Old 04-20-2011, 05:58 PM   #337
pbearsailor's Avatar
Port Hadlock , Washington
Originally Posted by mello mike View Post
I do have a question for you. Where did you get the exterior vent fitting for your fresh water tanks? I need something like that for my '58 Overlander. I'd also like to see how you connected the vent tube to your fresh water tanks. Did you use a reducer for this?
Most of the stuff for the water tank vent came from West Marine. The vent fitting is this one and I used reinforced vinyl tubing from there too. They even had the 5/8" to 3/8" inch reducer as well. My fresh tanks are stock Valterra ABS tanks and they'll be individually selectable, so one vent can work with both tanks, one line T'd off. I used the Valterra fitting kit for the tanks and it comes with a 1 1/4" barb for the fill line and a couple of 3/8" barbs for the feed and the vent.
Figured all that would end up being a hassle, but it was no problem, but it makes it easy having a West Marine a quarter mile from where I live.
Hope that helps.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 04-21-2011, 05:32 AM   #338
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hope that helps.
-steve
Perfect, thanks Steve. You can sure get some great stuff from West Marine for your Airstream.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-21-2011, 08:02 AM   #339
Originally Posted by Aage View Post
Nice work, Steve. From your use of red and blue pipe, I'm guessing you have a water heater too. Do you plan on making a bypass for that, for winter storage?
Ummm, forgetful in the describing, but not quite as much in the doing. Yep, it has a bypass installed, just waiting for the Pex to get there. Thanks, Aage.
-steve
Old 05-04-2011, 08:30 PM   #340
Wrapping up the sewing
We've got the curtains all sewn and installed. They have made a huge change in the trailer.
Since Jim had his machine in the trailer, we decided to do a cover for the mattress with Sunbrella. That was a pretty big and sometimes scary project, but we're both happy with the way it turned out. We have excess curtain fabric, so we'll make up a few throw pillows for the mattress with that.
And, in a measure of just how overconfident I'm getting with sewing, I bought an old Pfaff 130 machine on eBay with the idea that I'll make my own awning and outside window covers. That may or may not turn out to be a good idea.
On the plumbing front, the sewing has given me a good break from it again. Made a mistake in the galley by sliding the cabinet over to give me more access room. At least for me, the only way it can be designed is with everything in place. It can still mostly be assembled outside to give the crimper room, but I should have left the cabinet alone. At least it's easy to cut the copper crimps off and they're low cost.
ID:	129111   Click image for larger version
Old 05-04-2011, 09:45 PM   #341
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Nice work Steve, the color from the curtains is great!
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 05-17-2011, 07:29 PM   #342
Gas Plumbing and Water Plumbing
I still hate plumbing, but it's almost over. Fill lines for the two tanks and the sink drain remain to be done with the water. The pics show the layout in the galley with a few ball valves instead of check valves. The low point is right at the water heater and using the heater bypass, I'm able to get away with a single drain line for the system.
Double flares have been keeping me busy for a week or so. I've been lying under the trailer on rain and mud soaked cardboard surrounded by the state animal of western Washington, the slug. I put in shutoff valves for each of the four gas appliances. The propane system is all hooked up now, but the tubing still needs to be secured to the frame. I'd never done the double flares before, so it was scary turning the gas on this afternoon after the last connection was made. Had a couple of joints that needed another pull on the wrench and one just plain crummy flare that evaded my quality control and had to be replaced. Even though we've had temporary gas lines run for the heater for 2 years, it was still pretty cool to fire up the stove for the first time.
And, despite the rain, polishing has begun. Weather looks good for the next few days, so I'm planning on getting some more compounding done.
ID:	130061   Click image for larger version
ID:	130063   Click image for larger version
Old 05-18-2011, 07:01 AM   #343
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Steve
For somebody that hates plumbing you have done a first class job.
The polished area at the rear looks great! A nice contrast with the blue sky.
Dan
Old 05-18-2011, 10:06 AM   #344
nmbosa's Avatar
Nowhere , Washington
Fill lines for the two tanks and the sink drain remain to be done with the water. cheers,
We are seriously neck-and-neck Steve. I need to install the fill and vent for the fresh water tank after we get the dinette installed this weekend.
I also have have to run my vent lines for the gray tanks and black tank.
I may need to do some redesign on my fresh water plumbing this summer to make sure I can drain it properly for winterizing.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 05-18-2011, 08:14 PM   #345
Beautiful work, Steve. I actually enjoyed the plumbing, and I am appreciating the heck out of the work you've done.
And the rest of the interior is beautiful. Keep it up, you're not far off now.
Old 05-18-2011, 10:06 PM   #346
Originally Posted by TouringDan View Post
Steve
Dan
Thanks, Dan. We've had an unbelieveable 2 days in a row of sun with maybe two more coming. Going to be a lot of sunburn in the Pacific Northwest.
Norm
Yup, I forgot about the gray vent. Fitting is in, hole in the floor cut, but I still have to cut a scary hole in the top.
I got my fresh water fills out of the bargain bin at West Marine and I was happy to actually save some money, but they are 1 1/2" and the tank has 1 1/4" fittings, so I'll wind up spending the money I saved doing a silly reduction in the fill lines. Oh well.
Thanks Marcus! Norm and I are both pretty close, but I'll bet he feels like I do: there are still about a thousand little things still to do.
Best thing about the gas plumbing is that tomorrow the fridge will be able to run on gas. The boat has a fridge, but no freezer, so it'll be nice having it. Being able to keep ice cream will be a luxury we haven't had for many years.
Polishing with the compounder and F7 continues. Still amazes me how easily that 50 year old aluminum shines.
ID:	130142   Click image for larger version
Old 05-19-2011, 03:45 PM   #347
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
Inspirational
Steve,
Looking at your work makes me more eager to get on with the retrieval of our 57 Caravanner from Anchorage this summer.
We plan to complete the trip by Aug 1 and then get on with the work. Your well documented work with be a great reference.
Prickly Pear is offline   Reply With Quote
Old 05-19-2011, 05:00 PM   #348
Thanks Jim. I think we have a great model and a great year. They're pretty sweet trailers.
Stop by on your way back with yours. We're right on the border.
-steve
Old 05-20-2011, 10:47 AM   #349
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Steve,
You have a very great thread documenting some fabulous quality. I'm about to start doing some pex plumbing today. Your posts on plumbing are very helpful. Thanks for sharing all your great work here.
Lance
Top is offline   Reply With Quote
Old 05-20-2011, 11:02 AM   #350
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
All of your plumbing and gas lines look great. At work here we run miles of copper gas lines every year and have never heard of double flairs? but it all looks good.
The shine is coming along good also! Better keep your trailer locked up, it's a real eye catcher
1957, 1957 caravanner
who will be first to turn an AS into a boat? Aage Off Topic Forum 11 02-27-2013 11:38 PM
We had a great first trip! MUg Member Introductions 5 10-11-2012 08:03 AM
First-timers - If I had it to do over again... kudzu Community Polls 16 11-08-2006 11:02 PM
She's no Zip Dee - but she'll do..... GT1963 Awnings 3 05-12-2004 03:43 PM
Take your final ride in an Airstream... InsideOut Our Community 7 09-22-2003 01:50 PM
