Old 02-21-2011, 06:11 PM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
The conversion begins - with pics
Now several hundred dollars in, and a lot of hours, things are starting to take shape.
Olympic rivets are cool. I'm sure they are even cooler with a shaver.
The PO used what I think where propane vent covers over the vent stacks. They were much larger than what VTS sells, which are still larger than what was original, so I had 14 holes per vent I needed to fill. I primed and painted the vent covers from VTS a chrome silver, and used 2 layers of silicone glass impregnated sheet sealers between the metal covers and the aluminum skin. Interestingly, the PO used plumbers putty for a water tight seal. It actually worked very well, and I thought about using it again myself, but instead just went with the original design. I used foam as a gasket around the pipe, and I cut stainless steel sink strainers and pushed those up in the inside of the vent covers to prevent wasps. I'm glad I took these off in the winter, as there were about 3 nests per cap.
ID:	122805   Click image for larger version
robwok is offline   Reply With Quote
Old 02-21-2011, 06:15 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Looks really nice.
What is "silicone glass impregnated sheet sealers"?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-21-2011, 06:16 PM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
and the Jalousie
The Jalousie windows were interesting as well. The first pic is the original bulb seal, and the new one. The original was a stiff as a pencil. No sealing going on there!
Replaced the brush type weatherstripping, and all the vinyl buttons that hold the glass. It's frustrating, because I got pretty good at it by the end, after I worked out all the tricks getting them in and out. The real trick is to use a lubricant to get the new rubber seals in the track. I used boeshield, which is a waxy lubricant made to keep tablesaws from getting rusty. Works great.
Old 02-21-2011, 06:19 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
pics
Sorry, didn't wait for the pics to upload
ID:	122808   Click image for larger version
Old 02-21-2011, 06:21 PM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Originally Posted by DanielB View Post
Looks really nice.
Went to advance auto, and got gray gasket material. It comes in a rolled up sheet, and I just cut out a gasket shape to help prevent the electrolysis.
Old 02-21-2011, 06:21 PM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
sorry, not electrolysis. I can't remember. The corrosion battery effect whatever that's called.
Old 02-24-2011, 12:38 PM   #7
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Okay, now I feel a little silly. I thought it was plumbers putty. Felt and looked like the same stuff, and cleaned up the same, but in fact, it was butyl tape - now that I look at that closer. I ordered some, and I'm going to unscrew and put in the butyl tape. wow, what a learning process!
Pics Althea68 Forum Admin, News and Member Account Info 16 03-28-2011 09:21 PM
Help Identifying parts in these Pics???? robwok 1960 - 1964 Overlander 7 02-12-2011 09:23 AM
Help me resize pics Althea68 Forum Admin, News and Member Account Info 7 02-07-2011 10:45 PM
Overlander Gaucho pics NicheVintage 1965 - 1969 Overlander 11 01-28-2011 01:12 PM
Ah Yes! The Adventure begins. johnwatkins Member Introductions 3 01-15-2011 08:17 AM
