Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 09-21-2004, 06:16 AM   #1
Silverfly
Silverfly's Avatar
Profile:
What is this switch for?
Hi There, On my 62 overlander -What is this switch for? It is located behind the sink. It is wired but activates nothing?
Name:	62 Overlander Questions 001.jpg
Silverfly is offline   Reply With Quote
Old 09-21-2004, 08:20 AM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Your coach is old enough that it may still be a air over water system. That swtich may be for the Grover air pump and if the pressure is up then they pump will not run till it's low. Do you have a pressure gage anywhere? Tank should be against front wall and the pump next to it. Our pressure gage was right next to the window. Picture in my gallery.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-21-2004, 08:31 AM   #3
Silverfly
Silverfly's Avatar
Profile:
The pump switch makes sense, my airstream has been converted over to the demand type. The switch for it is now under the sink. Thanks.
P.S Does someone have a close up picture of the latch mechanism for the rear curbside side door? Mine is missing.
Old 09-21-2004, 10:56 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Silverfly!
I have the same switch arrangement in my '64 Overlander. In the case of my '64 Overlander, it controlls the porch light (not the "scare-light"). A photo of the optional porch light is below:
According to what I have been able to learn, the porch light was an option seeing limited popularity that was available from sometime in the 1950s through the mid-1960s. I was actually able to locate a pair of NOS shades for the fixture at a WBCCI International Rally about four years ago. I have learned of at least one 1958 and two 1962 coaches that were equipped with this option.
The owners' manual for my coach doesn't mention this switch nor the option, but it was a factory installed option - - friends of my family special ordered the coach new during the '64 model year.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-21-2004, 11:04 AM   #5
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Jelous of that light! I have the same mount on the coach but I metered it and it's hot all the time. There are only two swtiches in my coach and one is a regular style light switch over the Goucho next to the front window and it appears to be wired for the Grover. The other swithc is for the porch light next to the door. Every other switch is on the fixture they control.
1959 22' Caravanner
Atlanta, GA
Old 09-21-2004, 12:40 PM   #6
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
I've got the same outlet/switch combo, in the same locationon my '67 Globetrotter. It's currently wired to turn the 12 volt power on and off to a ShureFlow demand pump. The previous owner replaced the piston? type pump and left it in place, just connecting the new one with chunks of garden hose. I don't know for sure how much rewiring he did or if the old pump is 110 or 12 volts. I'll rut around in the basement tonight to find the old pump to find out it's voltage.
Tom
Tom Nugler is offline   Reply With Quote
Old 09-21-2004, 01:14 PM   #7
61Overlander
61Overlander's Avatar
Profile:
The proximity to the sink gives it away. If it's 12 v, you can bet it was the pump switch. My original switch location for the 12 v pump is on the side of cabinet next to the stove. I still use the original tank and pump system, althought the pump has been replaced. Found a pic of it, the switch is on the right side of cabinet in this pre restoration pic. Mike
61Overlander is offline   Reply With Quote
Old 09-21-2004, 01:16 PM   #8
61Overlander
Profile:
oops, hit submit instead of attach.. here's the pic
Old 09-21-2004, 03:42 PM   #9
Silverfly
Silverfly's Avatar
Profile:
I am satified it is for the pump. I will look for the wire under the bed and use it to now power the demand pump. This will eliminate the PO's toggle.
Does someone have a pick of the latch mechanism on the rear curbside side baggage door?
Pump Switch Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 1 06-28-2004 08:39 AM
Transfer switch markdoane Electrical - Systems, Generators, Batteries & Solar 1 02-21-2004 01:43 PM
electric couch switch Tom & Janet Salhus Electrical - Systems, Generators, Batteries & Solar 1 10-13-2003 05:53 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 04:09 PM
Light Switch JOECAR 1975-1976 Excella 500 1 03-16-2003 09:30 PM
