Old 08-18-2012, 03:47 PM   #1
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
Weight ratings of a '58 Overlander?
In reading the specs of our '58 Overlander it says the overall weight is 3850 lbs. Is this unladen? What is the gross versus net weight?
SpikeC is offline   Reply With Quote
Old 08-18-2012, 04:02 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I don't think those numbers are available for early trailers.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 08-18-2012, 04:23 PM   #3
1963 19' Globetrotter
Syracuse , New York
Images: 38
Classic Airstream Weight Ratings
Our 1963 globetrotter is "rated" - that is titled - for 2990 lbs (same as the 1963 brochure). I've weighed our and it weighs a little more than that empty. I think that shows that the classic Airstream brochure weights are curb, not gross.
mhutchinson is offline   Reply With Quote
Old 08-18-2012, 04:41 PM   #4
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Try this
airstreamguy.com - ** Airstream Lengths, Weights and Tongue Weight
Good site for some of that info...
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 08-18-2012, 05:13 PM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Our '66 Trade Wind is stated to be 4100# with a tongue weight of 410#. I find that that is close as when I weighed the tongue and it came in close to 500# partially loaded. I have to be carefull as a PO increase the fresh water capacity to 40 gals. I try to tow with half or less water and fill up at the sites. We do dry camp when not attending rallies but it's difficult for me to tranfer 5 gals at a time. Upon returning from our recent camping in a forest service campground I noticed that even with loading the heavier camp supplies over and behind the axles the rear of the car 'felt' heavier so before unloading I weighed the tongue. The scale maxed out at 750#s!!! Then it occurred to me that we didn't take our planned showers the last morning. 40 gals of water in tanks at the very front of the coach!!
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
At home for
Spring
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
FreshAir is online now   Reply With Quote
Old 08-18-2012, 05:45 PM   #6
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
Thanks casa3805, aka Chuck, that list doesn't give any insight on the '58 Overlander capacities. I guess the stated weight is just the curb weight. It would be nice if the GWR was available, but I guess it isn't!
I'm towing with a '08 Expedition with the towing package that is rated pre SAE at 9K lbs, I probably don't need to worry about it, but it would be nice to know!
Old 08-18-2012, 08:45 PM   #7
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
From what I have read here and elsewhere the specs:
Airstream, Inc :: Specifications
from the factory at time of manufacture were as an "as sold" per dry weight with no options beyond the specs. listed.
But, apparently the specs for anything beyond around 1988 are suspect to interpretation from the afore mentioned link. Best bet is to weigh your coach at dry weight at a site that has a recent state inspection sticker on the scales. Then you can determine the loaded weight for the gross tow for your coach (from your spec loaded sheet in your owners manual) and tv. Then your axle age and tires can be factored in as to what you can safely haul inside your coach and what you what you haul in your tv to achieve the desired hitch height of your coach and tv. Anything that over weighs you coach gross weight you can haul in your tv as long as your tv can handle the load as per hitch height and gross weight.
Seems technical and discombobulated, but the specs are the specs for safe travel.
1975 Sovereign
"The Silver Bullet"
Ford F350
Big C is offline   Reply With Quote
Old 08-18-2012, 08:58 PM   #8
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
Thanks for the input! Unfortunately there are no owners manuals for 1958 airstreams. The problem is coming up with specs!
Old 08-18-2012, 11:38 PM   #9
FreshAir's Avatar
1966 24' Tradewind
The max specs for the axles should give you a clue.
Neil
FreshAir #12407
Avatar;
At home for
Spring
1966 Trade Wind
455 cid
455 cid
Old 08-19-2012, 06:20 PM   #10
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
The axles were replaced by Mello Mike not too long ago, so no help there.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
