Old 05-31-2005, 08:47 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Ebay Trailer 1957 Caravanner
If I didn't have one apart in the drive I would get this and do the full monty. At least in the pictures the skin looks intact.
http://cgi.ebay.com/ebaymotors/ws/eB...category=50063
Over59 is offline   Reply With Quote
Old 06-14-2005, 08:20 PM   #2
Just picked her up
Over59, Hi, I just picked up the one you mentioned. She is now in NY and working her way to Florida this winter
58Caravanner is offline   Reply With Quote
Old 06-14-2005, 08:33 PM   #3
Over59's Avatar
Images: 37
Tells us all about the trailer. Did you tow it home from MI. I've always liked this size unit and all those windows. You'll find lots of ideas on the forum.
Old 06-15-2005, 06:30 AM   #4
funchucky1's Avatar
Riverhead , New York
That's why we have no vintage units here in New York.....all the ones that make it here...go to Florida!
Congrats on the new trailer!
funchucky1 is offline   Reply With Quote
Old 06-15-2005, 06:32 AM   #5
funchucky1's Avatar
Did I mention you'd better get started on that floor?
Old 06-15-2005, 07:33 AM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Congrats on your new-to-you trailer. That is truly a beauty and has tons of potential. The floor looks to be your biggest challenge. Welcome to the forums and vintage Airstreaming. This is the place to be.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-15-2005, 08:53 AM   #7
Over59's Avatar
Images: 37
If you have the time, space, skill and money then don't fool around with "patches". Go for it. Take a couple hundred pictures before you do anything and as you go along to remember how it all fits together. The insides come out easily once you find the few screw and rivets holding the stuff in, you shouldn't have to cut or break anything except some wires. Save everything until you are finished for possible reuse or patterns or to remember how it goes together. It is easier to remove the shell, fix the frame, and put on a new floor then to try to replace the floor in pieces. It is also way easier to take off the floor if the shell is out of the way. Also cut the new floor with the old one in place as a template before you take it off. Learned this OTJ also. You really need to get a good hammer tapping look at that frame, repair and mod it and likly a new axel with full wheel setups. This will be an expensive project, but you will have the finest $ 10,000 AS around and it will be good for another 50 years. Start your own thread and post what you are about to do and what you have done. Folk will jump in with their own lessons learned. There are those that do it and those that talk about it. Welcome to the other side.
Old 06-15-2005, 09:28 AM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Originally Posted by Over59
.....find the few screw and rivets holding the stuff in.... Welcome to the other side.
59, you're killin' me! But he is exactly right. It's a bunch of work, but extremely satisfying and rewarding along the way. And he's exactly right, those of us that have them in various stages of repair all over our backyards/garages/patios/etc do live on the other side. When I first started the 'Monty, I thought I must be nuts, but as time (and refurbishment) goes on, it's turned out to be a great experience. Good Luck!
www.nesa.org
Air No. 6427
Old 06-21-2005, 08:22 AM   #9
all the advice
Hi, Over59, that is exactly the plan I had in mind. Remove everything and the floor does need to be replaced. Then I am using the old as the patterns for new.
As far as my Florida comment, the plan is to work on it there this winter, and eventually have her(Cara) in Maine for the summers. At least for the first few years and then see what happens.
The first item I am working on is the door. It had the door knob style. It works like a regular door, except it has a bold in it. I was going to talk with the local locksmith to see what they could come up with. I found Weiser doorknob and it was only brass or antique brass. Not really what I wanted. I also need a hinge on the screen door. I have one, but need the second one.
So if anyone has advice, please pass it on, and I will start a thread when I begin... I was also going to put a web site up with all the updated pics as I go along.
thanks for all the help!
Old 06-21-2005, 09:45 AM   #10
Over59's Avatar
Images: 37
Don't throw anything away until you are finished. There is some nice woodwork in that which may refinish real pretty. Good Luck. Hope is works out for you.
1957, 1957 caravanner
