning for storage in a bag mounted on the awning rail. It takes maybe a minute to roll it up when the wind gets too strong and that was the goal when we made it. It gets used if it's easy to setup and storing it on the trailer means I don't have to find a place to store it.
Appreciate those of you who have posted in this thread. Apologies to those recent ones I haven't responded to.
I was so happy to see an update on this thread in my inbox. Been missing you. So good to hear how you've been doing, and every now and then I can just picture myself traveling your way to see your sweet Island Girl in person. BTW, I agree with Robin that those photos are the best. Thanks, Steve.
Carol
tallytwo1994 is offline   Reply With Quote
Old 05-09-2014, 07:50 PM   #541
nmbosa's Avatar
Nowhere , Washington
Yes, Norm, been here about a month. Only one fifth wheel in the campground tonight, nice and quiet here looking out over the water across the sound towards Edmonds. Come on up when you can.
Cheers,
Hmm. Been looking for one of those trips you can start early on a Friday. I'll see if I can get up there in the next month.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 05-10-2014, 08:21 PM   #542
Chlyman's Avatar
1958 18' "Footer"
Danville , California
Hi Steve,
Thanks for the update!! I am modeling my '57 Caravanner after yours, so I really appreciate you giving an update. I do have the same solar that you bought originally and am hoping that will be just fine with our part time usage. I feel I can always supplement with portable panels as well. I do have a hepvo for the shower, but have not installed it yet. So that is good information about the smell yours was emitting. Maybe a shower would not have the same problems, but maybe not. Hope you have a great summer, and when I am done with mine, I hope to travel up North to visit maybe.
Thanks again,
Carolyn
Carolyn
1956 Caravanner Forum link
1958 Traveler 18 Footer Forum link
1955 Kenskill Rebuild link
Chlyman is offline   Reply With Quote
Old 05-11-2014, 06:36 AM   #543
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Nice to see your update Steve, it looks like the miles in Island girl have been good, with many new adventures. Hope you have a great summer! The nights we spend in Nellie are and the miles we drive to the next destination are more exciting every year!
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 05-23-2014, 08:20 AM   #544
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Hi Steve
Glad to get an update on your travels and extended road testing of the trailer. We have shelved the 57' Custom project until a workspace and other obligations are resolved. But I still blame you for causing our belated attraction to this era AS and that fact that it ended up it our yard.
But this will allow more time to collect materials and parts until the right time comes around.
Then I will have to read Island Girl thread again from the beginning.
Thanks for the update and keep it up.
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
Old 05-23-2014, 10:14 PM   #545
Blame accepted.
Old 05-30-2014, 11:31 PM   #546
Chlyman's Avatar
1958 18' "Footer"
Hi Steve, can you tell me how you feel about the layout? The wet bath in particular. Do u feel there is enough room in there? Anything you would change about the layout?
Carolyn
Carolyn
1957, 1957 caravanner
who will be first to turn an AS into a boat? Aage Off Topic Forum 11 02-27-2013 11:38 PM
We had a great first trip! MUg Member Introductions 5 10-11-2012 08:03 AM
First-timers - If I had it to do over again... kudzu Community Polls 16 11-08-2006 11:02 PM
She's no Zip Dee - but she'll do..... GT1963 Awnings 3 05-12-2004 03:43 PM
Take your final ride in an Airstream... InsideOut Our Community 7 09-22-2003 01:50 PM
