Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 06-19-2005, 12:32 PM   #99
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Whatever is handy. I have used WD40, ATF, ZEP50, and on occasion air tool oil.
Uwe
Old 06-19-2005, 05:40 PM   #100
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
The grade 8 are for attaching the angle bracket to the rib. Most have only one ot allow some movement in an extreme situation. Though the floor are just zinced steel 1/4 20's. I figure if a hurricane wants it then it will have to take the whole thing in one bite.
More Aluminum for the belly pan came Friday, now have all I need. Not much progress today. Bought the plumbing parts for connecting the shower/tub to the shower pump with a gravity option. This hose size stuff will make you nuts.
Got the Caravel ready for next weekend "gathering" at the Cape Cod Canal. had to change the dump valve. Pretty easy if you have the right parts. Put grade 8 bolts and nuts on the tongue jack. Washed the trailer, make some new connections for the blue tank, and checked the air in the truck and trailer. Will charge the batteries all weeks and be ready to go.
Sixty days to go.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 07-02-2005, 09:05 PM   #101
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
49 days to go. Today I replaced the street rear section, attached the center belly pan, cut and formed the rear belly pan piece, and made channel for the rear end. Tomorrow attach rear belly pan section, do front belly pan section, Start wiring circuits that go between the skins and the tow hook up. Need to make some decisions about running lights, brake lights, backup lights, ect. Will wire for AC (Low Profile carrier).
It's going to be close....
Old 07-03-2005, 06:09 AM   #102
muddy_hollow
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Looking forward to seeing it at region1
I hope you are keeping pictures of all this work.
Are you going to caravan up through Rochester, Littleton and then onto Canada?
See you then,
Mud
65' Globetrotter 'The Otter'
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 07-03-2005, 06:11 AM   #103
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Shower sump drain.
This is the drain for the tub shower. The blue hose is to the pump which will pump the waste water into the waste water tank. The valve will allow for gravity drain to ground or blue boy as a hose connector will be added. The handle and the gravity drain opening will be below the belly pan.
Old 07-03-2005, 08:46 AM   #104
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock , Georgia
hey '59!
i just found your thread. it's nice to see another '59 just ahead of me. thanks for your comments in my thread as well. i saw really early in yout thread that there was a descrepency wether the trailer was a '59 or a '60. funny. mine says 1959 on the body in decals, but the title says 1960. it has the original 50's style "Airstream" placcards below both windows.
anyway, good luck with your trailer!
jordan
A-Merry-Can is offline   Reply With Quote
Old 07-03-2005, 05:42 PM   #105
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Today I took out the lower curb side window by the door and the center street side window. Both will be replaced with aluminum to allow for a change in the floor plan. Dinette with high back all the way around and a seamless kitchen back splash area. Also gives me room for a small wardrobe at the foot of each bed.
Got on side of the rear belly pan on, almost. This is a real struggle with the bumper in the way. Bolted down the wheel wells. Then ran the AC circuit wiring. Got tired and needed an easy job. Wrestling with sheets of aluminum under the trailer is exhausting.
48 days to go....
Need to order the water heater and space heater and electric toilet and water tanks and pumps.
Old 07-04-2005, 06:01 PM   #106
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Not much done today. Ran some more wire and did some more insulating. 47 days to go. I'm getting a little concerned about time. Ordered white coat (por stuff) for the caps and the tub.
Old 07-04-2005, 08:11 PM   #107
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally Posted by A-Merry-Can
hey '59!
jordan
Airstream, like Auto Manufactures has "year Models". The coach may well be a 60 model that built in late 59. I think October is the mark of the new model year.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 07-16-2005, 05:01 PM   #108
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Both end caps are back in after sanding off the old paint and recoating with expoxy. It was very difficult. Second Fantastic is in and extra supports for the AC are ready to go. All wiring that goes between the shells is in. The lower curbside front next ot door window is now covered with a new piece of aluminum. Tomorrow I hope to finish the patches and some belly pan trim. I'm running 2024t3 .032 along the edges midships. Oh, yea, learned how to take apart the air rivet gun and clear a jam. Water heater and furnance are on the way.
Old 10-28-2005, 04:40 PM   #109
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Working on the interior. Got the furnance workig today so we will be able to work during the cold weather. Here's a pic of some plumbing solutions.
Old 11-01-2005, 02:00 PM   #110
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
what kind of furnace did you get? does it require ducting? i am looking into heating solutions for our 18 footer. i really want an old, vintage lookng heater to mount on a wall, but i don't know of a good source. the ducted furnaces seem to be pretty pricey. the AC unit i'm looking at comes with a heat strip add-on option... good for camping with hookups, at least...
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
Old 11-06-2005, 07:23 PM   #111
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Without looking I thinks its an NT-30; 30KBTU. AC also has heater built in for mild chills with hookup. It has four 4" outlets, seems one must use at least three as they only give you one cover. It's likly too big for most of the year but I wanted the options of late fall or winter use. Not water below the floor level except the shower drain to the discharge pump hose. That's about 8 inches or a cup of antifreeze.
For a really cool wall unit check out the small marine cabin heaters. The original ones would scare me to use.
Old 11-06-2005, 11:07 PM   #112
StingrayL82
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Over59,
Very nice, indeed! I like the floor a lot.
Frederic
SSG Frederic Lynes
1971 31' Sovereign, restored
2004 F350 King Ranch
StingrayL82 is offline   Reply With Quote
Lower door step TomW Steps 31 01-17-2005 02:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 09:09 AM
Need a step? jcanavera 2001 Safari 8 01-26-2003 12:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
Airstream Forums - Airstream Cl
