Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 09-07-2004, 11:17 AM   #43
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Water Heater Parts
Pulled the water heater. Opened it up to find a rather nice aluminum tank inside. The knobs are in very good condition, the heater tube looks good, the regular is unknown. When on pilot it doesn't push down, prehaps it's not meant to do so. One end of the cover and the body of the cover are good. Of course the brass fitting are like new.
If you want any of these let me know. I don't know if the internal water tubing is good nor how to test it with out alot of trouble. If no one want the internal tank I may polish it for a what the heck is that garden sculpture.
I'll post some picture when the camera battery recharges,,,,
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 09-07-2004, 10:52 PM   #44
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Hi Paul,
I might be interested in the cover if it's in not to bad of shape and if it fits the opening I have for the newer Suburban WH. Can you post picture of it once your battery is ready? I'll go measure my existing cover. Thanks.
FF
2699
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 09-08-2004, 07:27 AM   #45
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
I am recycling the outside parts and working them in with a new heater so I'l be using the face plate cover.
Old 09-08-2004, 04:37 PM   #46
flyfshr
flyfshr's Avatar
Phoenix , Arizona
Glad to hear you're keeping the vintage look. Can't hurt to ask. Is that an International emblem showing in your avatar?
FF
WBCCI/VAC #2699
Air #10
Old 09-11-2004, 07:22 AM   #47
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
FF
Sure is. This is a 59 with the special 1960 plaque by the door.
This control unit is available if someone is interested.
ID:	8674   Click image for larger version
Old 03-08-2005, 09:22 AM   #48
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
After all the shell-on floor replacement research, ideas, and efforts it looks like I'll be taking it, all off. I put in the front piece of 3/4 marine flooring and I am not satisfied with it. I had to rout the edges to fit under the channel. The only way I see of getting the other pieces in is to take off the channel, put in the floor and then reattach the channel to the floor and shell and belly pan. Sounds like reattaching the shell in a shell-off doesn't it. So I need to move the trailers around in the drive so I I have a place for the shell, the frame and the Caravel. All hopes of using "The Bat Cave Express" for this year's Region One are gone. Which means I need to spend some time on the Caravel to use it this year. Need a LPG heater.
The up side is I'll take the frame to the axel guys who replaced the Caravel axel with modifactions they designed and latter approved by "you know who". Two new axels and wheels and adding some elevation so the trailer doesn't bottom out. Add some frame support for the water tank placement and bolt down and so I can use 1/2 marine floor. The 3/4 is too heavy. I'll be able to get the frame sand blasted and painted. Looks like I'll just have to do it right and use the Caravel for what outings we do. Also means I don't need that new truck yet.
While avoiding this reality I have designed what I believe will be the most elaborate DC system any personal trailer has seen, purchased the switches, wire, and some lights to try. Designed the water systems down to the tanks and the weight distribution and bought some pumps. Desinged the LPG system including the size of the supply pipe. The colors, theme, fabrics ect are selected. I even have two ZipDee pation awnings in the garage waiting. Did this with much help from you on the forum. So do you think you could come by and take the shell off some time soon? I was really trying to avoid this but was only avoiding accepting it. Looks like a BBQ / shell lifting party coming up, you are all invited.
Old 03-08-2005, 09:55 AM   #49
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Paul
Been there done that - feel your pain, admire your stick-to-it-ness.
Would love to join your party - except that I'm about 2000 miles from you.
Question - why don't you use 5/8" plywood - thats what was there before...... a little bit thicker than 1/2 - not as stout as 3/4 though..... and... in my opinion, if you don't need to do major frame work, taking the shell off is not necessary
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 03-19-2005, 08:53 AM   #50
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Fire?
This is the area behind the fridge. Looks like fire damage. The interior panels also have a black film in places as do some ribs. Look like a smoldering fire that started behind the fidge.
Old 03-21-2005, 02:00 PM   #51
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
All rivets are out, pushed through, and vulken seal broken, except those ataching to the front plate. Now I need to round up some jacks. I figure the shell to be about 400 pounds base on .46 pounds per square feet of 2024 and some for ribs and windows. Hope to take off the shell this weekend, then strip the frame for the sand blaster.
Old 03-24-2005, 04:31 PM   #52
Neophyte
Neophyte's Avatar
Profile:  1967 24' Tradewind
St. Louis , Missouri
Pictures, please!
As I am about (in a month or so) to venture down the same take-it-off-the-frame road you're currently on, a picture of the jack up and support rigs would really, really be appreciated.
Neophyte is offline   Reply With Quote
Old 03-26-2005, 02:31 PM   #53
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
It's off. As far as how it got this way I'll post some details later. I can tell you that some old retired guys from Airstream are sitting around laughing their... off about blind rivets, as in hidden from view. I'll be back with where to look for those as well.
I feel real good about this as I can now start to rebuild. The frame is in great shape overall. Still has the black finish coat on about half of it. It will be sandblasted and maybe primed need week. Then off to the axel shop.
I wanted to give it some height. Just need to put on straight axels. The orginals are a drop axel. It is low.
ID:	11204   Click image for larger version
ID:	11206   Click image for larger version
Old 03-26-2005, 02:42 PM   #54
Ken J
Paul
VERY nice job!
Ken
1958 Overlander
Old 03-29-2005, 10:57 AM   #55
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
The frame is now at the sandblasting company. The paint they use for coating is $450 a gallon. I declined the service and ordered a complete kit of POR 15. Hope to get it back Friday and take it to the axel shop.
Still debating the axel job. New everything? New Axels and plates ect, what rating, real axels or funny axels?.
I am leaning toward new straight axels @ 3000lbs, new shocks and four brakes and keepiing the 15.5 x 5 wheels. I like to look of the old bias tires on a vintage.
Old 03-29-2005, 11:25 AM   #56
Ken J
My vote is new everything - the only thing I may do is take the springs to a spring shop and have them look at them - its my understanding they can tell you what kind of shape they are in - doing this because you can't just order the 7 stack springs that are on the trailer. Am also planning on a new hitch tongue to be welded on.
Ken J.
1958 Overlander
Lower door step TomW Steps 31 01-17-2005 02:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 09:09 AM
Need a step? jcanavera 2001 Safari 8 01-26-2003 12:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
