Old 12-06-2009, 08:24 AM   #1
1959 22' Caravanner
candler , North Carolina
'59 Caravanner renovation
Well for about a month now I have been working on my 59'. Frame, floor.yadda yadda. I am putting in a grey tank ( INCA Plastics H-147) and I was going to use PVC pipping for waste lines, or should I use the black semi flexible 1 1/4" hose like it was done originally?? Thanks, many more pictures and updates to come. I have read and learned alot from all of you doing the total renovation thing.
jeffinwnc is offline   Reply With Quote
Old 12-06-2009, 09:07 AM   #2
Images: 59
I used ABS. But if you want to reuse any of the original rubber hose do so.
You can't argue against something that looks that good after 50 years.
Thats a nice location for your gray tank.
Old 12-07-2009, 06:36 PM   #3
1959 22' Caravanner
Here are 2 more pictures of my project.. So much to do!? I used the black semi flexible hose to the shower and PVC to the galley sink. I am not putting the vanity sink back because I thought I did not need 2 sinks within 4' of each other. I am going to make the previous vanity space into a desk space by making the wardrobe smaller to make the desk larger.
The 22' Airstream in the vintage class seem to be the perfect size
ID:	92238   Click image for larger version
Old 12-07-2009, 07:30 PM   #4
pbearsailor's Avatar
Port Hadlock , Washington
I agree on the vanity, Jeff. Planning to do about the same thing on my Caravanner as well.
Question on your gray tank: do you have a provision for dropping the tank from underneath if need be for repair later on?
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-07-2009, 08:17 PM   #5
1959 22' Caravanner
I thought about bolting the grey tank supports in but its as easy to cut the 11 gauge 1 1/2" angle supports when its time for repair.
Old 12-08-2009, 05:22 PM   #6
1959 22' Caravanner
black tank
While removing my bathroom in the 59',I noticed the black tank (pictured below) was constructed out of fiberglass. Is this the original tank?? The vent for the tank came out of the wall, but was not hooked up to the tank (1st clue).I thought the tanks back then were of metal construction.... Any thoughts??? Thanks
ID:	92291   Click image for larger version
Old 12-08-2009, 06:09 PM   #7
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I would use PVC if you are going out the side and less than 3'. If you are longer than that or going to run it to the back, I would uses PVC with a rubber coupler. Place the it about 6" away from tank. I do this so that the flex of the trailer will not break the tank parts or the PVC... Good luck
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-08-2009, 08:08 PM   #8
Images: 59
Thats the original tank. The vent was actually part of the toilet.
It's the 1 1/2" chrome tube just below the square plate.
. . . and good luck getting that gate valve off the tank outlet.
1959 caravanner
Extreme Makeover: Home Edition Airstream Renovation emhe Our Community 0 06-20-2011 08:28 PM
Any red flags on buying a renovation project? hankyknot General Repair Forum 23 05-17-2011 07:49 PM
'57 Caravanner for sale Julison 1952-1960 Caravanner 2 02-27-2011 07:11 AM
'59 Airstream Caravanner travel trailer eBay Watch Airstreams on eBay 0 01-29-2011 08:00 PM
