Old 05-04-2011, 09:45 PM   #341
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Nice work Steve, the color from the curtains is great!
Doug
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 05-17-2011, 07:29 PM   #342
pbearsailor's Avatar
Port Hadlock , Washington
Gas Plumbing and Water Plumbing
I still hate plumbing, but it's almost over. Fill lines for the two tanks and the sink drain remain to be done with the water. The pics show the layout in the galley with a few ball valves instead of check valves. The low point is right at the water heater and using the heater bypass, I'm able to get away with a single drain line for the system.
Double flares have been keeping me busy for a week or so. I've been lying under the trailer on rain and mud soaked cardboard surrounded by the state animal of western Washington, the slug. I put in shutoff valves for each of the four gas appliances. The propane system is all hooked up now, but the tubing still needs to be secured to the frame. I'd never done the double flares before, so it was scary turning the gas on this afternoon after the last connection was made. Had a couple of joints that needed another pull on the wrench and one just plain crummy flare that evaded my quality control and had to be replaced. Even though we've had temporary gas lines run for the heater for 2 years, it was still pretty cool to fire up the stove for the first time.
And, despite the rain, polishing has begun. Weather looks good for the next few days, so I'm planning on getting some more compounding done.
ID:	130061   Click image for larger version
ID:	130063   Click image for larger version
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 05-18-2011, 07:01 AM   #343
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Steve
For somebody that hates plumbing you have done a first class job.
The polished area at the rear looks great! A nice contrast with the blue sky.
Dan
Old 05-18-2011, 10:06 AM   #344
nmbosa's Avatar
Nowhere , Washington
Originally Posted by pbearsailor View Post
Fill lines for the two tanks and the sink drain remain to be done with the water. cheers,
We are seriously neck-and-neck Steve. I need to install the fill and vent for the fresh water tank after we get the dinette installed this weekend.
I also have have to run my vent lines for the gray tanks and black tank.
I may need to do some redesign on my fresh water plumbing this summer to make sure I can drain it properly for winterizing.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 05-18-2011, 08:14 PM   #345
Beautiful work, Steve. I actually enjoyed the plumbing, and I am appreciating the heck out of the work you've done.
And the rest of the interior is beautiful. Keep it up, you're not far off now.
Old 05-18-2011, 10:06 PM   #346
Originally Posted by TouringDan View Post
Steve
Dan
Thanks, Dan. We've had an unbelieveable 2 days in a row of sun with maybe two more coming. Going to be a lot of sunburn in the Pacific Northwest.
Norm
Yup, I forgot about the gray vent. Fitting is in, hole in the floor cut, but I still have to cut a scary hole in the top.
I got my fresh water fills out of the bargain bin at West Marine and I was happy to actually save some money, but they are 1 1/2" and the tank has 1 1/4" fittings, so I'll wind up spending the money I saved doing a silly reduction in the fill lines. Oh well.
Thanks Marcus! Norm and I are both pretty close, but I'll bet he feels like I do: there are still about a thousand little things still to do.
Best thing about the gas plumbing is that tomorrow the fridge will be able to run on gas. The boat has a fridge, but no freezer, so it'll be nice having it. Being able to keep ice cream will be a luxury we haven't had for many years.
Polishing with the compounder and F7 continues. Still amazes me how easily that 50 year old aluminum shines.
ID:	130142   Click image for larger version
Old 05-19-2011, 03:45 PM   #347
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
Inspirational
Steve,
Looking at your work makes me more eager to get on with the retrieval of our 57 Caravanner from Anchorage this summer.
We plan to complete the trip by Aug 1 and then get on with the work. Your well documented work with be a great reference.
Prickly Pear is offline   Reply With Quote
Old 05-19-2011, 05:00 PM   #348
Thanks Jim. I think we have a great model and a great year. They're pretty sweet trailers.
Stop by on your way back with yours. We're right on the border.
-steve
Old 05-20-2011, 10:47 AM   #349
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Steve,
You have a very great thread documenting some fabulous quality. I'm about to start doing some pex plumbing today. Your posts on plumbing are very helpful. Thanks for sharing all your great work here.
Lance
Lance M is offline   Reply With Quote
Old 05-20-2011, 11:02 AM   #350
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
All of your plumbing and gas lines look great. At work here we run miles of copper gas lines every year and have never heard of double flairs? but it all looks good.
The shine is coming along good also! Better keep your trailer locked up, it's a real eye catcher
Old 05-20-2011, 11:18 PM   #351
Thanks, Top. Nice work you're doing too. You'll like the PEX.
Doug, as far as I can tell, RVIA code calls for double flares on the copper but I'll bet more trailers are using single flares. I used forged nuts as well and they seem much stronger than the normal flare nut.
-steve
Old 05-21-2011, 06:09 AM   #352
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
-steve
The heavy forged nuts are all that should be used, I have replaced a lot of the light duty ones that have cracked. Not sure why they even make those?
Looks Like you will be on the road soon.
Stop by if you are ever coming through Wisconsin.
Keep cruis'n
Doug
Old 05-26-2011, 04:40 PM   #353
Island Girl's Systems are Go
Not much actual work today, but a big step forward. Yesterday I moved the trailer near a faucet and filled our fresh tanks. Today, the water pump and water heater got their electrical hookups done. Note to self: always make sure that you've hooked up the wires to the circuit breaker panel before you wonder why the pump doesn't work.
No leaks at all in the PEX. There's a drip at the water heater drain that needs attention and one at the strainer basket in the sink. Easy fixes. I will never like plumbing, but the PEX with the copper crimps and brass fittings works really well.
So we've now got heat, a cold fridge, hot and cold water, and a stove all functional.
-steve
Old 05-26-2011, 08:15 PM   #354
-steve
Awesome, Steve. I love the "running water shot." For me it's right up there with the "standing on the ground through your trailer's frame" shot. Both are satisfying in their own way, though I probably have to give the edge to running water because it generally means we're closer to camping.
Keep it up!
Old 05-26-2011, 09:47 PM   #355
Thanks, Marcus! Yeah, the problem with the standing in the frame shot is that you aren't really sure at that point that you're actually going to finish. At least when the water's running you can be pretty sure the finish is coming.
-steve
Old 05-26-2011, 10:41 PM   #356
nmbosa's Avatar
Dang it! I forgot that shot during the brief period I had the plumbing finished. I'll have to remember that tomorow when I reconnect the toilet.
Seriously though Steve. Everything is looking great on your trailer and I can't wait to see it in person. We should try and meet sometime this summer.
Norm
Norm and Mary
Old 05-27-2011, 06:12 AM   #357
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
The running water shot is awesome! It marks a big accomplishment!
http://www.airforums.com/forums/atta...5&d=1306372284
Lance
Old 05-27-2011, 08:06 AM   #358
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I was recently workin on my "other" project... Aka the house and drove a nail thru a pressure line. It was a stub right at concrete level and I was dreading the whole sweating of copper, no room to work and coupling affair. Needless to say, I hoofed it over to Lowes and picked up a couple of Gatorbite fittings and some Pex. I kept my fingers crossed and dove into the job. No lie!... 5 minutes later and everything was right with the world. I LOVE those GatorBite fittings! Made me feel like a hero.
Phrunes is offline   Reply With Quote
Old 05-27-2011, 09:22 AM   #359
Ha! Isn't that the way of it?
Right now I have my water heater bypassed, since it sustained some freeze damage here in Austin over the winter. The gas valve and pilot assembly were just about shot anyway, so I've purchased a new water heater but have yet to install it. Not going to happen before my beach trip this weekend, either.
But I figure, with temps around 100, we won't really need the hot water anyway.
Old 05-27-2011, 10:16 AM   #360
241 days in a row below 70 degrees here.
-steve
1957, 1957 caravanner
who will be first to turn an AS into a boat? Aage Off Topic Forum 11 02-27-2013 11:38 PM
We had a great first trip! MUg Member Introductions 5 10-11-2012 08:03 AM
First-timers - If I had it to do over again... kudzu Community Polls 16 11-08-2006 11:02 PM
She's no Zip Dee - but she'll do..... 05ModPod Awnings 3 05-12-2004 03:43 PM
Take your final ride in an Airstream... InsideOut Our Community 7 09-22-2003 01:50 PM
