Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 11-27-2005, 07:12 AM   #113
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
"The Bat Cave Express" is at the Airstream dealer in Waterbury CT getting it's wings put on. Pulled real good for the 90 minute ride. I was short a part so they had to keep it. These guys have been very good so far. Seem really interested in the rebuild.
The holding tanks and one of the fresh water tanks are in and plumbed. Fresh water tubing is in and plugged at each fixture, ready for a pressure test. I still need to add the forward fresh water tank.
Water heater and furance are in as well. We are setting up work space in the basement to build the cabinets over the winter. Really want to get it on the road for the Cherry Blossom in April.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 11-27-2005, 09:26 AM   #114
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Paul
Gosh I've been around this Airstream stuff a long time, what are wings? I knew they were special - did not know we could make them fly......
Anyway, let me know if you need any help on the cabinets, have mine all built and ready to install as soon as I get the inside painted - have to wait for spring for that......
Ken J.
1958 Overlander
Ken J is offline   Reply With Quote
Old 12-27-2005, 01:11 PM   #115
nameuroy
Fresno , California
Smile looking for info on Overlander 1959-1960 tire and wheels
I am looking for information on a 1959-1960 Overlander. I need to find out tire and wheel sizes, brake info and so forth. WE are planning to purchase this trailer, but it will need a lot of work. At this point we want to make sure it is road worthy to come home. Any info would be greatly appreciated.
nameuroy is offline   Reply With Quote
Old 12-31-2005, 10:08 PM   #116
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
1959 Airstream Overlander Tires Wheels
Greetings nameuroy!
Welcome to the Forums and the world of Vintage Overlanders!
The 1959 would be of an era where a beam axle with leaf springs, and split-rim wheels would have been the norm. It would also be from the time-period when the coach could have been ordered with either a single axle or a tandem axle setup -- and if a tandem axle, it could have four-wheel electric drum brakes; electric drum brakes on one axle and hydraulic drum brakes on the other; or four-wheel hydraulic drums.
From the standpoint of wheels, if the coach has its original split-rim wheels, the general consensus is that replacement with modern wheels that support tubeless tires is nearly mandatory. My advice would be to have a local shop measure the clearances involved as well as the off-set, bolt-circle, and center opening to insure that the replacement wheels will fit. Tires can also become an issue as clearances can be tight in the wheelwells on some coaches -- I know that I have had a tire dealer measure and order new tires for each of my coaches to insure that if there was a problem fitting the wheelwell that the issues with measurements would be the dealer's and not mine.
Since both of my coaches are a bit newer than your '59, I am not certain what to suggest in regard to bearing and brake parts. If the '59 is similar to my '64, you should be able to find reasonably priced fully-loaded backing plates that include all new brake parts for far less than the individual parts with the plus being that all critical brake parts are new. The bearings and seals could have some variability based upon whether the coach was produced in California or Ohio; and also in some instances where it fell in the production run for a given year -- again, this is something that can often be sourced from a knowlegeable auto parts store (particularly in rural areas) or from utility trailer parts houses.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 01-14-2006, 01:34 PM   #117
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
If you read the posts at the beginning of this thread you will find most of the info. The trip was interesting. What do you know are the trailer? Also may help to start a thread as this is long an many who load threads from the beginning don't see later posts.
Old 01-14-2006, 01:39 PM   #118
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Shower Wall
I am back at it. Had bad time with the ZipDee install. The dealer damaged the trailer, denied it, tried to charge me double the quote. Will not be doing business there again.
I finished the tub wall. Take a look. It's in our shower being tested for spotting. Those are water beads.
Old 01-14-2006, 01:43 PM   #119
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Looks like you need some Glass Wax or something similar to keep the water from beading. Unfortunately, Glass Wax is no longer produced although there is one on Ebay that's closing soon.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 01-18-2006, 03:58 PM   #120
ankornuta
ankornuta's Avatar
Profile:  Currently Looking...
Lowell , Massachusetts
Images: 22
So what is this weird plate thing in the front of the trailer holding the body on? It sticks up about 2" higher than the u-channel everywhere else?
ankornuta is offline   Reply With Quote
Old 01-18-2006, 04:47 PM   #121
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Ankornuta,
Talk to me, is it a steel plate or aluminum skin material. I have an L shaped piece of skin at the front about 4" on each leg.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 01-18-2006, 09:14 PM   #122
ankornuta
ankornuta's Avatar
Images: 22
Bill, I think it's aluminum. But the damndest thing is that I have a "battery holder" type steel contraption welded onto the A-frame part of the hitch which is preventing me from drilling those rivets out of it.
I would like to grind the battery holder deal off and rebuild it anyhow (although it is original), but I don't really want to grind it right NOW, while there's still all that wood and junk (like the body) to catch on fire while attached to the frame...
So what was the purpose of this plate?
Old 01-18-2006, 09:57 PM   #123
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
There is a steel plate in the front which attaches the frame to the shell. Look to drilling the rivets from the inside. I didn't have anything in the way from drilling from the outside. If you are careful you may be able to grind off the rivets from the inside and punch them out. You must put this or a replacement back on.
Old 01-18-2006, 10:45 PM   #124
wkerfoot
wkerfoot's Avatar
1954 29' Liner
Orange , California
Does it look like this?
Akornuta,
Does your aluminum piece look like the one in this picture? I think that that is what was used to help secure the front to the floor in addition to the channel before Airstream started using a steel plate welded to the frame cross member and riveted to the front shell. RJ Dial's 1957 Flying Cloud has the same thing.
Bill
Old 01-18-2006, 10:46 PM   #125
wkerfoot
wkerfoot's Avatar
1954 29' Liner
Orange , California
Over59,
I do not have this steel plate on my 1954 Liner.
Bill
Old 01-23-2006, 09:41 PM   #126
ankornuta
ankornuta's Avatar
Images: 22
It's steel on my '58, afterall. And I had to drill it out from the backside (inside the trailer), but it wasn't too bad.
Lower door step TomW Steps 31 01-17-2005 02:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 09:09 AM
Need a step? jcanavera 2001 Safari 8 01-26-2003 12:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
Powered by vBulletin® Versi
