Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 06-24-2004, 11:22 AM   #29
Profile:  , Minnesota
Images: 55
Originally Posted by psychpw
Floor really still looking OK structurally . Needs to be cleaned up and hope no surprises under the layers of tile, backing and glue. Everything is out of the trailer except the tub, the kitchen overhead aluminum cabinet, and fresh water tank. Tub seems to be held in by the drain . Only has one small crack in the surround asiele side front corner. Looks easy to fix. Anyone know if the 59 tubs were fiberglass or another type of plastic. It doesn't seem dried out. Pictures to follow.
Fiberglass i believe.
There's a fine line between a hobby and a mental illness.
Old 06-24-2004, 04:27 PM   #30
Profile:  1958 26' Overlander
Tijeras , New Mexico
The tub in my 58 is fiberglass. As with Flyfisher and myself, our tubs were stuck/glued to the floor.
I would also suggest that you junp in and down on your rear bumper and front tong to make sure you don't have seperation
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 06-24-2004, 04:52 PM   #31
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Duh?
Ken
Ken J,
Hi-lighted in blue..begs the comment.."Excuse me????"
ciao
53FC
53flyingcloud is offline   Reply With Quote
Old 06-24-2004, 06:07 PM   #32
Thats what happens when you can think faster than you type - soooooo will try this again - jump up and down on the rear bumper and thats tonque....... man o man my spelling is getting worse and worse........
Haste does make wsaite..... or is that waist or waste
Ken
1958 Overlander
Old 06-24-2004, 10:23 PM   #33
grins
Ken
LMAO
You know I couldn't resist`!!
ciao
53FC
Old 06-25-2004, 05:54 AM   #34
Images: 55
Unglued.
(shower pan, not referring to above posts)
Old 06-25-2004, 08:50 AM   #35
53 No prob - actually I appreciate it, I do get to typing too fast sometimes and have to admit often I've got 6 things going on at one time.
Ken
1958 Overlander
Old 06-27-2004, 08:55 PM   #36
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Glued. I don't like that at all. Seems to be helld at the drain but I'll be more carful.
Go camping . . . . .
Over59 is offline   Reply With Quote
Old 06-28-2004, 07:13 AM   #37
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
The tub is attached at the drain.You have to unscrew the drain from inside the tub.You can do it by crossing two screwdrivers in the drain and unscrewing the drain.Same as in the tub in the house.There is a tool available for the house drain but may be too big for the trailer.
BTW have you changed that coupler yet.
greg176 is offline   Reply With Quote
Old 07-07-2004, 12:56 PM   #38
Over59's Avatar
1968 17' Caravel
Images: 37
Slow....
Have not. Still cleaning out inside and getting the house ready for the painter coming in August. Will have it done when trailer gets new cross members and holding tank support work done. Maybe the fall.
Old 08-12-2004, 07:55 AM   #39
Over59's Avatar
1968 17' Caravel
Images: 37
Everything is out but the tub and fresh tank. Both in good condition. I'll be cutting the tub drain from underneath with the sawsall. Also need to work more on the fresh tank drain pipe to get the tank out, may just cut it also. Otherwise things came apart with a little effort and a 18" pipe wrench. Found another plate size floor problem under the water heater. Good news is even there the frame was great, a little surface rust.
New picture in gallery. This is progress
Old 08-12-2004, 01:02 PM   #40
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
That cast iron P trap is not available....I would not cut it!!!!!!!!!!!
Mine was a fight but I finaly got it free with the trick Greg mentioned. What you might do is get somebody Up top to hold the screw drivers like greg said and get underneither and try to twist. Once it moved a little it came right out.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-12-2004, 06:28 PM   #41
Over59's Avatar
1968 17' Caravel
Images: 37
Well then I'll try again. Had a youngin holding the bottom while I twisted the little metal dividers out of the drain. Prehaps several WD40 treatments and some heat on the trap will help. I guess I could cut the floor around the drain and take the whole thing out and deal with it after it's out.
Thanks for the warning. Even if I don't use it I am sure someone will like to have it.
Now to tell the wife about the 54 Crusier in Michigan I want.
Old 08-20-2004, 10:49 AM   #42
Over59's Avatar
1968 17' Caravel
Images: 37
No 54 cruiser for me.
I cut around the P trap from underneath and pulled the whole thing up to get the tub out. Alast more bad floor. Along the edge only and under the wall. Around the tub and across the back about 60%. The rear interior panel is corroded on the bottom about an 1/8 inch. The street side lower panel has a PO 8" hole in it so needs replacement or fiber glass patch.
Plan: remove lower interior rear skins to get a good look at floor edge. The bathroom floor is a separate sheet or I may replace it. This would likly make replaces to the last frame cross member easier as well. It's about gone. Also some main frame rot on the street side about where the toilet was.
There are three other problem areas so far. Under the window by the door, under where the water heater was, and just inside the curbside wheel well. The later is weak. There is a springy area in the middle living room. Whats amazing is looking under from the back you can see middle area frame cross members which still have black paint.
I hope to avoid the full monty as it well add a year to the job.
Pingbacks are On
Lower door step TomW Steps 31 01-17-2005 01:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 08:09 AM
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
SEO by vBSEO 3.1.0
